Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
  • TheUser
    Burned Alive
    • Greece
    Hello to everyone ,
    This is my first post here, and i would like to share with you a small story in case you can help me.
    Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
    All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
    I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help you update the firmware on the docker.
    But on my side, it doesn't do it.
    It keeps saying update required and then says either that FW has failed or starts again over and over again...
    I restarted checked different cables but again and again and again the same result. Nothing changes.
    Another solution would be to burn -again the .bin file to the bios/eeprom chip directly but for sure i would need to have the original part / bin file to burn into the chip itself... (if i will find or anyone has fixed something like that)
    Here is a part of the code, and please help out ?
    Thanks a lot guys !
    Code:
         USB-C Dock Gen2 FW utility V1.1.20
      Package including (DP hub : 5.07.001, USB hub : 0D24,0D23, PD Billboard : 0.1.0.30, PD CCG4 : md.0.0.37, Audio codec : 49-0E-43)
    Update date: 10/2/2024
    Update time: 9:21 μμ
    Before TimeDelay: 9:21:18 μμ
    After TimeDelay: 9:21:18 μμ
    TBT Force Power Enable
    Switch5G...
    Checking current Dock FW version :
    Firmware version is : Unknown
    The detail firmware version of each component :
    DP hub version : 0.00.000
    USB hub version : 0D24,0D23
    PD Billboard version :     USB-C Dock Gen2 FW utility V1.1.20
    Switch5G...
    PD Billboard version : 0.1.0.30
    PD CCG4 version : md.0.0.37
    Audio codec version : 49-0E-41
    Update is necessary.
    Current USB hub version is the same, no need to update.
    Current PD Billboard version is the same, no need to update.
    Current PD CCG4 version is the same, no need to update.
    Estimated it will take 01 minute(s) and 01 second(s) for Firmware update progress
    Start to update DP hub FW...
    Update DP hub FW...Fail
    Start to update Audio codec FW...
    Update Audio codec FW...Pass
    Switch10G...
    TBT Force Power Disable
    ThinkPad USB-C Dock Gen2 FW update Finished 0.1.0.30
    Switch10G...
    ThinkPad USB-C Dock Gen2 FW update Finished​
  • reamon
    • Aug 2020
    • 31
    Hi
    Did you find solution with 40as or original FW bin file ? thank you
    • weisian
      VSX-1021 - Update Error 1, DSP replaced, potentially need working firmware dump
      by weisian
      I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
      1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
      2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...
      03-12-2026, 05:54 AM
    • Boardview and Schematic Bot
      How To Check BIOS / EC firmware version for MSI notebook & Update it
      Not sure how up to date this is....
      How To Check BIOS/EC firmware version for MSI notebook?
      Please check BIOS/EC version by [Help Desk] or [BIOS Setup Utility]
      1. How to check BIOS/EC version by Help Desk?
      1.1. Open MSI Help Desk.
      Note: Help Desk is a built-in application for MSI notebooks. If you couldn’t find this software in your Windows system, please download and install MSI Help Desk from product.
      1.2. Click the [System Info].
      1.3. BIOS and EC firmware version will display on screen.
      03-27-2026, 01:12 PM
    • rumpumpel1
      ThinkPad X12 Detachable Gen 1: keyboard after firmware update without function
      by rumpumpel1
      Lenovo System Update offered me an update for the firmware of the Folio keyboard for my X12 Detachable Gen 1. The update got stuck and after 20 minutes I switched off the laptop. Since then, the keyboard and touchpad have been without function. Does anyone know how I can revive it?
      10-24-2024, 08:59 AM
    • dkneyle
      Sony KDL-46HX850 Can't upgrade/update firmware
      by dkneyle
      Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
      Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
      09-25-2024, 10:44 PM
    • piernov
      Infineon TPM firmware update files
      by piernov
      Infineon TPM firmware update files:
      Infineon_firmware_update.zip
      Code:
      TPM12_4.32.879.0_to_TPM12_4.34.1010.2.BIN
      TPM12_4.33.949.0_to_TPM12_4.34.1010.2.BIN
      TPM12_4.40.119.0_to_TPM12_4.43.257.0.BIN
      TPM12_4.40.119.0_to_TPM12_4.43.258.0.BIN
      TPM12_4.40.119.0_to_TPM12_4.43.259.0.BIN
      TPM12_4.40.119.0_to_TPM20_5.62.3126.0.BIN
      TPM12_4.40.119.0_to_TPM20_5.63.3144.0.BIN
      TPM12_4.40.119.0_to_TPM20_5.63.3353.0.BIN
      TPM12_4.42.132.0_to_TPM12_4.43.257.0.BIN
      TPM12_4.42.132.0_to_TPM12_4.43.258.0.BIN
      TPM12_4.42.132.0_to_TPM12_4.43.259.0.BIN
      10-25-2025, 10:09 AM
