Lenovo Thinkpad Ec Pwd Bypass
  • zomi
    • Nov 2011
    • 509
    #161
    Happy hunting brother
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1316
      • France
      #162
      Originally posted by Maxpower3
      edit
      after many try
      I managed to enter the bios, but the tabs are missing.
      Click image for larger version  Name:	441499388_881095270699214_2116687842734834106_n.jpg Views:	0 Size:	363.5 KB ID:	3279733 Click image for larger version  Name:	441409609_1406188906766540_432083223838718957_n.jpg Views:	0 Size:	336.0 KB ID:	3279734
      by the way, when I go through, with the 2 tabs, I have access to F9
      it loads well by default but the password is not cleaned.
      But I still have some access so I have to try to use the maintenance utility to initialize EC for testing.
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1316
        • France
        #163
        Originally posted by danito
        Maxpower3 can you help me please for a t14 gen 3 NM-E981 with NCPX997 what should be done?
        boardview or schema ? not found
        • ArtHunting
          • Sep 2023
          • 23
          Here boardview for this laptop
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1316
            • France
            #165
            thanks
            ​try
              • 21606
              Please do not post schematics or boardviews in the bios requests section.Post in in the "Schematic requests ONLY!" section , then you can post a link to it here.
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1316
                • France
                #167
ID:	3280024 Click image for larger version
                what is the latest version of the utility ??
                • ArtHunting
                  • Sep 2023
                  • 23
                  https://www.badcaps.net/forum/troubl...r-bootable-usb
                  • anhbanxoi
                    • Sep 2021
                    • 178
                    • VN
                    #169
                    Latest is 3.5.64
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1316
                      • France
                      #170
                      • anhbanxoi
                        • Sep 2021
                        • 178
                        • VN
                        #171
                        So you managed to remove the password?
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1316
                          • France
                          #172
                          no but I notice that the password is bypassed,
                          I can boot via F12 without password.
                          but there is a protocol error (LenovoEeprom)​
                          • anhbanxoi
                            • Sep 2021
                            • 178
                            • VN
                            #173
                            Try the latest U1 tool. Hope you can initialize the EC.
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1316
                              • France
                              #174
                              not worked
                              • danito
                                • Jun 2016
                                • 1058
                                • Romania
                                #175
                                thanks
                                ​try
                                I tried, but to no avail.
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1316
                                  • France
                                  #176
                                  freeze or not
                                  • claudi
                                    • Aug 2023
                                    • 5
                                    NM-C651
                                    NPCX897KA0BX
                                    try
                                    Do you have tips on how to try this out?
                                    I'm stuck on needing the internal display connected, but its cable cannot reach while I'm trying to access the bottom side of the board. I'm thinking I need to remove the panel from its casing but haven't done so yet.
                                    I've also had the charger port outside of its metal holder so I would be able to access the bottom side of the board that contains JDBUG1 while charging.
                                    • zomi
                                      • Nov 2011
                                      • 509
                                      #178
                                      Solder to the point then touch that to ground might be eaiser for you maybe
                                      • claudi
                                        • Aug 2023
                                        • 5
                                        NM-C651
                                        NPCX897KA0BX
                                        try
                                        Does not work
                                        • azanwaqas771
                                          • Feb 2019
                                          • 48
                                          • Pakistan
                                          #180
                                          Originally posted by claudi
                                          Does not work
                                          not unlock this model with this method
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
