Hello all. Currently trying to fix my nieces tv. Has no video. She did her own research and did the flashlight test. then ordered a replacement inverter. I installed it, however it did not fix the problem. There are no swollen caps. I suspicion the power supply board, but I need a schematic or other assistance in testing. Yes, I have a multimeter and a usb oscilloscope however, I don't know how to use the oscilloscope yet. Have searched and searched for service manuals, schematics, etc. to no avail. The power supply board is a BN44004400B. Thanks!
Need help with Samsung LN40E550f7f
Re: Need help with Samsung LN40E550f7f
pretty smart niece to figure that out it could be the inverter board. However for your board is a PSU repair kit at SJ available that fixes: The Samsung BN44-00440B Power Supply Component Repair Kit includes all necessary components to repair common failures on the Power Supply. Symptoms include will not turn on, no backlights, missing 5V standby or PFC.
http://www.shopjimmy.com/samsung-bn4...repair-kit.htm -
So what Voltages do you have on the connector of the power supply board that goes to the main board when TV is in standby and when power switch is activated?
You MUST report the pin name and follow by the Voltage reading for each pin so we can see if they are correct or not.
We also need good clear the pictures of YOUR whole power supply board.Last edited by budm; 02-19-2018, 06:19 PM.Never stop learning
Exercise caution when testing power supply board, it can be deadly. there are legends like little maps on the power supply board that tell you what voltages to expect from the connector pins, put negative lead on ground like the chassis for example, also check those 2 fuses if you haven't, I check those fuses with tv off and unplugged. The voltages have to be checked with tv on or plugged in of course.Last edited by nomoresonys; 02-19-2018, 09:42 PM.Comment
Voltages are as follows both on the power supply as well as the lead in to the logic board:
Power supply:
Pin 1=5.17
2= 5.17
4= 12.78
5.=12.78
6.=12.78
7.=12.78
At Logic Board= same
Lead to inverter:
pin 10= 12.07
pin 2= 12.76
At Inverter: Same
Any not listed had value of 0.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thank you for the warning. I actually have done a lot of computer work and 3 t.v.'s so far. I learned my lesson on things holding a charge years ago.Exercise caution when testing power supply board, it can be deadly. there are legends like little maps on the power supply board that tell you what voltages to expect from the connector pins, put negative lead on ground like the chassis for example, also check those 2 fuses if you haven't, I check those fuses with tv off and unplugged. The voltages have to be checked with tv on or plugged in of course.
I found the voltages on the board. - Not easy to read!Comment
If you do post voltages and pin numbers, you have to include the pin out name. Your pictures are way too small in order to see anything like that what we need. You need to upload high resolution pictures, so we can see the details.Comment
1) No pin names to tell us what each pins are.
2) There are 14 pins on that power supply connector that goes to the main board but you only report 7 of them and without the pin names as requested then those reported numbers are just about meaningless.
3) Samsung BN44-00440B power supply board?
4) You need to follow the instructions.Never stop learning
Cool, just a stock warning, cuz there's no way of telling a posters knowledge depth.Comment
Don't give up, what I do is just copy the legend/map on a piece of paper, pins and description, like bl-on etc, then just type it back in here with the voltage you got next to it.Comment
http://www.shopjimmy.com/samsung-bn4...upply-unit.htm is this your power board? you may have gotten a bad tcon board, hard to tell, I see shopjimmy has 1 for 10 bux. oops my bad you said inverter not tcon.Last edited by nomoresonys; 02-20-2018, 08:54 PM.Comment
Does this tv have a metal back cover? if so are there any burn looking marks on it, like where the power board is etc. just worked on a sammy ln40c650, you can check my thread if you care to, but take your time, I double and triple checked everything before proceeding, you may have a whole different issue of course.Comment
Maybe start with those 2 big 450v filter capacitors, check m with black lead on negative side and red lead on positive side right on the legs, should get around 160 in standby and 380 volts while tv is on.Comment
psb:
1. B13V -13.1V
2. DIM- 5V
3. B13V-13.1V
4. NC -0V
5. B13V- 13.1V
6.BLU_ON -0V
7. B13V-13.1V
8., 9., 10 GND- 0V
11.B5V- 5.1V
12 A5V - 5.1V
13. B5V- 5.1V
14. PS_ON- 3VAttached Filesif you find these attachements useful please consider making a small donation to the site
No scorch marks. 450v caps read 375v. Everyone is talking about standby mode; on this t.v. , when is off, the indicator light stays red and I have no readings. If I turn it on, it chimes, the light flashes and then goes off. After several minutes, it shuts off.Comment
Don't have a schematic, not sure if this one will do it, try unplug power supply board from main board, see if backlights go on.Comment
Assuming...7 Photos -
by NicktronicHey everyone,
This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
Anybody... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by repair-itI am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... - Loading...
