Need help with Samsung LN40E550f7f
  • pocketwatch62
    • 74
    • US
    #161
    Re: Need help with Samsung LN40E550f7f
    voltage as follows
    with all boards connected and TV on, but no backlights.
    psb:
    1. B13V----12.88v
    2. DIM----2.77v
    3. B13V----12.87V
    4. NC -0V
    5. B13V----12.87v
    6.BLU_ON---5.14
    7. B13V---5.14v
    8., 9., 10 GND- 0V
    11.B5V---5.17V
    12 A5V---5.18V
    13. B5V---5.17V
    14. PS_ON---3.30V
    • pocketwatch62
      • 74
      • US
      #162
      correction
      BLU_on---5.14v
      • nomoresonys
        • 12331
        • U.S.
        #163
        recheck 7, looks like it should be 13.
        • nomoresonys
          • 12331
          • U.S.
          #164
          Guess we need to figure out why 7 is only 5 volts.
          • Diah
            • Feb 2013
            • 6599
            you disconnect the MB from PWB the led back light blinked for second or less.. you have bad back light... take screen apart and keep the MB disconnected to repair the LED back light until they all on and stay on.
            • nomoresonys
              • 12331
              • U.S.
              #166
              Unplug inverter/s from powerboard, (best practice is always unplug tv from outlet before unplug any cables etc. then plug tv back in outlet and try it) see if 7 comes up to 13 volts.
              • nomoresonys
                • 12331
                • U.S.
                #167
                If powerboard isn't fully working there's no need to go further until it works correctly.
                  1) Pin 7 is more likely to be OP measurement notes error.
                  2) This TV does not have LED backights, it has CCFL
                  https://www.badcaps.net/forum/attach...8&d=1519166063
                  3) You need to check the DCV between the two legs of the main filter cap to see if you have PFC Boosted Voltage of 380 ~ 400VDC or not for the inverter Transformer drive circuit to work.
                  • nomoresonys
                    • 12331
                    • U.S.
                    #169
                    He did, post 160.
                    • nomoresonys
                      • 12331
                      • U.S.
                      #170
                      Check the little blue capacitor by the filter caps labeled CPxxx something like that. Did you heat the powerboard with a hairdryer?
                        Originally posted by pocketwatch62
                        nomoresonys,
                        The main filters comes up to 415 DCV for a split second the settles down to 159 DCV.
                        CP804 looks good but i know that don't mean nothing.
                        Do i need to remove it and check it?
                        Sounds like the PFC Boosted Voltage did kick on but went up over 400V so it may have trigger PFC shutdown so the Voltage goes back down to 160V.
                        • pocketwatch62
                          • 74
                          • US
                          #172
                          with main board disconnected the backlights flash for a second and all of them come on and are white, no black ends on the CCFL's buy the way i have 5.14 on BLU_ON with main board connected.
                          • pocketwatch62
                            • 74
                            • US
                            #173
                            nomoresonys
                            Heating the power board makes no change.
                            • pocketwatch62
                              • 74
                              • US
                              #174
                              Sorry pin 7 B13V reads 12.87 DVC.
                              • nomoresonys
                                • 12331
                                • U.S.
                                #175
                                If backlights come on and stay on, then usually it points to a problem with mainboard, sometimes panel or tcon.
                                • nomoresonys
                                  • 12331
                                  • U.S.
                                  #176
                                  Thought it was, would be pretty strange to only be missing one 13.
                                  • R_J
                                    • Jun 2012
                                    • 9624
                                    • nomoresonys
                                      • 12331
                                      • U.S.
                                      #178
                                      Might be a dirty or oxidized connection, try unlug n replug the cable from powerboard to mainboard on both ends a few times, carefully just want to make sure there's good contact.
                                      • pocketwatch62
                                        • 74
                                        • US
                                        #179
                                        would the backlights stay on if the CCFLS are ok with the main board disconnected or just flash for a split second which is what they are doing with the main board disconnected.
                                        • nomoresonys
                                          • 12331
                                          • U.S.
                                          #180
                                          Test the bl-on pin again, see if it changes voltages when you hit power.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Nicktronic
                                            Samsung Power Supply Board BN44-00874F
                                            by Nicktronic
                                            Hey everyone,
                                            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                            Anybody...
                                            03-17-2025, 06:20 AM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • repair-it
                                            Need advice testing a samsung power supply board with scope
                                            by repair-it
                                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                            07-12-2025, 11:00 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
