Need help with Samsung LN40E550f7f
  • nomoresonys
    • 12330
    • U.S.
    #141
    Re: Need help with Samsung LN40E550f7f
    Originally posted by Kindred1
    All the specs seem the same except for the packaging type. I don't know anything about said components except what I'm learning.
    I'm not sure, could call them and give m your part description number etc.
      I get 34.7vac
      All measurement are done in V DC mode setting on the meter.
      • Kindred1
        • Feb 2018
        • 55
        I knew I'd get that wrong. - 16.9 vdc
        • Kindred1
          • Feb 2018
          • 55
          So is that voltage correct?
            You have (-) symbol in front of the reading, is that right?
            If the Red probe is on the VCC pin 8 and the black probe is on GND pin 6 then it should not show as Negative reading on your meter, Please verify.
            The minimum start up Voltage for this PFC IC is 12VDC (+/-1V).
            • Kindred1
              • Feb 2018
              • 55
              No, that was a typo.
                That means the IC is getting the VCC to run so at this point I would get a couple ICs (buy more than one so you have spare in case it gets damaged during the soldering works) and replace it.
                Line #5 (cut tape) on that Digikey will work.
                • Kindred1
                  • Feb 2018
                  • 55
                  Thanks! I will continue to read up on this stuff. Will post after repair.
                  • pocketwatch62
                    • 74
                    • US
                    #149
                    Kinderd1,
                    Did you ever get this set going? I have the same set with the same problem.
                    • nomoresonys
                      • 12330
                      • U.S.
                      #150
                      Not sure if you did the tests in this thread, try test on post #89, report results.
                      • pocketwatch62
                        • 74
                        • US
                        #151
                        nomoresonys,
                        with the main board disconnected the backlights flash for just a split second.
                        I have all the low voltage, But i have only 167DCV on the main filters.
                        • nomoresonys
                          • 12330
                          • U.S.
                          #152
                          So it doesn't go above 167 when you hit power, should go to around 400 when you hit power, could be problem in pfc circuit.
                          • nomoresonys
                            • 12330
                            • U.S.
                            #153
                            Try heating the powerboard with a hairdryer small section at a time heat all the capacitors optos etc. see if tv comes on or changes any.
                            • nomoresonys
                              • 12330
                              • U.S.
                              #154
                              Test connector from mainboard to powerboard on powerboard side with all boards hooked up, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description/name and condition both off and when you hit power on.
                              • nomoresonys
                                • 12330
                                • U.S.
                                #155
                                Did you check all your diodes?
                                • nomoresonys
                                  • 12330
                                  • U.S.
                                  #156
                                  Look closely at CP804, any bulging or anything?
                                  • nomoresonys
                                    • 12330
                                    • U.S.
                                    #157
                                    Maybe try unplug inverter/s from powerboard, see if your filter caps come up to proper voltage. (best practice is always unplug tv from outlet before unplug any cables etc. then plug tv back in outlet and try it)
                                    • nomoresonys
                                      • 12330
                                      • U.S.
                                      #158
                                      As always, BE VERY CAREFUL when working on HOT/DEADLY side of powerboard lots of high voltage and the inverters can have more than 1000 volts coming out.
                                        Originally posted by pocketwatch62
                                        Kinderd1,
                                        Please report what Voltages you have on the power supply connector's pins that goes to the Main board, put down pin number and follow by pin name and the Voltage reading when TV is plug in and when power switch is activated, that will be a starting point.
                                        Also provide good clear pictures of YOUR boards.
                                        • pocketwatch62
                                          • 74
                                          • US
                                          #160
                                          nomoresonys,
                                          The main filters comes up to 415 DCV for a split second the settles down to 159 DCV.
                                          CP804 looks good but i know that don't mean nothing.
                                          Do i need to remove it and check it?
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Nicktronic
                                            Samsung Power Supply Board BN44-00874F
                                            by Nicktronic
                                            Hey everyone,
                                            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                            Anybody...
                                            03-17-2025, 06:20 AM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • repair-it
                                            Need advice testing a samsung power supply board with scope
                                            by repair-it
                                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                            07-12-2025, 11:00 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
