the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • mariushm
    • May 2011
    • 3799
    #301
    Re: the gutless, bloated, and fried power supply hall of shame
    It's made by CWT, so it's probably a Neo Power , Smart Power, [type something here] Power
    See http://www.realhardtechx.com/index_archivos/Page673.htm for Antec's models and oems
    • c_hegge
      • Sep 2009
      • 5219
      My guess is an SL350 or SL300 (one of the early StupidPowers)
      • goodpsusearch
        • Oct 2009
        • 2848
        • Greece
        #303
        Antec SmartPower without PFC
        • Behemot
          • 4845
          • CZ
          #304
          Ah, no review anywhere…
          • goodpsusearch
            • Oct 2009
            • 2848
            • Greece
            #305
            NOT BAD, after full recap and fan-mod
            • kuzyatech
              • Sep 2012
              • 13
              Sorry, didn't think anybody would care for a model number. Antec Smart Power SL400. The label is a royal pain to photograph- too many reflections
              www.kuzyatech.com My blog about things I make, break and fix
                They probably blew the budget on the shiny label, instead of making a half decent power supply...
                • c_hegge
                  • Sep 2009
                  • 5219
                  Hahaha so that's how they got away with selling those things at high prices
                  • dmill89
                    • Dec 2011
                    • 2531
                    The sad thing is that they were decent power supplies with the exception of the caps and how the fan controler was set, a few cents in quality caps and a fan controler set to speed up at a lower tep and these could have been some of the most reliable PSUs of their generation but instead they were some of the least reliable.
                    • Pentium4
                      CapXon Be Gone
                      • Sep 2011
                      • 3741
                      Trash. I think when they made it they forgot to print the IT after SH Can't tell who made it but it kinda looks like my old POS Raidmax...Input caps are HEC, the rest are JEE. Surprised to see ANY parts at all for the transient filtering. The PWM controller is made by Fairchild (don't know the model) I threw it straight in the trash. Should I consider salvaging it? There are hardly any caps on the secondary....
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Originally posted by Label
                        High Quality Switching Power Supply
                        It's a Sun Pro.
                        It actually looks to use DC-DC conversion on the 3.3V rail, and the heat sinks look thick enough. Might be a keeper if you re-cap and fix up the input filtering.
                        EDIT: The Delta I posted before is alive. I replaced the caps, the smaller torroid coil, and the wires. It's fine now. It does the full 300W in spec.
                        • Wester547
                          • Nov 2011
                          • 1268
                          • USA.
                          #312
                          ^ How is the efficiency of that Delta at 300W and below?
                          • c_hegge
                            • Sep 2009
                            • 5219
                            I didn't do a progressive load test. It was late in the day, and I had other things to do, so I just took it straight up to 310W. The efficiency there was about 77% IIRC. Not great for 230V, but I've seen much worse.
                            • Behemot
                              • 4845
                              • CZ
                              #314
                              Yeah the heatsinks look somewhat decent. What transformer it uses? I think it is the most basic element really. You can pretty much change everything else, but not so much the transformer (well, if you don't have bigger one with the same wiring from another PSU).
                              • goodpsusearch
                                • Oct 2009
                                • 2848
                                • Greece
                                #315
                                +1
                                And I was never brave enough to change the primary transistors of a psu.
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  The transformer looks like an ERL-33. It would be good for 250W after a re-cap, which is enough for a basic PC.
                                    master hoarder
                                    • May 2008
                                    • 12164
                                    #317
                                    Originally posted by c_hegge
                                    It's a Sun Pro.
                                    Sun Pro it is, indeed.
                                    I wouldn't touch that particular platform even with a 10 m stick. It's crappy at best. Decent source of parts, though.
                                    Yes, you should. The caps may as well be garbage, but the secondary rectifiers on those are usually okay. The 5V rail in particular, may have 16 or 20A part. It's not a whole lot, but when you get a Deer or a Bestec that has space for a second rectifier on one of it's rails, this becomes a really nice upgrade. The MOSFET that regulates the 3.3V rail on these units is also useful. The 431 shunt regulator is also useful if you like to thinker/play with circuits.
                                    • Shocker
                                      Banned
                                      • Dec 2011
                                      • 635
                                      #318
                                      I've never seen an ERL-33 transformer. What I have seen are EI-33 and ERL-35. (And larger sizes like ERL-39 in bigger PSUs, or EI-28 in the worst of the worst.)
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        I'll recheck tomorrow. I'm pretty sure it was a 30A part for the 5V though
                                        • Behemot
                                          • 4845
                                          • CZ
                                          #320
                                          If you have some transformer info, please feel free to contribute to a list https://www.badcaps.net/forum/showthread.php?t=22475
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
                                          • amuse619
                                            Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
                                            by amuse619
                                            Hello!
                                            Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
                                            Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
                                            08-14-2024, 01:22 PM
