Lenovo Thinkpad Ec Pwd Bypass
  • Andreasbest
    • Aug 2014
    • 1188
    • Hellas ( Greece )
    #221
    2+ hours of testing and no success.
    The closest i get is a "user" bios interface with only Main, Config and Time tab enabled.
    I get some EAIA data access error and Machine UUID is invalid but still after this asks for password again.
    I even installed the same BIOS like Max's laptop on T480s video.
    I give up.
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1253
      • France
      #222
      Originally posted by Andreasbest
      Over 1 hour of testing on T480s and i get Thermal Sensing Error.
      Got other errors like EAIA data access error and Machine UUID is invalid but this the most common.
      Machine power off when this occurs.
      Keep trying.
      Try holding Esc during boot to bypass power off due to errors
      • Andreasbest
        • Aug 2014
        • 1188
        • Hellas ( Greece )
        #223
        Ok, gonna try again and upload results.
        I'm surprised how easily you made it work on the video.
        • Andreasbest
          • Aug 2014
          • 1188
          • Hellas ( Greece )
          #224
          No luck, still the same, closest i can go is a limited BIOS with Main, Config and Date/time tabs only.
          Esc is not preventing the shut down due to Thermal Sensing Error
          • Andreasbest
            • Aug 2014
            • 1188
            • Hellas ( Greece )
            #225
            Just to make sure i'm not super dumb, the marked red pins are the correct? any of them?
            Please confirm.
            • Andreasbest
              • Aug 2014
              • 1188
              • Hellas ( Greece )
              #226
              I bricked it, loaded defaults on limited BIOS and now is just singing a melody, no post.
              No problem, it will become a great donor for the rest T480s, locked motherboard was useless anyway.
              If you need any testing with t480s, T490s and E14 Gen2 let me know, i have many.
              • danito
                • Jun 2016
                • 1049
                • Romania
                #227
                Please confirm.
                for me, t480s and t490 worked with pin 6.
                I don't bother with T14 gen1.​
                • Andreasbest
                  • Aug 2014
                  • 1188
                  • Hellas ( Greece )
                  #228
                  i tried all pins with the above results.
                  perhaps has something to do with the enabled fingerprint on my BIOS, i don't see other difference.
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1253
                    • France
                    #229
                    Originally posted by Maxpower3
                    Hello everyone.
                    Don't save with F10, just clean Pwd with enter twice.
                    If the serial, uuid etc. information is corrupted, you are saving the wrong information
                    The method is delicate, there is always a risk of bricking or try failed.
                    ITE and Nuvoton is easy
                    Mec16 is more delicate (many try necessary).
                    Timing is important
                    you're almost there, the safety tabs are missing, you have to keep trying. maybe stay less long
                    for MEC, must start before the display with a short contact,
                    too long = fan error and power off.
                    Never saved or loaded by default, I killed a few computers during my tests too
                    if Mec records corrupted information, it's over​
                    • black0hackers
                      • Jul 2020
                      • 367
                      Some one doing on L13 G3 intel?
                      • Andreasbest
                        • Aug 2014
                        • 1188
                        • Hellas ( Greece )
                        #231
                        Before display you mean before the LENOVO logo BUT after the backlight?
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1253
                          • France
                          #232
                          difficult to explain
                          just before the panel lighting, before the logo.
                          It takes many tries to get the timing right.
                          if too long or too late, fan errors and other errors appear.
                          The ideal is when you have access without errors so that the numbers are not corrupted.
                          you have to check if information is not corrupted in the first tab.
                          that's why I do a ctrl alt del after deletion like that the information is not saved, just password removal
                          • danito
                            • Jun 2016
                            • 1049
                            • Romania
                            #233
                            Maxpower3 for mec1503 (T15 gen2) have you found any solution?
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1253
                              • France
                              #234
                              no progress
                              as said above, absent at the moment,
                              I don't even have a desk to work on at the moment. lol
                              Masonry, roofing and electricity.
                              I pass by here from time to time but I can't help much
                              • danito
                                • Jun 2016
                                • 1049
                                • Romania
                                #235
                                no progress
                                I understand. Good luck there.
                                • Zalman
                                  • May 2020
                                  • 32
                                  • UA
                                  #236
                                  Please confirm.
                                  Why don't you just unlock them all with Autopatcher and 10EUR USB Programmer (CH341a + SOIC8 clip)? No soldering, no nothing. Just need another device and python installed.
                                  • volinakis
                                    • Jan 2021
                                    • 2804
                                    • N/A
                                    #237
                                    Yep, good luck unlocking them with CH341A!
                                    • Zalman
                                      • May 2020
                                      • 32
                                      • UA
                                      #238
                                      I was referring to those 3 boxes of T480s. Not the other devices he has.
                                      When I was following Maxpower's instructions for the first time with MEC1663 device it took me like 30 min, the next one was probably 5 min or so. So yes, bypass method would be faster, but if he absolutely can't move anywhere, I don't see a reason for not using Autopatcher on 8th gen Kaby Lake R. Instead of just killing boards one by one like he reported. Do you?
                                      • Andreasbest
                                        • Aug 2014
                                        • 1188
                                        • Hellas ( Greece )
                                        #239
                                        CH341A not working on T480x and above.
                                        PW stored in EC.
                                        • svadikn
                                          PC-expert
                                          • Jul 2024
                                          • 15
                                          • Poland
                                          #240
                                          Hello everybody! On a Lenovo ThinkPad 13 S2 laptop, main DA0PS8MB8G0 rev:G methods LAD0-LAD3 on GND - DID NOT HELP.
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
