ME Firmware Cleaning Guide
all donations are welcome,
>>>>> click on this link to donate via PayPal. <<<<<
Re: ME Firmware Cleaning Guide
Is it the same bios youve already asked about in the HP ZBook Studio G8 thread - https://www.badcaps.net/forum/showpo...3&postcount=14 . What is your model,firefly or studio G8 .If its the same bios you`re asking for just bump that thread,no need to post the same thing again.If its a different one then start a new thread.Comment
this one is HP Zbook Firefly 14 G8Is it the same bios youve already asked about in the HP ZBook Studio G8 thread - https://www.badcaps.net/forum/showpo...3&postcount=14 . What is your model,firefly or studio G8 .If its the same bios you`re asking for just bump that thread,no need to post the same thing again.If its a different one then start a new thread.
SN: 5CG2071904Comment
Hello guys,
I need the firmware bin file CSE ME 12.0.35.1427 CNP-LP C, and I cannot find it anywhere, do you have any idea if it is possible to find it?
Thank you in advance.Attached Filesif you find these attachements useful please consider making a small donation to the site
If you can`t find it anywhere its ok to use the next oldest or newest version. Use PRD_RGN .
.Comment
It's already exist in Win-Raid`s Repository (Check the attached links in Post #1).
Also you are using a very old version for ME_Analyzer.Attached Filesif you find these attachements useful please consider making a small donation to the site
----------------------------------------------------------------------------------------------------------------------------------------------------------------------Comment
Re: What flash image tool
11.8.xx.xxx
Become a Badcaps supporter
Thanks to all supporters.​
----------------------------------------------------------------------------------------------------------------------------------------------------------Doctrina est fructus dulcis, radicis amarae..Comment
Thank you so much SMDFlea for the great and easy to follow guide.
I am recently trying to clean the ME on Surface Pro 7 (CSME 13), however I am unable to find the "SMIP signning field" in the FIT. The FIT only lists non-zero OEM Public Key and OEM Key Manifest Binary.
I tried to ignore this step, but simply overwritting the ME Sub Partition with a clean one and exporting the bios is not working - the tablet just turns on and off.
Thank you
by SMDFleaIf you have to clean the ME firmware on **some microsoft surface models the touchscreen can stop working.
** Some models do not need this fix.
*You should install the latest updates from microsoft,including the driver packs before assuming there is a hardware problem.* - See Post #2
EDIT: If nothing else works try this fix - https://www.badcaps.net/forum/showpo...8&postcount=40
Always check a working dump from the same model using FIT.If the working dump default setting for "Integrated Sensor Hub Supported" is set to "NO"...-
Channel: BIOS Requests ONLY!
by Wachenaggoi know a tool https://github.com/MuertoGB/MacEfiToolkit is capable of SN change and Clean ME but not updating EFI Version of the BIN file. is there a guide or a BIOS structure to update the firmware??...03-06-2024, 01:34 AM
by zklgfsHi,
I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...-
08-11-2025, 02:14 PM -
by TheUserHello to everyone ,
This is my first post here, and i would like to share with you a small story in case you can help me.
Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help... -
by gurj1979Hi guys.
I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
Got New chip and writes good.
THE PROBLEM...
It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
Does anyone have a Good Firmware I can have?...-
Channel: Troubleshooting & Designing Networks
- Loading...
