Need help with Samsung LN40E550f7f
  • nomoresonys
    • 12276
    • U.S.
    #221
    Re: Need help with Samsung LN40E550f7f
    Highjack?? kindreds last post was 3-1-2018, said he wold post back but never did, he/she just left it hanging.
    • pocketwatch62
      • 74
      • US
      #222
      Thanks Guys very much.
      I'll order the kit and post the results.
        Verify the kit to make sure the parts numbers of the parts matched what you have. I would replace just the PFC IC first instead of installing everything in the kit.
        • nomoresonys
          • 12276
          • U.S.
          #224
          It's correct, I triple check most everything I post.
          • R_J
            • Jun 2012
            • 9588
            It just makes things easier when trying to help someone if they start there own post.
            • nomoresonys
              • 12276
              • U.S.
              #226
              I might be a little less confusing but do we really need hundreds of threads about the same tv with the same problem?
              • nomoresonys
                • 12276
                • U.S.
                #227
                should have typed It might be.
                • pocketwatch62
                  • 74
                  • US
                  #228
                  Hey Guys,
                  Thanks so much for your expert help.
                  Got the parts today and changed ICP801 (FAN7930B)
                  Solved the problem.
                  Plays beautifully now.
                  Thanks again.
                  • R_J
                    • Jun 2012
                    • 9588
                    Thats good to here it's fixed,
                    So it seems to be if the PFC boosted voltage measures too high (~430vdc), it is a good chance the FAN7930B is defective even though it is boosting the voltage. Likely one of the input opamps is bad.
                    • nomoresonys
                      • 12276
                      • U.S.
                      #230
                      Nice.
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • Nicktronic
                        Samsung Power Supply Board BN44-00874F
                        by Nicktronic
                        Hey everyone,
                        This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                        Anybody...
                        03-17-2025, 06:20 AM
                        After all of...
                        07-13-2024, 08:14 PM
                      • repair-it
                        Need advice testing a samsung power supply board with scope
                        by repair-it
                        I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                        07-12-2025, 11:00 AM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
