This topic is closed.
This is a sticky topic.
    If you do that it will help us a lot, it is not easy trying to troubleshooting without having the units or the boards in front of us to look at, it is the least you can do for us that are trying to help.
    Also look at the pictures you take, if you cannot see the object clearly, we cannot see it clearly either. I have to draw up the diagram based on your pictures when we do not have the service manuals for what we are trying to fix.
    I am getting tire of asking for pictures so I skip those posts without pictures.
    Here is a link to our FAQ explaining how to upload pictures incase you need it: https://www.badcaps.net/forum/showthread.php?t=1868
    Last edited by Per Hansson; 08-19-2014, 12:23 PM. Reason: Added FAQ link & stickied thread
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Please upload pictures using attachment function when ask for help on the repair
    I second and third that !
    Cant understand why when people can see what we keep asking for so few
    bother to put together a decent request for help.
    Perhaps we need to have some minimum requirements on a sticky we can just
    post as a link in reply to an inadequate request.
    I used to post this but gave up.
    Welcome to the forum-
    We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back (in the same orientation) and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
    Examples of what is needed
    https://www.badcaps.net/forum/attach...7&d=1280167246
    https://www.badcaps.net/forum/attach...6&d=1280167246
    https://www.badcaps.net/forum/attach...4&d=1280167246
    It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      Sticky?
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • retiredcaps
        • Apr 2010
        • 9271
        Hmm, no animated gif for :standing-on-chair-clapping:
        Although I no longer participate in certain sub-sections of these forums, sometimes I lurk and despite providing numerous well written easy-to-understand examples, tips, guides, it still amazes me that people asking for free help to solve their problems still can't or won't do the simple basics.
        I suggest putting this thread into your signature link as well.
        --- begin sig file ---
        --- end sig file ---
        • retiredcaps
          • Apr 2010
          • 9271
          All handheld shot with, my now 10+ year old and still going strong after 30K+ pictures, Canon A80.
          Macro and sunlight are required.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Are you questioning what a sticky is or the idea of using one for this purpose?
            I think it's an ok idea to set a sticky post devoted to how to ask for help here. Some people (especially newbies, no offense to newbies, it just takes time to learn how things work here) need it drummed into their heads so another drum probably couldn't hurt.
            • selldoor
              Slow Learner
              • Dec 2010
              • 7870
              Originally posted by martino
              Sticky?
              Not sure if your having me on
              Well maybe stickie in US?
              Sticky is just a thread that is always available at the top of a forum.
              On the tv section there are 4 - you can apply to a mod to have any good
              useful to all thread stuck ( pinned - hence the blue tack symbol) to the top of a forum.
              On the Monitor thread is retiredcaps' 2 second to black guide.
              so it is easy to refer people to it.
              @ retiredcaps - my dittie above is mostly copied from yours. I was thinking the 2mb could be increased to 3mb as even cheaper cameras start off there.
              and the jpg up;load is now said to be 4mb not that I have tried it.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Thread stickied, also edited OP with link to FAQ on uploading pictures.
                  Thanks!
                    What can be done with good pictures:
                    https://www.badcaps.net/forum/showpo...9&postcount=12
                    https://www.badcaps.net/forum/showthread.php?t=41310
                      Another example:
                      https://www.badcaps.net/forum/showpo...5&postcount=35
                        Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
                        by sam_sam_sam
                        This is a new item at Electronic GoldMine that has arrived within the last few weeks
                        Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
                        Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
                        https://theelectronicgoldmine.com/products/g28392
                        One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
                        11-24-2024, 01:25 AM
                      • Salvador Pérez
                        Help identifying the function of these two coils - MSI Delta 15 (MS-15CK1)
                        by Salvador Pérez
                        Hello everyone, I'm troubleshooting an MSI Delta 15 (MS-15CK1) motherboard, and I need help identifying the function of the two coils marked in the attached image. The laptop powers on and responds to the keyboard, but the screen does not turn on-neither the LCD nor the backlight. I've checked the main power rails, and all other coils seem to have the expected voltages:
                        • 0.91V for the GPU
                        • 1.7V for VRAM
                        • 3.3V and 5V rails 1.8V for the BIOS
                        • 0.9V for the CPU and iGPU 1.2V for the RAM
                        However, these two coils are not showing any voltage....
                        03-10-2025, 11:50 AM
                      • bohaboha
                        Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
                        by bohaboha
                        Hi it looks like everything works don't know where to test except the 390v in the 2 capacitor in the hot side of the power supply and the weird 180v in the diodes in the cold side that should be discharged it is writin on the circuit no more you can read what is written on the circuit quite srrange color mixiing yellow and white
                        anyhow i couldn't t read anything else
                        the backlight is on strong and the screen does not get dark or very dark but no pictures
                        the mainborad feels a bit hott on the black part i test it to 52 degree's against 34 to 40 on the rest of it
                        01-02-2025, 08:04 PM
                      • valvashon
                        LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                        by valvashon
                        The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                        Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                        11-24-2024, 12:08 PM
                      • viewerau
                        AVerMedia Ezrecorder ER310
                        by viewerau
                        I do hope I have posted this in the correct area, as it is a video related device?
                        The above item has reached end of life, with the manufacturer not supporting this any longer
                        My unit has stopped, in that it will start up, however, it will not respond to the remote control.
                        My remote seems to work ok, as I can see it emitting a red led when I use a mobile camera to check it....just to be sure, I also have a Harmony remote 300 that I was able to download the codes onto, and it's behaviour is the same.
                        Previously, pressing the remote invoked a...
                        11-08-2025, 12:25 AM
