Lenovo Golden Key V3.5.60 - DMI EDITOR (BOOTABLE USB)
  • hypermk735
    • Jan 2024
    • 10
    Sharing the latest version of Lenovo Golden Key I found to change DMI information such as serial number, MTM, UUID. Run the U1 application and create a bootable USB. It may show an older version upon making the usb. Restart the program and it will update the USB to the next version available. For some reason the updater program does not upgrade all the way to the newest version, only incrementally until it reaches the latest. So do this, Open the u1.exe run the update, close the program, open and run again, close it and repeat until you get to the latest version 3.5.60.
    U1 Key Updater.ZIP has been removed
  • torinvoin
    • Jul 2024
    • cyprus
    Thank you, my friend! this utility helped to update the serial number on lenovo legion 5
    • waxwagner
      • Aug 2024
      • brazil
      Thanks a lot hypermk735​. You saved my life!!! For real!
      • system_fans
        • Sep 2023
        • 9
        • china
        Thank you very much. Does it support ThinkPad Machine?
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1599
          • France
          yes see list
          • system_fans
            • Sep 2023
            • 9
            • china
            Originally posted by Maxpower3
            yes see list
            OK thanks
            • ethics
              • Oct 2016
              • 39
              Thank you!!
              Saved my but!
              Cheers
              • lecong1986
                • Mar 2017
                • 20
                • vietnam
                Thank you verry much
                • RM2000
                  • Oct 2024
                  • Belgium
                  Can this be used on Lenovo 7x Yoga Slim ?
                  • Datashifter
                    • Oct 2019
                    What support tool would be needed for the T430? Asking as I do not see it in the list of supported machines...
                    • RM2000
                      • Oct 2024
                      • Belgium
                      I wanted to know if this tool can be used on the new Lenovo 7x Yoga Slim ( 14Q8X9 ) (Machine type: 83ED) to fix the issue myself, since Lenovo technician was not able
                      to repair it. If you can provide a newer version that would be great help
                      Thanks,
                      • RM2000
                        • Oct 2024
                        • Belgium
                        I have tried it with the latest version and getting error :
                        Directory: 'Trace' already exists
                        scrip error status: unsupported (line 74)
                        second time I tried then I got line 84 error.
                        Thanks for your help.
                          • 23852
                          What is the issue you are trying to fix
                          • RM2000
                            • Oct 2024
                            • Belgium
                            Long story short lenovo had replaced on site 3 times the motherboard due to hardware related issues and still they could not update the serial number in the bios. Now they want me to send the laptop to the depo but I can not so I wanted to fix this issue on my own. I still have issue when the battery is either fully charged or discharged with the power supply connected the system just reboots
                            It seems to be a again hardware issue so I had escalated the matter and the technician refuse to help an further.
                            Thanks for your support.
                            Regards,
                              • 23852
                              Regards,
                              Post your bios backup in a new bios request thread and we`ll have a look at it.
                              Edit: you can try the ThinkPad Config Information Update Utility https://www.badcaps.net/forum/troubl...24#post1622424
                              • thinkpadg6
                                • Nov 2024
                                • 5
                                while reading S/N data from EEPROM. I got
                                EEPROM Checksum error
                                EEPROM fail when reading or writing data.
                                • sudi test
                                  • Nov 2024
                                  • indonesia
                                  thank a lot friend. 😍
                                  • shanilmathew
                                    • Sep 2022
                                    • India
                                    Hi, I tried to update my serial number and I am getting the error , family name : not found. Can you help me, I am on the latest version.
                                    • itherogermany
                                      • Jan 2025
                                      Hey guys, could you please help me. For some reason the format tool is not working. The USB stick is correctly attached and the tool shows it, too. When clicking on the format tool button the popup appears with earasing all data and stuff but after accepting it nothing happens. What could be the reason.
                                      Thank you so much for your help.
                                      • Maxpower3
                                        Bad Veteran
                                        • Feb 2018
                                        • 1599
                                        • France
                                        look my post
                                        https://www.badcaps.net/forum/troubl...70#post3538670
                                        • coasterghost
                                          Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                          by coasterghost
                                          For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                          Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                          Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                          System Hardware:
                                          Processor: AMD Ryzen 7 PRO 5850U
                                          Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                          09-08-2025, 10:46 PM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • Boardview and Schematic Bot
                                          Lenovo 3000 Series Schematic
                                          Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                          3000 C100 laptop with Braille keyboard
                                          Lenovo 3000 C
                                          C100, C200 - 15-inch XGA screen
                                          Lenovo 3000 N
                                          N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                          N500 - 15.4 inch screen.
                                          Lenovo 3000 V
                                          V100, V200 - 12.1-inch WXGA models
                                          Lenovo 3000 G
                                          G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                          10-04-2024, 06:05 AM
                                          Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                          09-06-2024, 06:40 AM
                                          This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                          09-06-2024, 06:06 AM
