I read EBOOK of Testing Electronic Component and found that
"In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
Is it really possible to test small ceramic disc capacitor with analogue meter?
And There is many analogue meter in aliexpress which only need two 1.5v AA size battery or It need 9-volt battery as well as two 1.5v AA size batter.
But In order to 12v output from the probe for testing 10kohm ,should I purchase analogue meter which need two 1.5v AA size battery and 9-volt battery like below analogue meter from aliexpress shop?
https://www.aliexpress.com/item/1005005511902269.html
