Actually I did have a few 27uf @ 50 volts but they were in a container that is odd values or low voltage capacitors that I mainly use for 5 volt switching power supplies I did not even think about looking in this container because I was looking for some 3300uf @ 35 volt I have some but they are not brand name ones for this switching power supply but I am not going to change them because of the quality of these boards and that I had to do a repair job in four places
To date I have not figured out what the substance was. Almost like dried up FluidFilm. Weird. I also can't figure out why this “coating” was just in the power supply, And it was sucked in from the front. The 2 radios inside were clean as a whistle. If someone would have sprayed it from the front, it would have been all over the place inside.
so this would really limit things.
I did figure out the playing dead problem. It was the bigger ribbon cable that is between the TX radio and the front LED board. The ribbon cable chaffed down to the Ethernet cable that goes between the board on the front and a temperature control board on the back.
Sorry sam_sam_sam I totally hijacked your thread.
I would not worry about that because I have been interested in your off topic about my endeavors about my Panasonic switching power supply that the circuit boards are crap and how you are trying to resolve your own issues with your experience with the substance in your switching power supply so it is not completely off topicSorry sam_sam_sam I totally hijacked your thread.
By that reasoning though, the original 27uF caps would never have been +20% either.
So the circuit may well be unstable with something that much higher"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
In post # 9 I showed one side of the board but I am not going to remove it again because of how poor the soldering joint traces because I plan on reusing it for a project that I want to complete I am going to replace the output capacitors I just have not got to this part of the recapping process of this board yet
If I can take a better picture of this board I will post itComment
I think today they can manufacture electrolytic capacitors within a few % tolerance. It's not the 1950's anymore for the -20%/+80% number, and its +/-20% nowadays still a 40% wide window.
Many larger caps I've bought are at basically at -18% lol. An old cap is 82uF 450V, the new one measures ~70uF (happened several times) so I end up upsizing and buying 100uF to get 85uF. This is Chemicon and Nichicon. Why would you give the customer more than what the spec is
Smaller caps seem to be closer tolerance to rated value, so a 27uF would be very close to that.
Wild guess this is a half-bridge SMPS and the 27uF is part of the driver circuit, like in PC power supplies.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by sam_sam_samI was working on this CNC machine today found no keyboard functioning no control relay powering on
The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
Found shorted diodes on main controller relays there are 3 of them that... -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... - Loading...
