Lenovo Thinkpad Ec Pwd Bypass
    Happy hunting brother
      Originally posted by Maxpower3 View Post
      edit
      after many try
      I managed to enter the bios, but the tabs are missing.
      Click image for larger version  Name:	441499388_881095270699214_2116687842734834106_n.jpg Views:	0 Size:	363.5 KB ID:	3279733 Click image for larger version  Name:	441409609_1406188906766540_432083223838718957_n.jpg Views:	0 Size:	336.0 KB ID:	3279734
      by the way, when I go through, with the 2 tabs, I have access to F9
      it loads well by default but the password is not cleaned.
      But I still have some access so I have to try to use the maintenance utility to initialize EC for testing.
        Originally posted by danito View Post
        Maxpower3 can you help me please for a t14 gen 3 NM-E981 with NCPX997 what should be done?
        boardview or schema ? not found
          Here boardview for this laptop
            thanks
            ​try
              Please do not post schematics or boardviews in the bios requests section.Post in in the "Schematic requests ONLY!" section , then you can post a link to it here.
ID:	3280024 Click image for larger version
                what is the latest version of the utility ??
                  https://www.badcaps.net/forum/troubl...r-bootable-usb
                    Latest is 3.5.64
                        So you managed to remove the password?
                          no but I notice that the password is bypassed,
                          I can boot via F12 without password.
                          but there is a protocol error (LenovoEeprom)​
                            Try the latest U1 tool. Hope you can initialize the EC.
                              not worked
                                thanks
                                ​try
                                I tried, but to no avail.
                                  freeze or not
                                    NM-C651
                                    NPCX897KA0BX
                                    try
                                    Do you have tips on how to try this out?
                                    I'm stuck on needing the internal display connected, but its cable cannot reach while I'm trying to access the bottom side of the board. I'm thinking I need to remove the panel from its casing but haven't done so yet.
                                    I've also had the charger port outside of its metal holder so I would be able to access the bottom side of the board that contains JDBUG1 while charging.
                                      Solder to the point then touch that to ground might be eaiser for you maybe
                                        NM-C651
                                        NPCX897KA0BX
                                        try
                                        Does not work
                                          Originally posted by claudi View Post
                                          Does not work
                                          not unlock this model with this method
