Need help with Samsung LN40E550f7f
  • Kindred1
    • Feb 2018
    • 55
    Hello all. Currently trying to fix my nieces tv. Has no video. She did her own research and did the flashlight test. then ordered a replacement inverter. I installed it, however it did not fix the problem. There are no swollen caps. I suspicion the power supply board, but I need a schematic or other assistance in testing. Yes, I have a multimeter and a usb oscilloscope however, I don't know how to use the oscilloscope yet. Have searched and searched for service manuals, schematics, etc. to no avail. The power supply board is a BN44004400B. Thanks!
  • CapLeaker
    Leaking Member
    • 8000
    Re: Need help with Samsung LN40E550f7f
    pretty smart niece to figure that out it could be the inverter board. However for your board is a PSU repair kit at SJ available that fixes: The Samsung BN44-00440B Power Supply Component Repair Kit includes all necessary components to repair common failures on the Power Supply. Symptoms include will not turn on, no backlights, missing 5V standby or PFC.
    http://www.shopjimmy.com/samsung-bn4...repair-kit.htm
      So what Voltages do you have on the connector of the power supply board that goes to the main board when TV is in standby and when power switch is activated?
      You MUST report the pin name and follow by the Voltage reading for each pin so we can see if they are correct or not.
      We also need good clear the pictures of YOUR whole power supply board.
        • 12086
        • U.S.
        Exercise caution when testing power supply board, it can be deadly. there are legends like little maps on the power supply board that tell you what voltages to expect from the connector pins, put negative lead on ground like the chassis for example, also check those 2 fuses if you haven't, I check those fuses with tv off and unplugged. The voltages have to be checked with tv on or plugged in of course.
        • Kindred1
          • Feb 2018
          • 55
          Thank you for the input. I will consider that option if it turns out to be the problem.
          • Kindred1
            • Feb 2018
            • 55
            Voltages are as follows both on the power supply as well as the lead in to the logic board:
            Power supply:
            Pin 1=5.17
            2= 5.17
            4= 12.78
            5.=12.78
            6.=12.78
            7.=12.78
            At Logic Board= same
            Lead to inverter:
            pin 10= 12.07
            pin 2= 12.76
            At Inverter: Same
            Any not listed had value of 0.
            • Kindred1
              • Feb 2018
              • 55
              Thank you for the warning. I actually have done a lot of computer work and 3 t.v.'s so far. I learned my lesson on things holding a charge years ago.
              I found the voltages on the board. - Not easy to read!
              • CapLeaker
                Leaking Member
                • 8000
                If you do post voltages and pin numbers, you have to include the pin out name. Your pictures are way too small in order to see anything like that what we need. You need to upload high resolution pictures, so we can see the details.
                  1) No pin names to tell us what each pins are.
                  2) There are 14 pins on that power supply connector that goes to the main board but you only report 7 of them and without the pin names as requested then those reported numbers are just about meaningless.
                  3) Samsung BN44-00440B power supply board?
                  4) You need to follow the instructions.
                    • 12086
                    • U.S.
                    Cool, just a stock warning, cuz there's no way of telling a posters knowledge depth.
                      • 12086
                      • U.S.
                      Don't give up, what I do is just copy the legend/map on a piece of paper, pins and description, like bl-on etc, then just type it back in here with the voltage you got next to it.
                        • 12086
                        • U.S.
                        http://www.shopjimmy.com/samsung-bn4...upply-unit.htm is this your power board? you may have gotten a bad tcon board, hard to tell, I see shopjimmy has 1 for 10 bux. oops my bad you said inverter not tcon.
                          • 12086
                          • U.S.
                          Does this tv have a metal back cover? if so are there any burn looking marks on it, like where the power board is etc. just worked on a sammy ln40c650, you can check my thread if you care to, but take your time, I double and triple checked everything before proceeding, you may have a whole different issue of course.
                            • 12086
                            • U.S.
                            Maybe start with those 2 big 450v filter capacitors, check m with black lead on negative side and red lead on positive side right on the legs, should get around 160 in standby and 380 volts while tv is on.
                            • Kindred1
                              • Feb 2018
                              • 55
                              I see now what you guys are talking about in regards to pin names. Will upload along with new pics.
                                • 12086
                                • U.S.
                                Cool, lets give it our best shot.
                                • Kindred1
                                  • Feb 2018
                                  • 55
                                  psb:
                                  1. B13V -13.1V
                                  2. DIM- 5V
                                  3. B13V-13.1V
                                  4. NC -0V
                                  5. B13V- 13.1V
                                  6.BLU_ON -0V
                                  7. B13V-13.1V
                                  8., 9., 10 GND- 0V
                                  11.B5V- 5.1V
                                  12 A5V - 5.1V
                                  13. B5V- 5.1V
                                  14. PS_ON- 3V
                                  • Kindred1
                                    • Feb 2018
                                    • 55
                                    Here's a better one.
                                    • Kindred1
                                      • Feb 2018
                                      • 55
                                      No scorch marks. 450v caps read 375v. Everyone is talking about standby mode; on this t.v. , when is off, the indicator light stays red and I have no readings. If I turn it on, it chimes, the light flashes and then goes off. After several minutes, it shuts off.
                                        • 12086
                                        • U.S.
                                        Don't have a schematic, not sure if this one will do it, try unplug power supply board from main board, see if backlights go on.
                                        • Nicktronic
                                          Samsung Power Supply Board BN44-00874F
                                          by Nicktronic
                                          Hey everyone,
                                          This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                          Anybody...
                                          03-17-2025, 06:20 AM
                                          by sam_sam_sam
                                          After all of...
                                          07-13-2024, 08:14 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
