Need help with Samsung LN40E550f7f
Re: Need help with Samsung LN40E550f7f
You have (-) symbol in front of the reading, is that right?
If the Red probe is on the VCC pin 8 and the black probe is on GND pin 6 then it should not show as Negative reading on your meter, Please verify.
The minimum start up Voltage for this PFC IC is 12VDC (+/-1V).Never stop learning
That means the IC is getting the VCC to run so at this point I would get a couple ICs (buy more than one so you have spare in case it gets damaged during the soldering works) and replace it.
Line #5 (cut tape) on that Digikey will work.Never stop learning
Not sure if you did the tests in this thread, try test on post #89, report results.Comment
nomoresonys,
with the main board disconnected the backlights flash for just a split second.
I have all the low voltage, But i have only 167DCV on the main filters.Comment
So it doesn't go above 167 when you hit power, should go to around 400 when you hit power, could be problem in pfc circuit.Comment
Try heating the powerboard with a hairdryer small section at a time heat all the capacitors optos etc. see if tv comes on or changes any.Comment
Test connector from mainboard to powerboard on powerboard side with all boards hooked up, test with tv plugged in but off then hit power, report both conditions here, give pin number, pin description/name and condition both off and when you hit power on.Comment
Maybe try unplug inverter/s from powerboard, see if your filter caps come up to proper voltage. (best practice is always unplug tv from outlet before unplug any cables etc. then plug tv back in outlet and try it)Comment
As always, BE VERY CAREFUL when working on HOT/DEADLY side of powerboard lots of high voltage and the inverters can have more than 1000 volts coming out.Comment
Also provide good clear pictures of YOUR boards.Never stop learning
nomoresonys,
The main filters comes up to 415 DCV for a split second the settles down to 159 DCV.
CP804 looks good but i know that don't mean nothing.
Do i need to remove it and check it?Comment
Assuming...7 Photos -
by NicktronicHey everyone,
This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
Anybody... -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
The models launched in 2018 and 2019 respectively.... - Loading...
