Need help with Samsung LN40E550f7f
  • Kindred1
    • Feb 2018
    • 55
    Re: Need help with Samsung LN40E550f7f
    Bottom line is we do have voltage from main to power board when t.v. is powered on. - Sorry for the confusion.
    • nomoresonys
      • 12323
      • U.S.
      #82
      Looks like the mainboard isn't sending the blu_on signal to the power supply.
      • nomoresonys
        • 12323
        • U.S.
        #83
        You could try fixing the mainboard but it can be very technical.
        • Kindred1
          • Feb 2018
          • 55
          So to clarify on my end. there is no power on Blu_on - during standby. When tv is powered on, then I have voltage. Therefore, the main board is sending signal and the signal is staying on. - So, I think I'm back to checking the inverter board. The layout is different than the ones I find online. I'm going to look again, the post a pic of it if I'm unsuccessful. Unless you all have any other has suggestions.
          • nomoresonys
            • 12323
            • U.S.
            #85
            Ok, just to be clear, with all boards hooked up, you do have about 3 volts on blu_on pin, when you check it?
            • nomoresonys
              • 12323
              • U.S.
              #86
              Well if your inverters you have 2, the original and one you bought, check out ok, it may be a backlight issue.
              • nomoresonys
                • 12323
                • U.S.
                #87
                http://www.shopjimmy.com/cmo-27-d070...t-inverter.htm good pic. of the inverter, probably test it next.
                • nomoresonys
                  • 12323
                  • U.S.
                  #88
                  https://www.youtube.com/watch?v=oE6K4xBVweA checking inverter its a samsung but a different model, gives you a good idea of what to do.
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    This model does have pull up resistors. Point in case, if you unplug mainboard from power supply you will get backlights. If you don't, look at inverter or CCFLs.
                    Shine a flashlight into the screen and hit the menu button. See anything?
                    These E series were some if the last that used CCFLs before going all LED. They have a moderately high failure rate. The connections that the CCFL bulbs use inside are spring loaded into the sockets. They break down.
                    • nomoresonys
                      • 12323
                      • U.S.
                      #90
                      Was trying to find a video with someone testing an E series inverter but no luck, not sure of the differences between series.
                        This power supply board it supplies high frequency AC to connector CNI801 pin 3 (LOW 193VAC) and pin 1 (HIGH 373VAC) of the power supply board to drive the Primary winding of the Inveter transformers on the Inverter transformer board.
                        If it is bad lamp problem, the backlights should flash on for seconds (unless ALL the lamps are bad which is not likely) before the inverter transformer driver circuit on the power supply board goes into protection shutdown.
                        O.P. need to verify if he is getting the high frequency AC drive Voltage to drive the primary side of the inverter transformer on the inverter transformer board or not.
                        • Kindred1
                          • Feb 2018
                          • 55
                          With everything hooked up and the tv powered on I get 5.14v on blu_on.
                          • Kindred1
                            • Feb 2018
                            • 55
                            Yes, I can see the screen static and some lettering with the flashlight. No backlights with mainboard unplugged.
                            • nomoresonys
                              • 12323
                              • U.S.
                              #94
                              I guess test the inverter, if that's ok, what else could it be but a bad ccfl?
                              • Kindred1
                                • Feb 2018
                                • 55
                                I think we found our problem Budm. I am not getting voltage at those pins. I am checking with inverter unplugged direct from the pins on the board.
                                • Kindred1
                                  • Feb 2018
                                  • 55
                                  So, where do I check for the fault?
                                  • Kindred1
                                    • Feb 2018
                                    • 55
                                    Weird thing is, I remember getting some voltage there early on, tho' I don't remember what they were.
                                    • nomoresonys
                                      • 12323
                                      • U.S.
                                      #98
                                      Trying to remember if you had the proper voltage on the filter capacitor legs?
                                      • Kindred1
                                        • Feb 2018
                                        • 55
                                        That's the large 450v caps?
                                        • nomoresonys
                                          • 12323
                                          • U.S.
                                          #100
                                          Yes, remember high voltage in that area use caution.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Nicktronic
                                            Samsung Power Supply Board BN44-00874F
                                            by Nicktronic
                                            Hey everyone,
                                            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                            Anybody...
                                            03-17-2025, 06:20 AM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • repair-it
                                            Need advice testing a samsung power supply board with scope
                                            by repair-it
                                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                            07-12-2025, 11:00 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
