Lenovo Thinkpad Ec Pwd Bypass
  • Mahesa09
    • Nov 2021
    • 63
    • jakarta
    #621
    Originally posted by Maxpower3
    you're talking about my video L13 Gen2, you left a comment??
    at the beginning for the suspense, I didn't show,
    I did with switch
    not in the video, I'm just curious because it wasn't from the start.
    now I wonder why the e14 g2 i5 gen 11 and l14 i5 gen 11 didn't work while for amd it worked​
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1171
      • France
      #622
      Originally posted by Mahesa09
      hy max, why not work to l14 g2 HL4A0/HL5A0 NM D271
      @mahendra938
      hy max, what are doing to LENOVO L13 Gen2 Nuvoton NCPE68B , I see you don't do grounding
      sorry, I got confused.
      • wraster
        • Jan 2025
        • 18
        Originally posted by volinakis
        marked part to ground, as Maxpower3 instructions
        Thanks very much.
        Can you help me learn how you knew that is the 0-3 LAD trace? I am just starting to learn to translate board diagrams. In the attached schematic LAD0:3 are labeled K1, J2, J1, H2, and overlapping the trace you marked on the board are the letters "K" and "U2". Are all of the LAD wires bundled together in that trace, or the entire LPC bus? I see that there are many fewer traces on the board than are connections in the diagram.
        Link to schematic - https://www.badcaps.net/forum/troubl...v1-0-schematic
        Another question I have is, how exactly do you short it? Just touch the top of the trace right there where you marked with my grounded conductor?
        I really appreciate it, this is very interesting to me.
        • volinakis
          • Jan 2021
          • 2622
          • N/A
          #624
          Originally posted by wraster
          Thanks very much.
          look at the boardview of NM-C801. Use a switch, as you can see in Maxpower3 instructions or other users photos.
            • 20311
            sorry, it's me who started it, Possible to move all the off-topic posts into a new therad SVod info and problem
            Its ok ,i split the posts off to a new thread --> https://www.badcaps.net/forum/troubl...-svod4-npcx997
            • wraster
              • Jan 2025
              • 18
              It would help me understand to have answers to the questions I asked. I am trying to find the information I need to understand Maxpower3's instructions (I am unfamiliar with many of these terms and acronyms and am piecing it together). For example I don't know what you mean by "use a switch" (what is a switch in this context?). If anyone else can help answer my questions I would appreciate the help! Also/alternatively, do you know of a good reference for these things? Like how to translate the boardview to the board.
              In the attached pic of the chip and board region, does either the red circle or yellow circle contain the actual location of where one would touch the board to short the LPC bus?
              I see my attachment didn't work in my previous post, trying again here. I think this is what you refer to by boardview.
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1171
                • France
                #627
                Click image for larger version  Name:	image.png Views:	0 Size:	2.84 MB ID:	3553923
                lad 0​ or 1/2/3
                look
                • volinakis
                  • Jan 2021
                  • 2622
                  • N/A
                  #628
                  You would understand if you read previous posts, in post 603 you have a pic with "switch". Boardview is a schematic containing print of circuit board and components placed on board, google should answer to this question ... You can find boardview searching on this forum for "NM-C801 schematic". ALL INFORMATIONS are here, in this forum, but you want to be given to you instead of looking for them ...
                  • Mahesa09
                    • Nov 2021
                    • 63
                    • jakarta
                    #629
                    @mahendra938
                    sorry I don't want to confuse you, now I don't discuss what in your video I already understand.
                    now my question,
                    d lenovo e14/e15 G2 amd this method works.
                    l14/l15 g2 amd also works.
                    but this method is not working
                    on e14/e15 g2 intel and l14/l15 g2 intel.
                    even though it is only different from LPC and ESPI.
                    In the schematic, there are LPC and ESPI modes, how to change them​
                    • Mahesa09
                      • Nov 2021
                      • 63
                      • jakarta
                      #630
                      NPCE68BPA0DX Lad Pin 126-127-128 or 1 of EC
                      This doesn't work max, there is a difference in the cascitor installed with L14 gen 1.
                      check pins 125 and 124 on l14 g1 and l14 g2.
                      is it necessary to remove the connecting resistor at pins 124 and 125 of l14 G2​
                      • Mahesa09
                        • Nov 2021
                        • 63
                        • jakarta
                        #631
                        I have attached the differences
ID:	3554532 Click image for larger version
                        IIClick image for larger version
Name:	max bypass l14 AMD.png
ID:	3554529Click image for larger version
ID:	3554530 Click image for larger version
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1171
                          • France
                          #632
                          you can try!
                          for me it doesn't work,
                          Espi is in Pch.
                          some killed processors or motherboard while playing with espi
                          • Mahesa09
                            • Nov 2021
                            • 63
                            • jakarta
                            #633
                            you can try!
                            Espi is in Pch.
                            I also wouldn't dare if no one tried heheheh
                            • wraster
                              • Jan 2025
                              • 18
                              lad 0​ or 1/2/3
                              look
                              Thank you!
                              • wraster
                                • Jan 2025
                                • 18
                                You're partially correct - I asked questions in the hopes that somebody would provide me an answer. I have read the thread, and in my current state of knowledge, the abbreviated form generally used (which makes assumptions on what is already known) gives me only partial information for which I lack the context, making it more of a task than just reading the incomplete sentences to reach understanding - which I know works for you in this field because you are already familiar with the concepts. Therefore "ALL INFORMATIONS" means something different to you than it does to me. The information is surely outside of the forum as well, but this format facilitates conversational learning and has been helpful for many people, myself and probably yourself included. You can also build relationships through tact, if you want to.
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1171
                                  • France
                                  #636
                                  Originally posted by Markus1741
                                  I could use it to unlock a Lenovo T14s Gen2 AMD built in February 2022, otherwise it would be electronic waste.
                                  Especially since you're making it all available for free.
                                  Chapeau! Chapeau!
                                  I confirm it worked for me too
                                  Ttiming a little different.
                                  Short after F1 and timing a little long.
                                  it happened, just clean pwd even no security chip
                                  X13 Gen2 AMD Nm-d442 IT5679VG
                                  with last bios 1.32 with a weird version of EC. 1.08.
                                  Well there is 1.33 that came out today
                                  Click image for larger version  Name:	image.png Views:	0 Size:	2.02 MB ID:	3558009
                                  • FalconPunch
                                    • Oct 2023
                                    • 20
                                    • France
                                    #637
                                    Hello MaxPower,
                                    Thanks again for sharing this method. I tested on my laptop but it is high risks, high reward solution . It was a lenovo x380. Of 50 tries on shorting LPC_AD 0 to GND, I managed to get to 2 times in the bios. On the first time, i cleared the Supervisor password and cleared the security ; I have done Ctrl+Alt+Del to exit from bios ; Upo rebooting the bios password was still there. So i managed to get bios a second time. but this time laptop froze when i was redoing clearing supervisor password; It shuts downs ; upon powering on, There was no display not even Lenovo Logo : I think i bricked it ; Should i get a random bios file for Lenovo x380 on the forum to flash it on the pc ? Thanks
                                    • babanu
                                      • Jan 2011
                                      • 57
                                      #638
                                      Hello everyone I have a laptop lenovo Thinkpad L13 Gen.2 Serial R9-125S7V Type number 20VK-S02400 bios passworded and locked in computrance KBC NPCE68BPA and SAS programmer A tutorial or some information if you can trick me Thank you!!
                                      • jackx
                                        • May 2020
                                        • 198
                                        • casa1
                                        #639
                                        Salut frero maxpower comment decoder p15 lenovo
                                        • babanu
                                          • Jan 2011
                                          • 57
                                          #640
                                          Hello For the above lenovo model equipped with NPCE68, among the 4 pins to ground 126,127,128,1 after many attempts the functional pin is 126
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
