Philips 55PUS6804/12 turn on & off (probably backlight issue)
  • ovrax
    • Nov 2023
    • 17
    • Belgium
    • New technology, development...
    First of all, please excuse me as I'm quite new to this field.
    I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
    I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
    The Ambilight works perfectly and stays on.
    No sounds.
    Thanks in advance.
  • nomoresonys
    • 12370
    • U.S.
    You're probably on the right track, a backlight flash then nothing is a classic symptom of bad led/s.
    • nomoresonys
      • 12370
      • U.S.
      Here's a similar model, MUST be careful panel looks like its glued or taped down, VERY easy to break unless caution is taken, slow and gentle, good idea to do everything you can to verify on this one. Read the comments, they mention how it's best to replace ALL strips: https://www.youtube.com/watch?v=-Qfd-xikbzw
      • nomoresonys
        • 12370
        • U.S.
        I'm not sure on this model if there should be something on screen when a backlight led is bad but you can try it, shine a flashlight on the screen see if you can detect any text or anything hit menu to see if you detect anything, if you see something that's more evidence that it's probably bad led/s.
        • Diah
          • Feb 2013
          • 6735
          you need to measure first PS_ON on the PSU socket if it remain on >3V or go down.. in case go down TV didn't complete boot.. in other words reboot.issue
          • ovrax
            • Nov 2023
            • 17
            • Belgium
            Thank you all for your messages.
            I've ordered the LEDs, I'll proceed with the operation as soon as I receive them and will keep you updated here.​
            • Cornito
              Thomson 50UD6306 (TCL) Backlight Issue, starts then stops, led changed
              by Cornito
              Hello Team,
              I'm back with another backlight issue that I thought was simple, but it turned out to be more complex than expected.
              Let me provide a brief history: The TV was working well, then one day, the backlight started and shut down. I thought I had an LED issue leading to this behavior, so I replaced the LEDs with brand new ones. However, the issue remains the same.
              Next, I replaced the electrolytic capacitors attached to the LED power supply, but the results were the same. I then replaced the driver, a OB3365RP, and did it twice due to the same result....
              08-08-2024, 08:09 AM
            • cheebster
              iPad Pro 12.9 5th Gen Backlight Issue
              by cheebster
              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
              Anyone...
              05-20-2025, 09:17 AM
            • Acnologia
              Lenovo Thinkpad T540P - Showing at 14" inch but NOT at 15.6" inch (Backlight issue) ?
              by Acnologia
              Hello to all members of badcaps.
              Another brainstorming that i have been messing with for months as a side project.
              Bought a T540p , from eBay as 'doesn't display' ,so i thought it was either backlight fuse, or screen issue etc.
              I got it in my hands, first thing, the machine works fine boots to windows , in external screen all diagnostic are good.
              Step 1.
              Change screen (FAT - LED ) 1366x768 to 2nd one, that i know 1000% that is working ,as it has been tested.
              Machine > Doesn't give display it's really dim.
              Step 2.
              Use the same...
              11-05-2025, 04:02 AM
            • DoOm86
              philips 55pft5500/12 Backlight issue. What am I doing wrong?
              by DoOm86
              TV philips 55'' no backlight (image ok).
              I tested the backlight with my led tester from the unplugged connector cable and it lights up. I had voltages at the motherboard connector, but anyway I order a new psu. Same problem, same voltages. Disassembled the TV and checked every strip with my led tester, they all light up, same voltage for every pair of strip (they go two by two).
              What am I missing?
              And something else I don't understand. I checked and I have 3v Leds, 10 per strips. Why every pair of strip (so 20 Led) take about 32v when powered up with my led tester 🤔
              04-16-2024, 03:47 PM
            • Cornito
              TCL 65C715 backlight issue
              by Cornito
              Hello team,
              I'm back with another topic.
              It's a 65C715 TCL tv with backlight issue.
              But the problem is a bit strange.
              When I took this tv from the marketplace backlight didn't work but picture was ok.
              Back at home I checked with led tester if led are alive and I can find something different in term of voltage supply => nothing
              Putting all back together the tv worked fine for weeks. => Contact issue??
              Few moment later the tv has started to have backlight issue back, turning off and on worked sometimes and tv was working....
              06-09-2024, 02:24 AM
