ME Firmware Cleaning Guide
    • 25739
    Here`s a quick ME Firmware cleaning guide.
    The guide is basic,its main goal is to show you how to use intel FIT,its highly recommended that you all follow the guide posted at win-raid
    (The attached FIT version is 11, if your ME Firmware (FW) is not 11.0.*.* follow the win-raid guide. Use the tools version for your ME FW, for example: ME System Tools v9.1 For systems running ME v9.0 - v9.1)
    A video,software (intel FIT) and practice bios are all included. I`ll post a better video and more advanced guide at a later date.
    1. Open the bios with MEAnalyzer and check the ME firmware version
    (The latest ME Analyzer releases are on Github,https://github.com/platomav/MEAnalyzer/releases )
    Thank You platomav
    (Create MEAnalyzer executable from Github Python Scripts - https://www.badcaps.net/forum/showthread.php?t=115358 . Thank You reformatt
    2. Find the matching ME firmware and rename to ME Region.bin
    3. Start Flash Image Tool (FIT) and open the bios
    4. Change "Generate Intermediate Files" to no and save as untitled.xml .Close FIT
    5. Copy or move the ME Region.bin to the decomp folder, overwriting the original
    6. Start FIT again,open the untitled.xml file, click on Build,Build Image .
    7. outimage.bin is the bios with clean ME firmware, rename it if you want
    8. Open the bios with MEAnalyzer,it should say Configured (only ME FW 11 and above will say configured)
    9. Job done
    How to clean ME Region on Apple machines https://www.youtube.com/watch?v=exfG5Iywmjk .Thanks piernov
    For a more detailed,in depth guide:
    Guide-How To: Clean Dumped Intel Engine (CS)ME/(CS)TXE Regions with Data Initialization https://winraid.level1techs.com/t/gu...lization/31277 .A huge thanks to plutomaniac
    Intel (CS)ME, CS(TXE), CS(SPS), PMC, PHY & PCHC:
    Firmware Repositories
    https://winraid.level1techs.com/t/in...sitories/30869
    Intel Management Engine: Drivers, Firmware & System Tools 2-15
    https://winraid.level1techs.com/t/in...ols-2-15/30719
    Intel Trusted Execution Engine: Drivers, Firmware & System Tools
    https://winraid.level1techs.com/t/in...nd-tools/30730
    >> Please consider making a donation to the guys at Win-raid to help with hosting. <<
    And to Badcaps https://www.badcaps.net/index.php?pageid=donate1<<
    Last edited by SMDFlea; 04-26-2023, 09:09 AM. Reason: Updated URL`s.Old win-raid links no longer work
    • 25739
    Re: ME Firmware Cleaning Guide
    Some motherboards have dual bios chips.FIT can`t work without first joining the bios backups together into one file.
    To join two files together you can use a hex editor,file joining software or a batch script that runs from the windows command line.
    To make a batch script copy the text without the quotes "" into notepad:
    "@ECHO OFF
    copy 8MB.bin /B + 16MB.bin /B 8+16MB_Joined.bin /B
    pause"
    Save the file with any name you like followed by a .bat file extension,for example: Join_8+16MB.bat
    When the batch file is run the files named 8MB.bin and 16MB.bin are joined together and a new file is made called 8+16MB_Joined.bin
    Both filenames must be renamed to match your own filenames,or you can rename your bios backups to match the script filenames.
    Multiple scripts can be made and kept in the same folder.Files of any size can be joined,the file names are used just to avoid any confusion.
    After cleaning the ME firmware FIT will split the files back again.
      • 25739
      ME 16 and ME 16.1
      Work in progress
      • lapfix
        • Mar 2020
        • 2778
        • my workshop
        Clear steps to take , thank you SMDFlea
        • bachir2004
          • Feb 2015
          • 439
          • maroc
          Really nice job smdflea.
          • sourcebf
            • Jul 2016
            • 435
            • N/A
            • Laptops, Tablets & Mobiles
            Thanks brother for all this useful informations
            • Mazorca
              • Jan 2017
              • 463
              • fishing
              A thousand thanks. Makes for a good reading and learning even if you don't do the cleaning, lots of good info.
              • Spider1211
                • Oct 2019
                • 532
                • Mauritius
                Thank you. Can you please make a guide on how to extract EC?
                • Ghamidi
                  • Mar 2020
                  • 308
                  • France
                  Great job thank Mr smdfela
                  • fyaagoub
                    • 269
                    • maroc
                    Thank you
                    • al2216aa85ms
                      • Sep 2020
                      • 6
                      • canada
                      Checking the resulting outimage.bin with the infamous me_cleaner.py tells me that "The AltMeDisable bit is NOT SET"
                      How is the ME cleaned then? Will your steps prevent it from loading or....? Please excuse my lack of knowledge.
                      My ME version is 10.x.x.x and using ME_Analyzer, there is nothing to indicate whether the image is "configured" or not, that piece of info is simply missing/omitted from the results. Your test bin says "initialized" before the cleaning and is ME ver. 11.x.x.x. Maybe ME ver 10.x.x.x doesn't even have the option to be "configured"?
                      I will test my outimage.bin later on tonight to see how the ME behaves.
                      Thanks for the clear steps and all the tools and info provided, much appreciated.
                      • qonma
                        Kuli Solder
                        • Jun 2017
                        • 189
                        • INDONESIA
                        • TRAVELLING
                        nice post meybe to experiments for the clean me
                        • al2216aa85ms
                          • Sep 2020
                          • 6
                          • canada
                          OK, I read part of the in-depth guide you linked to and the goal, it says, is to prepare the bios.bin for flashing on similar machines. I was under the impression that this guide would strip away the ME so that it is disabled. For those who want to "disable" ME on your machines, this is not the guide to follow. There is nothing good about the ME, just another way big brother may keep a watchful eye over you. It's kinda creepy now that I think about it and I'm sure violates some human rights.
                          • Bonzas
                            • 475
                            • Indonesia
                            Tried several times without success with ME 11 or later especially after ME 12 release, found many board trouble with that bios.
                            Maybe someone can help to explain where is important part doing this ( Clear ME 11 & Later )
                            • alas3376
                              • Nov 2011
                              • 381
                              • BENIN
                              great job, thank you
                              • stingerchamp
                                • Sep 2020
                                • 475
                                • Pakistan
                                • Computer or laptop troubleshooting
                                What happens if file system already said configured instead of initialized?
                                when i open bios file ( dumped one) it says file system configured.
                                • stingerchamp
                                  • Sep 2020
                                  • 475
                                  • Pakistan
                                  hi,
                                  if you need Intel CSME firmware repository pack for 11.8.50 ,please find below compressed file.
                                    • 25739
                                    It means the ME firmware is already cleaned.
                                      • 25739
                                      hi,
                                      Thanks, you`ll find a link in the first post to all the repositories
                                      https://www.win-raid.com/t832f39-Int...ositories.html
                                        • 25739
                                        Which part in particular are you getting stuck with
