ESR meter upgrades
This is a sticky topic.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8753
    • Fixing Failed Fuhjyyus
    #961
    Re: component testers
    Not quite two zeners... at least to prove if it works properly.
    Plus these component testers don't directly do high voltage zeners either...
    Speaking of weird devices, it probably can't figure out tunnel diodes either.
      • 31557
      some testers have dc-dc convertors to test zeners upto 30 or even 50v
      i'm looking at one that may make a good starting platform, but it would still need a rotary encoder and a better cpu.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8753
        #963
        Right, but those dc-dc converters are not well suited for testing DIACs
        (Effectively the best thing for testing DIACs is a curve tracer type functionality...)
          • 31557
          well if the output was controlled by an analog pin on the cpu that could be done.
          • redwire
            • Dec 2010
            • 3916
            I reprogrammed AY-AT/ST7735 20MHz xtal and it seems to work fine. I have to play around with it more. It's a small font.
            ARVDUDE does not work with Atmel AVRISP MkII, it's a years old bug, something about the USB driver. Wasted hours going down that rabbit hole. In the end, I had to have Zadig rollback to its old Win7 USB driver to get it to work. Otherwise the usual "No USB device found" error in AVRDUDE
            I might get/make USBASP as a backup, with the 6-pin cable.
            stj thanks for posting the files.
            • ducky29
              • Dec 2015
              • 371
              • Europe
              #966
              Re: ESR meter upgrades
              Has anyone ever tried the GME model 236 sold by TEquipment.NET ? Does it test in circuit like it claims?
              • brethin
                • Dec 2008
                • 1907
                • Beer, Nookie, Computers
                #967
                Nothing can test in circuit accurately due to other components effecting it.
                • lotec25
                  • Feb 2015
                  • 5
                  So witch meter is best to buy at this time? I seen this one recommended a page back
                  https://www.aliexpress.com/item/32832292103.html
                  Is there a post that states what items are needed to mod it to where it can be used with the new firmware that has been written?
                    • 31557
                    that question depends on if you want to just use it,
                    or if you intend to do upgrades & stuff.
                    • lotec25
                      • Feb 2015
                      • 5
                      stj,
                      I would like one to upgrade and mess around with. Can you recommend one? and a link to what parts i should look for?
                        • 31557
                        hard to say right now.
                        i'm personally leaning towards the TC1 because it can take a bigger mcu,
                        now just to get it up to current standards it will need a rotary encoder and a new voltage reference (LM4040) just to start.
                        but as a base, it's nice - fully cased with a colour display and lithium battery inside.
                        there is lots of pictures and stuff here:
                        https://yadi.sk/d/yW8xa5NJgUo5z
                        • lotec25
                          • Feb 2015
                          • 5
                          How many pins does the rotary encoder need for the TC1?
                            • 31557
                            the same as any other, 2.
                            but they are shared with the other things anyway - pincount is not the issue - size of the flash is.
                            all the cheap testers have 32k, we want more than that.
                            now here is the issue, most testers use the atmega328p and that has 32pins.
                            we cant get a better chip with that pincount.
                            the tc1 is different - it uses the atmega324 and that has 44pins.
                            we can get 64k chips in that package.
                            • Per Hansson
                              • Jul 2005
                              • 5897
                              • Sweden
                              #974
                              The M644 based one is nice if you want to have a full-featured model.
                              I have bought one and really like it, I have not tinkered with the firmware on it though.
                              Vince linked this one a page back, I bought mine on eBay but that auction does not exist anymore...
                              https://www.aliexpress.com/item/M644...912063006.html
                                • 31557
                                i looked at that one before, on banggood.
                                not bad but no colour display.
                                i want colour display because it has better contrast and a noticably higher resolution.
                                • TheOnlyDocc
                                  • Sep 2016
                                  • 8
                                  I hope you can help me. I am searching for a new Tester. After moving to a new location i can not find my old gm-328 (modded with new quarz. . . .).
                                  I am not planing to mod the new one. But i was checking what is available out there and found a version with PWM Generator (would be helpfull when working with leds /modding led circuits). https://www.banggood.com/de/9-12V-DC...r_warehouse=CN
                                  But the version i found on Banggood seems to have some problems (comment from the reviews:firmware don't fit with the resistors divider/The software came as version 1.13k but there are much newer versions available
                                  • Jatsekku
                                    • Jun 2020
                                    • Polska
                                    #977
                                    Hi guys! Could someone point me out the newest version of tester (hardware and software as well)? Maybe the newest is not a good term, I think most advanced version will be better description.
                                    I would like to develop new version based on STM32, but there is so many version as far that I don't even know which one I should treat as reference for my design.
                                    • Per Hansson
                                      • Jul 2005
                                      • 5897
                                      • Sweden
                                      #978
                                      The idea behind the "transistor tester" project is to make something with as few external components as possible perform the required job.
                                      In the case of the tester this relies on a 5v compatible ADC.
                                      The STM32 is much more expensive, and also a 3.3v device.
                                      I'm not saying it can't be done: of course it can, but it takes the project in a different direction than what the authors intended.
                                      As for the "latest tester" or "best tester" this rotinely comes up over at the long eevblog thread.
                                      I think the M644 based version I linked in my previous post above hits a good balance of cost vs features.
                                      But it of course depends on what features you want, there is for example the BSIDE version that I have too, in a quite nice case.
                                      But it uses the regular Atmega 328 controller instead.
                                        • 31557
                                        if you want to build one, start here:
                                        https://www.mikrocontroller.net/svnb...nsistortester/
                                        but arm based chips wont work, they only have 3.3v outputs - you need 5v
                                          • Jul 2011
                                          • 6079
                                          • Soldering Junkie
                                          #980
                                          Is a better ESR meter than the blue meter that I have now
                                          I am not really looking for a component tester at this point
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
