Philips 37PF7321/98 cannot turn on
  • john_doe
    • Apr 2013
    • 192
    • Malaysia
    #141
    Re: Philips 37PF7321/98 cannot turn on
    Originally posted by john_doe
    What is happening???
    I jump a ground to Gate and now the Gate is 20v and Yellow S(source) is 5v.
    And the pin 3 of 1305 is 0v.
    When I power off and on the tv, the led light on the front panel is green and stay green. Before this, the led is green and after about 2 sec will turn red.
    Just to be sure, I have remove the ground to G. And the voltage of the Gate is still 20v and the Source is still 5v.
    How is this possible?
    • john_doe
      • Apr 2013
      • 192
      • Malaysia
      #142
      This is driving me nuts!
      Now when I power up the tv, the front panel LED light is off. I press the power button and the LED turned green. The tv screen also lighted up! I swear I didn't do anything.
      Am I seeing things? I better go and sleep.
      • selldoor
        Slow Learner
        • 7870
        #143
        Great stuff - hope it lasts - I dont know if its possible to unstick a stuck transistor- maybe?
        If it doesnt come on again try heating that section of the board with a hairdryer maybe
        getting some voltage through heated something up making it work.
          Darn, 143 posts and the TV start functioning by itself.
          • bammbammfran
            • Apr 2014
            • 476
            looks like we found part of the issue
            now if you do that with the 3 pin wire connected to the power supply, the relay might just kick on
            • bammbammfran
              • Apr 2014
              • 476
              you charged the transistor and it activated . I THINK !
              • bammbammfran
                • Apr 2014
                • 476
                IT IS SAYING, Stop poking me !!
                • john_doe
                  • Apr 2013
                  • 192
                  • Malaysia
                  #148
                  I just check with the 3 pin plug 1305 connected. The Gate is 20v and the Source is 5v. Pin 1 and 2 of 1305 are 5v. Pin 3 is 0v.
                  When I power up the TV, no front panel LED light. Press the power on button and the LED light turn green and stay green. Screen on TV also lighted up.
                    • 31194
                    more likely it has a slight leak and is feeding back into the gate./base
                    • john_doe
                      • Apr 2013
                      • 192
                      • Malaysia
                      #150
                      Now the TV screen is not lighted. Voltages at mosfet 7531 and 3 pin plug 1305 no change.
                      TV is unstable.
                      • bammbammfran
                        • Apr 2014
                        • 476
                        so that 20-20 and 5 are still at the transistor even when you power it off with the power button ?
                        To me that 20volts does not sound right
                        Also do you hear the relay click off when powering it off ?
                        • john_doe
                          • Apr 2013
                          • 192
                          • Malaysia
                          #152
                          When I first turn on the main without pressing the power on button, there is 20v and 5v and Gate and Source respectively but no green LED light on front panel.
                          When I press the power on button, green LED turn on. 20v and 5v still on.
                          Did not hear the relay click when pressing the power on button on and off. Only hear relay click when turn off main power.
                          • bammbammfran
                            • Apr 2014
                            • 476
                            unplug the 11 pin wire on the standby board, then remove the number 7 wire from the plug
                            (you have to slightly lift the clip on the side of the plug with a pointy object and pull the wire out)
                            then power up
                            now check the voltages on the board that we were checking at the transistor and 1305
                            and do a separate check on the wire and the pin that we just removed
                            • john_doe
                              • Apr 2013
                              • 192
                              • Malaysia
                              #154
                              then power up
                              When pin 7 removed, 20v and 5v still there. 1305 Pin 1 and 2 are 5v. Pin 3 is 0v.
                              11 pin wire:
                              Pin 4 is 12v
                              Pin 5 is 5v
                              Pin 7 is 5v
                              Pin 9 is 12v
                              Others are 0v
                              • john_doe
                                • Apr 2013
                                • 192
                                • Malaysia
                                #155
                                Even with main power off, the Gate of 7531 still has voltage, 14v and discharging slowly.
                                • bammbammfran
                                  • Apr 2014
                                  • 476
                                  ok
                                  with all power off and with it sit to discharge a bit
                                  check resistance in both directions from the Drain (yellowD) to the Gate pin (Yellow G)
                                  if zero or close to it, the transistor went bad
                                  going to need to cut a trace to isolate the Gate pin on that mosfet
                                  use an exacto knife or the like and cut out the yellow section at the end of the pink arrow
                                  I am trying to see if the gate is causing the 20 volts or the board itself
                                  Picture attached if I remember this time
                                  • john_doe
                                    • Apr 2013
                                    • 192
                                    • Malaysia
                                    #157
                                    ok
                                    Resistance from Drain to Gate is OL both direction.
                                    7531 is new. Is it really necessary to cut trace? I have never done this.
                                    • bammbammfran
                                      • Apr 2014
                                      • 476
                                      7531 is new ???
                                      when did this get changed ???
                                      yes, you have to cut it since there are no jumpers to remove.
                                      it's an easy redo
                                      • john_doe
                                        • Apr 2013
                                        • 192
                                        • Malaysia
                                        #159
                                        7531 is new ???
                                        it's an easy redo
                                        It was replaced yesterday before our test. I replaced it because I wanted to test it out of circuit and since it is out, I replaced a new one.
                                        Ok, trace is cut.
                                        • bammbammfran
                                          • Apr 2014
                                          • 476
                                          now recheck usual voltages at G D S and at 1305 and also check the pad to the right of the cut
                                          • JorKsX
                                            Philips 47pfl6008s wont turn on
                                            by JorKsX
                                            Hello. Got my hands on Philips 47pfl6008s/12.
                                            Problem is that it does not turn on. Last owner said the problem came slowly.
                                            One day did not respond to remote, had to unplug from AC and then back and it worked. next day had to disconnect 3-4 times before it turned on.
                                            And then it went into hours of unplugging and replugging until it turned on.
                                            When I plug AC into tv, it does not respond to "turn on" button or anything else.
                                            After 10-15minutes the TV starts blinking red LED twice.
                                            So it blinks twice, then waits 3 seconds, then again twice...
                                            02-13-2022, 03:36 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • ovrax
                                            Philips 55PUS6804/12 turn on & off (probably backlight issue)
                                            by ovrax
                                            First of all, please excuse me as I'm quite new to this field.
                                            I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                                            I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                                            The Ambilight works perfectly and stays on.
                                            No sounds.
                                            Thanks in advance.
                                            08-25-2024, 04:33 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • robante15
                                            Acer Aspire 4520 won't turn on after reboot
                                            by robante15
                                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                            If I remove the...
                                            04-06-2024, 06:50 PM
