Need help with Samsung LN40E550f7f
  • nomoresonys
    • 12331
    • U.S.
    #181
    Re: Need help with Samsung LN40E550f7f
    Originally posted by pocketwatch62
    would the backlights stay on if the CCFLS are ok with the main board disconnected or just flash for a split second which is what they are doing with the main board disconnected.
    They stay on, when pullup resistors are present, usually means backlights and powerboard are ok.
    • nomoresonys
      • 12331
      • U.S.
      #182
      Do test on post 180.
      • pocketwatch62
        • 74
        • US
        #183
        when i hit the power BLU_ON goes to 5.16v and drops to 5.14 and is steady at 5.14v.
        • nomoresonys
          • 12331
          • U.S.
          #184
          I might have misunderstood, are they staying on or just a flash then off?
          • pocketwatch62
            • 74
            • US
            #185
            Just a flash for a split second but i can see they are all coming on.
            • nomoresonys
              • 12331
              • U.S.
              #186
              What does it read before you hit power, which is just standby?
              • pocketwatch62
                • 74
                • US
                #187
                BLU_ON reads 0.00 before i hit the power button.
                • nomoresonys
                  • 12331
                  • U.S.
                  #188
                  Ok, looks like we're back to powerboard, unhook inverter board/s from powerboard, have cable from powerboard to mainboard in place, see if you have around 400 steady at the filter caps when you hit power, be CAREFUL 400 volts can kill.
                  • nomoresonys
                    • 12331
                    • U.S.
                    #189
                    Ok, that's good.
                    • pocketwatch62
                      • 74
                      • US
                      #190
                      with inverter unplugged and main board plugged in the main filters go to 439 DCV then drops to 147 DCV.
                      • nomoresonys
                        • 12331
                        • U.S.
                        #191
                        Ok, looks like we have confirmed the problem is on powerboard.
                        • nomoresonys
                          • 12331
                          • U.S.
                          #192
                          Check the diodes.
                          • pocketwatch62
                            • 74
                            • US
                            #193
                            Any ideal? we have all the low voltage.
                            • pocketwatch62
                              • 74
                              • US
                              #194
                              I have the are all showing good.
                              • nomoresonys
                                • 12331
                                • U.S.
                                #195
                                I suspect the little blue cap by the filter caps, think it's CP820 or sum such number.
                                • pocketwatch62
                                  • 74
                                  • US
                                  #196
                                  yes, it is CP820 i will change it and let you know.
                                  • nomoresonys
                                    • 12331
                                    • U.S.
                                    #197
                                    One way of testing caps without a cap meter: To test the capacitor with a multimeter, set the meter to read in the high ohms range, somewhere above 10k and 1m ohms. Touch the meter leads to the corresponding leads on the capacitor, red to positive and black to negative. The meter should start at zero and then moving slowly toward infinity.
                                    • pocketwatch62
                                      • 74
                                      • US
                                      #198
                                      I replaced CP820 and CP804 did no change anything.
                                      • nomoresonys
                                        • 12331
                                        • U.S.
                                        #199
                                        Ok, at least it's good to have them off the suspect list.
                                        • nomoresonys
                                          • 12331
                                          • U.S.
                                          #200
                                          Thinking it must be in the pfc area, can you check the other components, check anything labeled with second letter P.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Nicktronic
                                            Samsung Power Supply Board BN44-00874F
                                            by Nicktronic
                                            Hey everyone,
                                            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                            Anybody...
                                            03-17-2025, 06:20 AM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • repair-it
                                            Need advice testing a samsung power supply board with scope
                                            by repair-it
                                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                            07-12-2025, 11:00 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
