Lenovo Thinkpad Ec Pwd Bypass
  • rediii
    h???, spurrrn
    • Mar 2018
    • 504
    • somewhere in europe
    #301
    Originally posted by izaak94
    Is there also no way to read with JTAG vertyanov?
    no, it's impossible and maybe will never be (same for mec1503).
    • mshone
      • Jan 2014
      • 61
      • serbia
      #302
      Originally posted by Andreasbest
      Success!!
      The mini circuit with button and GND from USB was a miracle, i was ctrl-alt-delete and buttoning rapidly.
      Thank you Maxpower3 pro as usual.
      Did GND from other point is possible? Thanks in advance
      • Andreasbest
        • Aug 2014
        • 1218
        • Hellas ( Greece )
        #303
        Yes, as you can see i get GND from usb, you can get GND from any place on motherboard.
        Tip: disconnect the speakers while you try, it's much easier without constant beeping
        • Andreasbest
          • Aug 2014
          • 1218
          • Hellas ( Greece )
          #304
          Maxpower3 Do you believe that Ctrl-Alt-Del works exact the same way as power on/off or not?
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1358
            • France
            #305
            I always use Ctrl alt del to do the bypass,
            I leave the PC started normally, then ctrlalt del and bypass​
            • Andreasbest
              • Aug 2014
              • 1218
              • Hellas ( Greece )
              #306
              Hello Maxpower3 i have a small info, perhaps it's useless though.
              Remember the T480s that i bricked with the load defaults and F10? Yesterday that i tried it again was beeping a Lenovo diag melody, i managed to make it post again with a simple RTC reset (all batteries disconnected, psu disconnected, power button pressed for ~1 minute).
              For some strange reason the glitch wasn't working on it (bios 1.31) perhaps EC got corrupted due to F10, so i tried to flash the next version (1.33), EC got updated with 1.33 and glitch was possible again.
              Try your bricks again, perhaps you can resurrect them this way.
              • widdx
                • Aug 2024
                • 5
                • Sweden
                #307
                Hey, thanks for providing this method Maxpower3, i successfully unlocked a P53. I now have a x390 that appears to be bricked, No power led and not responding to powerbutton. Tried reset button for 30 seconds+ aswell as disconnecting the whole motherboard for hours.
                Is there any way of resurecting this? I assume it is because the MEC1663 got corrupted, is it possible to reprogram through JTAG or spi? The board gets power.
                • Andreasbest
                  • Aug 2014
                  • 1218
                  • Hellas ( Greece )
                  #308
                  Try to disconnect all batteries for a few days. One T480s that i got here was revived after some days, was bricked due to load defaults and save while i was using the glitch.
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1358
                    • France
                    #309
                    yes, he is right. Sometimes he lives again but sometimes he dies. I also have an X390 which died like this. I haven't taken care of it yet​
                    • widdx
                      • Aug 2024
                      • 5
                      • Sweden
                      #310
                      I’ve had it disconnected for at least 3 days and it did’t really do anything. Still completely dead, No led from charger or anything, sadly.
                      • Andreasbest
                        • Aug 2014
                        • 1218
                        • Hellas ( Greece )
                        #311
                        Are you sure is bricked and not just faulty?
                        Meanwhile i succeed unlocking another T480s, i have the feeling that if you go just before LENOVO logo (perhaps some milliseconds with LENOVO logo on) is easier to trigger it.
                        • widdx
                          • Aug 2024
                          • 5
                          • Sweden
                          #312
                          It worked fine until the last attempt that gave me some errors, then it just shut down and never woke up again.
                          • Andreasbest
                            • Aug 2014
                            • 1218
                            • Hellas ( Greece )
                            #313
                            If you didn't saved on BIOS then perhaps it's not bricked. Open thread with schematics and boardview (if possible) to check all voltages, perhaps another member has a good advice on this.
                            By the way, even if bricked the charger port LED should power on.
                            • Andreasbest
                              • Aug 2014
                              • 1218
                              • Hellas ( Greece )
                              #314
                              On P52 i see the LPC traces with and without resistors.
                              Where should i solder, before (right on JDBUG1) or after resistors?
                              Thank you in advance!
                              • Maxpower3
                                Bad Veteran
                                • Feb 2018
                                • 1358
                                • France
                                #315
                                if resistances present, use JDBUG1
                                otherwise go before the resistance if absent​
                                resistance 0 ohm, made as simple as possible for you otherwise​
                                • Andreasbest
                                  • Aug 2014
                                  • 1218
                                  • Hellas ( Greece )
                                  #316
                                  Ok, P52 ready too
                                  Max!
                                  • sam2929
                                    • Apr 2024
                                    • 5
                                    • algeria
                                    #317
                                    Hello Maxpower3​ any solution for Thinkpad T14 Gen 3 AMD Pwd Bypass
                                    • Andreasbest
                                      • Aug 2014
                                      • 1218
                                      • Hellas ( Greece )
                                      #318
                                      What model of EC has?
                                      • sam2929
                                        • Apr 2024
                                        • 5
                                        • algeria
                                        #319
                                        model of EC 21CG-S3C200
                                        • sam2929
                                          • Apr 2024
                                          • 5
                                          • algeria
                                          #320
                                          SN : PF-4C64AD
                                          Model : 21CGS3C22
                                          Bios :Lenovo R23ET65W (1.35) 21/03/2023
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
