Need advice testing a samsung power supply board with scope
  • repair-it
    • Nov 2020
    • 112
    • US
    I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
  • CapLeaker
    Leaking Member
    • 8250
    All you need is your DMM and set it to VDC. Plug the PSU in and it should turn on (depends on what Samsung PSU it is). Check the voltage on your main filter cap. Should be something like 380VDC if the PFC is working. That is all there is to it. No oscilloscope needed.
    Do NOT test the primary with an oscilloscope without the isolation transformer. That will blow up your PSU and your oscilloscope.
    • repair-it
      • Nov 2020
      • 112
      • US
      Thanks - wish it was that simple. These boards are know to fail due to a disc capacitor cracking, leading the failure of at least one power mosfet which in turn, can cause a failure of the pfc ic. Replacing the shorted mosfet and 4 disc caps, resulted in a nice little mosfet explosion. The next step is to verify that the pfc ic is or is not damaged - that is what I am attempting to do.
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • ohren
        by ohren
        09-08-2023, 05:24 PM
      • C152Heavy
        by C152Heavy
        Summary for TL-DR readers:
        • VCC pin (18) of PFC...
        01-11-2023, 02:53 PM
        09-07-2024, 05:50 AM
