Need help with Samsung LN40E550f7f
  • Kindred1
    • Feb 2018
    • 55
    Re: Need help with Samsung LN40E550f7f
    317 in standby, 364 turned on.
    • Kindred1
      • Feb 2018
      • 55
      *correction* 371 in standby
      • nomoresonys
        • 12331
        • U.S.
        #103
        Ok, I'm not positive but it looks like per post 95, if the proper voltage isn't there on powersupply with inverter unplugged from it, then the problems on the powersupply?
        • nomoresonys
          • 12331
          • U.S.
          #104
          The standby seems quite high and the 364 seems a little low.
          • nomoresonys
            • 12331
            • U.S.
            #105
            Ok then something is wrong, they are usually around 160 standby and 380 while on. I dont know what causes that but someone does I bet.
            • Kindred1
              • Feb 2018
              • 55
              Thanks for all your input.
              • nomoresonys
                • 12331
                • U.S.
                #107
                I guess you could test your bridge rectifier.
                • nomoresonys
                  • 12331
                  • U.S.
                  #108
                  http://www.shopjimmy.com/samsung-bn4...upply-unit.htm if you click the image it will magnify.
                  I believe the bridge rectifier is BD801S.
                  • nomoresonys
                    • 12331
                    • U.S.
                    #109
                    https://www.youtube.com/watch?v=zK8oNhFaRdM testing bridge rectifier.
                    • nomoresonys
                      • 12331
                      • U.S.
                      #110
                      I always watch the videos, its very true that a pic. or video is worth a thousand words.
                      • Kindred1
                        • Feb 2018
                        • 55
                        Lol, I just watched the same video before checking this. Diode mode isn't working on my meter, but I followed a tutorial and tested the ac and dc and it seems fine. 123 a/c 169 dc
                        • nomoresonys
                          • 12331
                          • U.S.
                          #112
                          Ok cool, I guess the thing to do is keep tracing it out, til you find the bad component, if there is one.
                          • nomoresonys
                            • 12331
                            • U.S.
                            #113
                            Check will62's post a little bit ago, he helped fix one with a factory reset. It was a panasonic but it had some symptoms like it could have been a bad board or such.
                            • nomoresonys
                              • 12331
                              • U.S.
                              #114
                              Did you try a factory reset on this one?
                                or *correction* 371 in standby
                                That is not right, in standby the PFC Voltage boost converter is off so the Voltage measured between the two legs of the main filter cap should be around 160VDC, when PS-ON is present then it should be around 380VDC in typical Samsung and most TV that has active PFC circuit.
                                Please retest the Voltage between the two legs of the cap again.
                                • nomoresonys
                                  • 12331
                                  • U.S.
                                  #116
                                  https://www.youtube.com/watch?v=bK0qFueHopw be very careful, I would only do the reset, like he does and not change anything in there but if you cant see the menu then probably cant do it.
                                  • Kindred1
                                    • Feb 2018
                                    • 55
                                    Well, from what I can see, there are no options in the diagnosis screen and I don't have the remote.
                                    • Kindred1
                                      • Feb 2018
                                      • 55
                                      Ok,changed out my leads on my meter. Measured again. 165.0vdc off and 169.2
                                      on. both caps. cp802 and cp803
                                      • R_J
                                        • Jun 2012
                                        • 9624
                                        never mind
                                          Is the ON = 169.2V reading with PS-ON present? If PS-ON present then we have problem with the PFC circuit. But I thought you have 365V on the fuse next to the filter cap before in the earlier thread, that must have been an error then.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Nicktronic
                                            Samsung Power Supply Board BN44-00874F
                                            by Nicktronic
                                            Hey everyone,
                                            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                            Anybody...
                                            03-17-2025, 06:20 AM
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • repair-it
                                            Need advice testing a samsung power supply board with scope
                                            by repair-it
                                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                            07-12-2025, 11:00 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
