Lenovo Thinkpad Ec Pwd Bypass
  • Andromedus_81
    • Aug 2023
    • 47
    • United Kingdom
    #721
    Any luck with Lenovo ThinkPad T14 Gen 2 Type 20w1 ? S/N 45at48
    • anhbanxoi
      • Sep 2021
      • 178
      • VN
      #722
      replace the MEC
      • Gabrielsun
        • Jul 2025
        • 3
        I'm new to the forum and looking forward to learning something new.
        I got a Lenovo Thinkpad X1 Carbon Gen9 (with intel CPU) on which the USBC ports were broken, these are now repaired, I have reinstalled the notebook with Win11 and actually everything works, but it has a bios supervisor password.
        is there any way to read out the password, or install a new bios? or any other methods?
        as I said, I am an absolute beginner and need to get an overview first
        Greetings to all
        • peste
          peste commented
          Editing a comment
          post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
      • peste
        • Dec 2016
        • 13041
        • ROMANIA
        #724
        Greetings to all
        post S/N, full name and model, motherboard model, TYPE,etc.
        • rediii
          h???, spurrrn
          • Mar 2018
          • 490
          • somewhere in europe
          #725
          Greetings to all
          not possible... mec1503/1723
          • rediii
            h???, spurrrn
            • Mar 2018
            • 490
            #726
            Originally posted by veridiux
            I purchased an X1 Carbon Gen 8 a few years ago, but unfortunately discovered it’s locked with a BIOS password. Will this method work to bypass or reset it?
            yes, you can program it. these devices have a mec1633 chip. try the shorting technique or program via jtag or kbc. greetings
            • Gabrielsun
              • Jul 2025
              • 3
              S/N: PF3LEK30
              Machine Type Model: 20XW005JGE
              System board serial number: L2HF23P010Z
              • Andreasbest
                • Aug 2014
                • 1179
                • Hellas ( Greece )
                #728
                On T470s is on J5 (hidden behind the Mac Address sticker) in case anyone is searching for it
                • softlibs
                  • Jul 2025
                  • 4
                  i tried the shorting technique on a p53s and now it boots to a blank screen.
                  how do i recover from this? also i probably shorted the wrong chip, i was poking around on the j9301
                  i'm reading right now but rather frustrated with many many other things that y'all have the space to have dumped on you here.
                  • Tokeri
                    • Sep 2024
                    • 8
                    • Sweden
                    #730
                    Hello, I have a question. Since this method works by shorting LPC, does it also work with AMD models? I have a L14 gen 1 ryzen model, that I got the schematics for and it shows that it also uses LPC bus for EC communication. From what i understand, the only EC that don't work are the ones using eSPI.
                    • Geromen
                      • Mar 2025
                      • 7
                      • Dominican Republic
                      #731
                      I understand that it will work, try.
                      • Tokeri
                        • Sep 2024
                        • 8
                        • Sweden
                        #732
                        I can report, it works! Took a few tries but now I have an unlocked L14 laptop
                        • kyzer
                          Nson
                          • Jul 2020
                          • 10
                          • Cameroon
                          #733
                          Originally posted by Maxpower3
                          Click image for larger version Name:	Nouveau Image bitmap.png Views:	0 Size:	6.76 MB ID:	3259195
                          Connect your motherboard to an external screen or with the original LCD, being careful.
                          Uses a USB keyboard to make things easier and avoid communication problems with the KBC(Ec)
                          Prepare a ground wire.
                          When everything is ready.
                          You must put a wire on the ground and make a light contact (1 -2 seconds should be enough).
                          If too long, errors occur : Fan error, Bad data, Thermal sensor etc ... and power off
                          Wait the Logo or just after the backlight.
                          Short contact with pin 128 or 1, wait and release
                          and press F1 to enter setup
                          After clearing security with blank password
                          and clear security chip.
                          Simply restart with Ctrl Alt Del
                          And test now
                          Warning:
                          Do not short before full startup (backlight), nor during shutdown.
                          Follow this carefully, otherwise there is a risk of bricking or corrupted data.
                          • jawal37
                            • Feb 2013
                            • 41
                            • afric
                            #734
                            LPC_AD2 WORK GOOD IN RC0905 NEAR PROC
                              • 21282
                              What model is that ?
                              • Aapenootjes
                                • Nov 2016
                                • Nederland
                                #736
                                Maxpower3 Thank you so much! I can confirm this works on my Thinkpad P1 gen1 20MD (LPM-1 MB 17870-1, MEC1653-BA1). By extension, this should work for the Thinkpad X1 extreme gen1 as well.
                                This motherboard has two LPC debug ports, LPC1 and LPC2. My first hour of trying was fruitless, connecting ground to the correct pad on LPC2 didn't do anything at all. Two days later I took a better look at the the board and its schematic. Following the trace I noticed the resistors connecting the LPC1&2 pads to LAD0:3 aren't actually populated. I've been connecting ground to nothing! Upon noticing this I put some tape as a mask around the unpopulated R7722 & R7715 resistor pads, these connect to the LPC_AD3 trace. Using these pads I was able to get rid of the SVP in about 15 minutes.
                                I was so close to giving up entirely after spending 5 days trying, most of which I spend trying to get an autopatched image to work.
                                • kicker12
                                  • Jul 2022
                                  • 11
                                  • Italy
                                  #737
                                  Confirm it unlocks P14s Gen1, MoBo NM-C931, MEC1663. MERCI!!!
                                    Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                    This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                    09-06-2024, 11:40 AM
