Samsung Power Supply Board BN44-00874F
  • Nicktronic
    • Mar 2023
    • 247
    Hey everyone,
    This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
    Anybody have a schematic for this board? I'm struggling to troubleshoot without it. Also I'm open to advice on where to focus.
    Thanks!
  • nomoresonys
    • 12370
    • U.S.
    Whoa, the soldering of those replaced parts is a mess, that could be the problem.
    • Nicktronic
      • Mar 2023
      • 247
      Yeah, I didn't clean the board up for her photoshoot, but I assure you the solder joints are solid.
      • nomoresonys
        • 12370
        • U.S.
        I see, I would probably suspect the IC nearby QP802CS, the one with 14 legs there and maybe check the resistors by your mosfet, and maybe QP804 and the ones near it. See if you can grab a datasheet for that IC.
        • nomoresonys
          • 12370
          • U.S.
          I guess first order is getting the standby working.
          • nomoresonys
            • 12370
            • U.S.
            Go ahead and check all the transistors, thats all that start with Q for a short if you haven't already. For those that may be looking on and need to know. Put meter in beep mode, thats the one with the diode on some meters and check each of the three legs for a short, so one probe on leg 1 the other on leg 2 then 3, then go from 2 to 3, if you get a constant beep its shorted. If meter has no beep mode, you can test in ohm mode, if you get close to 0 ohms while doing the same test its shorted.
            • nomoresonys
              • 12370
              • U.S.
              To be clear, you replaced the parts with the correct part and after trying tv again, none of the parts are reading bad again, fuse didn't blow etc?
              • nomoresonys
                • 12370
                • U.S.
                Not exactly sure, but CP801S and CP802S may need to be checked.
                • nomoresonys
                  • 12370
                  • U.S.
                  Maybe do a quick ohm check of CM185, CM810 and CM814.
                  • Nicktronic
                    • Mar 2023
                    • 247
                    The IC is ICP801S, UCC28064A G4, datasheet attached.
                    The resistors beside QP801CS appear to be 0.25ohm each, but when measured out of circuit, both are dead short(0.01ohms each)
                    QP804 seems ok and the resistors around it are good.
                    • Nicktronic
                      • Mar 2023
                      • 247
                      All the FETS are good, no shorts. Should I check all the transistors on the underside of the board too?
                      • Nicktronic
                        • Mar 2023
                        • 247
                        Correct
                        • Nicktronic
                          • Mar 2023
                          • 247
                          They are 1uF each and measure 2.1uF in parallel. Seems ok.
                          • Nicktronic
                            • Mar 2023
                            • 247
                            They all measure good.
                            • nomoresonys
                              • 12370
                              • U.S.
                              Check the markings on those resistors, if it's a 0 ohm resistor then its ok.
                              • nomoresonys
                                • 12370
                                • U.S.
                                Sure, couldn't hurt to check them.
                                • Nicktronic
                                  • Mar 2023
                                  • 247
                                  Is it fair to say ICM801CS (FA6B22N, cannot find a datasheet) should be driving QM801CS and QM802CS when the board is in standby? It's switching the 170vdc of the filter caps, to ultimately provide an unboosted VDC on the output connector (7ish volts)?
                                  In the current state with the board on the bench and plugged in, on ICM801CS pins:
                                  1 - 68-69VDC
                                  2 - 0vdc
                                  3 - 0vdc
                                  4 - 7.2VDC
                                  5 - 0vdc
                                  6 - 0vdc
                                  7 - 0vdc
                                  8 - 0vdc
                                  9 - 0vdc
                                  10 - 10VDC
                                  11 - 0vdc
                                  12 - GND
                                  13 - 0vdc
                                  14 - 8VDC
                                  15 - 8VDC
                                  16 - 10VDC
                                  https://products.fujielectric.com/en...etail/FA6B22N/
                                  This link is the most info I could find for this IC.
                                  Thoughts?
                                  • Nicktronic
                                    • Mar 2023
                                    • 247
                                    Markings indicate 0.25 ohms, and two in parallel, so 0.125ohms
                                    • Nicktronic
                                      • Mar 2023
                                      • 247
                                      I did, and couldn't find anything...
                                      • lotas
                                        • Jan 2016
                                        • 5199
                                        • Russia
                                        FA6B22N can be replaced with FA6B20N, not much information...
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • repair-it
                                          Need advice testing a samsung power supply board with scope
                                          by repair-it
                                          I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                          07-12-2025, 11:00 AM
                                        • Cooperr
                                          Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                                          by Cooperr
                                          I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                                          The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                                          10-21-2025, 01:11 PM
                                          Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                                          I was working on this CNC machine today found no keyboard functioning no control relay powering on
                                          The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                                          Found shorted diodes on main controller relays there are 3 of them that...
                                          01-07-2023, 05:43 PM
