Try our *UPDATED* boardview, bios, & schematic search. Over 2.3 million files for download!
ESR meter upgrades
This is a sticky topic.
    Posted Photos 132 Photos
  • masterprince123
    Vintage Dick Smith ESR & Low Ohms Meter Bob Parker not working
    by masterprince123
    Hi All,
    I am the fortunate owner of an original K7204 ESR Meter, and it is a pleasure to have such a wonderful piece of equipment. I purchased it from eBay, although unfortunately it had not been used for many years.
    I am experiencing an issue with the meter. As soon as I power it on, the display shows “EA” or you can say stuck in EA. if I try to power the meter off it doesn't do anything at all.
    When I touch the two probe leads together to perform the zeroing, the displayed numbers jump randomly. Once I separate the probes, the display then becomes stuck...
    10-04-2026, 07:17 AM
  • chth96
    Is it possible to test small ceramic disc capacitor with analogue meter?
    by chth96
    I read EBOOK of Testing Electronic Component and found that
    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
    Is it really possible to test small ceramic disc capacitor with analogue...
    03-09-2024, 10:03 PM
    Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
    by sam_sam_sam
    I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
    I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
    12-31-2023, 06:04 AM
  • Ryan Wurtz
    Lenovo Yoga C740-15IML 5V on usb meter.
    by Ryan Wurtz
    Hello. So I searched and didn't find any posts on this specific problem.
    When plugged in USB power meter reads 5v
    Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
    Original mobo had a shorted cpu it seems.
    So I decided I need a new motherboard.
    Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
    5v on the meter. Still won't charge. Can still charge the battery...
    11-24-2025, 01:08 AM
    How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
    by sam_sam_sam
    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
    12-14-2023, 07:45 PM
