Ubiquiti firmware help. US-8-150W POE
  • gurj1979
    • Dec 2014
    • 186
    Hi guys.
    I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
    Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
    So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
    Got New chip and writes good.
    THE PROBLEM...
    It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
    Does anyone have a Good Firmware I can have?
    Or can you repair my firmware?
    I have attached mine if you need to compare.
    Thanks.​
  • hoaca388
    Badcaps
    • Jan 2022
    • 12248
    TRy : https://ui.com/download/software/us-8-150w
    • gurj1979
      • Dec 2014
      • 186
      Tried those weeks ago. Without an interface it wont upload to the Switch. Need a dump file so I can use EEPROM Write to the chip. Plus - the dump will have my MAC Address in it.
      The firmware on the chip is that bad / corrupt that it wont even bring up Console, so I can't even SSH to it and use Upgrade command
      • gurj1979
        • Dec 2014
        • 186
        So I managed to Console to the switch using Serial. The Firmware is Corrupt.
        Does anyone have a good one I can use?
        The MAC Address is not stored in the EEPROM - it's embedded in the Broadcom Network Processor.
        • gurj1979
          • Dec 2014
          • 186
          Has anyone got a US-8-150W POE Firmware Dump (full dump) which as been Factory Reset ?
          Desperate here.
          Thanks.
          • Chipbg
            • Oct 2024
            EEPROM chip
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • testaccgta
              Unable to verify IC or write/erase/flash BIOS file to XMC QH128AHIG SPI chip using NeoProgrammer/AsProgrammer
              by testaccgta
              Hi, everyone!
              I've recently acquired two brand new SPI chips to replace the one currently in my Acer A514-54G laptop MB (FH5AT LA-K092P). The reason why I'm replacing the current SPI chip is because I had some difficulties with a third-party IT assistant who pretty much lacked the soldering skills and ended up destroying the current SPI chip soldered to my MB from factory.
              I've decided to do this on my own because I spent the past month or so learning some soldering skills and BIOS modding through Badcaps and WinRaid forums, hence the attempt. I've also chosen to buy...
              09-01-2024, 08:24 PM
            • ahmedtou
              HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
              by ahmedtou
              help me please
              I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
              When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
              I will share all the details with you, including the disc information.
              Code:
              HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
              Current Profile: BD-R
              Disc Information:
              Status: Empty
              State of Last Session: Empty
              Erasable: No
              Free Sectors: 12,219,392
              Free Space: 25,025,314,816 bytes
              Free Time: 2715:27:17 (MM:SS:FF)
              Next
              08-27-2025, 08:49 AM
            • CapThatBrass
              RT809F Chip Write Failure - Winbond 25R256JV
              by CapThatBrass
              I've managed to take an image dump in BIN format of my Dell Latitude 5420, which had a Winbond 25R256JV chip installed.
              I used an RT809F programmer to obtain the BIN, using the supplied iFix RT809F programmer application (latest version being 20220830).
              The programmer automatically found the settings to read the chip but selected the Winbond W25Q256FV instead (my actual model isn't available on the listing within the software). The image came out fine - I did this multiple times to clarify the data being read was the same each time.
              10-04-2022, 11:56 AM
            • stormy1777
              Pantum CM1100adw firmware w/no chip
              by stormy1777
              Hi friends.
              Got the CM1100adw color printer and delighted at the prospect of being able to break-free from this "chip" on inks/toners!!!
              Read many posts on topic.. wondering if someone can help:
              HTML Code:
              Firmware Version: 3.E.1.2
              Engine Version: 1.0.6.8
              HTML Code:
              Q044RlYwMDA3Rzo6MzExMjAwMEY6OkFDOkM1OjFCOjUxOkJCOjVFOjozLkUuMS4yJFNJRzQwMDhmYzZmYjgxNDU1MWMwZTJiMTkxZjM1ODkyNGUzOjpCdWlsZHRpbWU6IFRodSAxOSBTZX
              AgMjAyNCAxMToyOToxMCBBTSBDU1Q6OjEwMjQ6OkNNMTEwMEFEVwA6OjEuMC42LjgAOjo1Ljg6Og==
              Assuming i'd want to do myself, is it possible to read/dump...
              06-27-2025, 09:13 AM
