the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
Re: the gutless, bloated, and fried power supply hall of shame
From the build qulaity pictorial. One of the worst ATX PSU's I have seen in a while.TMP-ANS LC-A350ATX
The good thing about this power supply is...... that it is not going to power a computer anymore
Not worth of anything!
It reminds me of those power supplies:
https://www.badcaps.net/forum/showth...ier#post114292
https://www.badcaps.net/forum/showth...ier#post199701
I love how they dated the warranty from the time of manufacure (not the time of purchase). FAIL.sigpic
(Insert witty quote here)Comment
It's quite fun to drop a ton of bricks on top of these. They usually work better afterwards.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, bios, schematic, boardview (board view), datasheet, cad - use our search.
Subscribe to support us. It only takes 1 minute: https://www.badcaps.net/settings/subscriptionsComment
Another cheap Sun Pro. At lest thios one does use DC-DC conversion from the 5V rail to generate the 3.3V. However, it still never managed more than about 73% efficiency on 230V at about 250W Load. I doubt it would even manage 70% in the US. At 350W, the efficiency was about 68% and it exploded after a few minutes.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
How is this for gutless and fried?
https://www.badcaps.net/forum/attach...1&d=1334112631
Okay, I'll come clean - the PSU didn't come that stripped down (obviously
). This used to power my family's 400MHz Pentium II PC back in 1999-2001. The model number on the label will fool you that this in an L&C, but it's not (most likely J&C just labeled it as such). It actually used to look exactly like these (save for the different cap brands on mine)
https://www.badcaps.net/forum/showth...ighlight=m-tec
https://www.badcaps.net/forum/showthread.php?t=1178 (see post #1)
Seems to go also by the names of M-tec, Meico, and Frontier.
As you can see, even without me removing the components, it's a very crappy power supply. Fortunately, it was pretty good desoldering practice for me a few years back. Also, the components I took out of it helped me save a 17" CRT monitor, a 250W HiPro PSU, and a few other things. Will soon be using one of the schottky diodes from it to make the 12V rail of a 250W Bestec 12Z a little beefier.Comment
http://www.eevblog.com/forum/product...-modification/
I don't see how that AC adapter was supposed to work without filter caps.Comment
Haha, must have a lot of 60hz hum on the output! (when its working-if it even does work at all :P)http://www.eevblog.com/forum/product...-modification/
Its so cheap that it doesn't even work for a millisecond xD
Note the fake certification labels!
Look at the comments for this product!
http://www.amazon.com/Apple-iPhone-T...pr_product_top
LOL at one of the comments, the person said it almost caught fire, and it made their phone go whacky, probably from loads of AC hum on the output.
-Ben
EDIT:
another fried PS picture!
http://www.magicbluesmoke.org/309/in...s-nv-psu-failsLast edited by ben7; 04-21-2012, 09:23 AM.Muh-soggy-kneeComment
umm, it did. there are 2 tiny lytics.http://www.eevblog.com/forum/product...-modification/
also, it might be a half bridge cemter tapped rectifier, which would produce 100hz of noise (based on the plug, looks to be a 250V 50HZ connector). The picture is too fuzzy to tell.
There still would be lots of noise, as those caps are probably too tiny for the job.sigpic
It looks like the cap on the lower left corner next to the USB connector is a filter cap, but the other cap is part of the oscillator. That looks like the single transistor oscillator that is used in most cheap adapters, but the power just goes through a single diode before going into the oscillator without a filter cap or current limiting resistor.Comment
Oh my... How did I miss this. The famous "Mrs. Varga and Co." psu. I just gutted one today to get the fuse and mag-amp choke.How is this for gutless and fried?
That is actually a very interesting PCB. It is designed for both AT and ATX - i have both versions. All i can say it's a big mess of a PCB. The input diodes are 2A, no room for a bridge rectifier. You can't fit any input caps larger than 330u due to can size. And there's no input filtering whatsoever, not even the room for it. Crazy.A working TV? How boring!Originally posted by PeteS in CARemember that by the time consequences of a short-sighted decision are experienced, the idiot who made the bad decision may have already been promoted or moved on to a better job at another company.Comment
BRACE YOURSELVES, you may cry at how bad this PSU is..
Too lazy to label the popped caps but I'm sure you can spot them. All it was powering was an Athlon 64 x2 and a 6800GS. Efficiency = 64% Canicon caps (kill me now)Comment
The heatsinks don't seem too bad though, and there are actually inductors in the output not just wire links - also it has a bridge rectifier. It's lame but it could be worse."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
Makes me wonder what software they used for the top-side printing - it looks horrible. MS Paint maybe?
The MOSFET and 431 shunt regulator are also pretty useful. I was prototyping a circuit yesterday and needed some odd resistor values. Found most of them in the bag where I have the parts from that PSU.Originally posted by pdavidI just gutted one today to get the fuse and mag-amp choke.
The heat sinks aren't too bad either, especially the secondary one. Might use it in the headphone amp I'm going to build (0.o).
Funny how I find this PSU much more useful for the parts than if it was actually working and in one piece.Comment
Delta Electronics power supply and control board from a Belinea 1925 S1W screen I found in the recycling center electronics section this afternoon :
Main cap is Nichicon, ALL the bloated caps are CapXon. The screen is not even five years old according to the PCB build dates :/ Really bad caps.
Replaced them all with with what I had on hand (including Fujyuu and other sh**) but mostly for test purposes, the screen works fine but makes an annoying buzzing sound. It's kinda weird since I replaced the two CapXon GL105°C on the power supply board with the exact same CapXon GL from another PSU, with the same ratings, but a bit older. I guess I should buy some new caps for this one.Last edited by SuperDuty; 04-30-2012, 03:31 PM.Comment
Comparison of a two PSUs :
On the left, a 145W AT (not sure, it has AT connectors but no switch like most AT PSUs) Astec power supply, from 1997, high quality components and very clean PCB.
On the right, the infamous Heden PSX-A330U, supposedly 480W...problem ? U mad ?
I got it in a case I bought in 2004 or 2005. I used this power supply with an Althon XP2200+, a K7S8X motherboard and a Radeon 9600 Pro for about five years with no problem. No filter, no PFC, a lot of missing components. I've stripped it and threw the rest to the trash.
This is a famous french article explaining in details about how bad power supplies from this brand are : http://www.x86-secret.com/dossier-36...on_Noname.html
Two weeks ago I decided to have a look at my computer power supplies. I had about 20 of them...I have about 10 left, I even found a DEER power supply ! It will be recycled soon.Comment
Heh, the lone Rubycon and Nichicon are fine -> but the rest are CrapXon so they bulge like anything else! I have replaced so many bulged CapXon they are down their with Fuhhhjyuuuuuu.Delta Electronics power supply and control board from a Belinea 1925 S1W screen I found in the recycling center electronics section this afternoon :
Replaced them all with with what I had on hand (including Fujyuu and other sh**) but mostly for test purposes, the screen works fine but makes an annoying buzzing sound. It's kinda weird since I replaced the two CapXon GL105°C on the power supply board with the exact same CapXon GL from another PSU, with the same ratings, but a bit older. I guess I should buy some new caps for this one.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
by bauto601Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
A "nice" YoungYear unit? - Badcaps
The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish.... -
by mitchwI am repairing a HP Victus 16 with black screen, blinking screen, etc. Quick googling provided me the answer that the lid detect hall sensor is the issue. Confirmed with disconnecting the IR board (that contains also the hall effect sensor). Laptop itself is just over a year old, but out of warranty.
Apparently the sensor itself is a TCS40DLR, which fails after just months of use at elevated temperatures.
Now which one is the best to replace with?
Some suggested A1126LLHLT-T, but they had to modify the power supply to supply the 3.3V instead of 1.8V, as the sensor wasn't... -
by eccerr0rIntroducing... the POS-124Z which really is a POS:
Yep it's a POS allright.
I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
So I had to take a peek:
EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?... -
by tamerelaputeHi,
I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
Except the cpu, I cant feel anything getting warmer.
I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
I believe that if the cpu was fried,... -
by serwanjaf7hello friends
pls i need help with hp vicuts it have problem on the hall sensor i want to change it bu i dont find and i dont now what is the part no
pls need help
thank you... - Loading...
