How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
    • Jul 2011
    • 6070
    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer power supply ( 5 volt power supply )
    Well this where it gets a little bit hairy with the maintenance/technician that I work with because they just kept putting fuses in it and getting the same exact results simply because they do not understand how to troubleshoot a situation where you keep blowing fuses and these fuses are not cheap around $20.00 each
    I told my boss that the only way you are going to get anywhere with this price of equipment is to remove one wire at a time until you find the wire that has the short on it with a Ohm meter and a ESR meter to know what the actual resistance is not what the multi meter is telling you
    Now my boss understood this concept because he had done this in the automotive mechanic and done this before as well but had not done this with a piece of equipment with a 110 volt control circuit which I have done this several times before in the past
    It turns out that the gas valve / flame detector controller has a dead short 2.3 ESR reading that reading told me more than the multi meter was telling me
    I have use this combination before on another machine where I used to work at that was blowing fuses as well
    Once I removed the wire from the gas valve / flame detector controller and reconnected the power supply with the incandescent light bulb instead of the fuse the light bulb was only dim ( because before the light bulb was as bright as it would be plugged into an outlet) and the machine controller came back to life and I do not know if anything else is wrong with this machine tomorrow is another day
    This one big reason why using an incandescent light is definitely your friend in situation like this
    I hope this helps someone else that finds themselves in a similar situation and use this method of troubleshooting because it might help you from going down a deep rabbit hole that just doesn't make no sense about what is going on
    • Jul 2011
    • 6070
    How an incandescent light bulb and a ESR meter is your friend when you have a machine blowing fuses on the 120 volt control circuit
    For some reason it would not let me post this that is above and it is not allowing me to correct spelling errors either if go back and hit edit I can see it but for some reason when you hit save it did not save it I had to make another post
    Now my boss has use this method of using an incandescent light bulb to troubleshoot a problem with blowing fuses in a automotive type of setting but had never done it in a machine type setting before but he let me have at it because his boss was getting a little inpatient with this machine being down
    Luckily the manufacturer of this equipment made it easy to figure out where the 120 AC volt section is located because all the wires are red the 24 volts DC are blue and I think if I remember right the 5 volt DC are gray one note we do not have the right wiring diagram for the model number that we have because apparently the serial number matters on this machine to get the right one
    Unfortunately the wiring diagram does not show the wire number which is really shit-ie which is why you can not know where a wire goes unless you physically chase it from one end to the other end really are you kidding me this does not make your life or job easier by no means
    Update we got the piece of equipment repaired today and we are back in business with this nightmare
    Now we have another nightmare with another piece of equipment that I think has a bad IO card in the PLC because the fault light is ON for the IO cards but I think we narrow it down to which card is because of what is not working correctly
    Update on the feeder it appear to have a bad safety relay and who knows what else is wrong this equipment but unfortunately we do not have one on the shelf at the moment
    One note some of the equipment are 20 years or older and we do have some equipment that is a lot newer but the older ones are ones that are nightmares because they have been around so long that they really need to be retired and put out of their misery and mine as well
    • Sik_6ty_Sixx
      HH Scott Model A510 Stereo Integrated Amplifier/ Graphic EQ - Blowing fuses in the LEFT speaker channel only. Any Help???
      by Sik_6ty_Sixx
      So like the title says, I have an old Stereo Receiver/Amplifier that I picked up from the goodwill, it's a HH Scott Model A510. When I first got it home it had zero output. Opened it up, notice the fuses are missing. Pop in 2 new fuses (AGC4A 250V) and try again, within 5 seconds the L channel fuse POP! I don't see any visible indications of damage or arc burns on the PCB, no popped resistors or diodes, no burnt traces or blown out caps. So I decide to just try another new fuse, POP. Swapped around my R and L speaker wires, and checked the integrity of all wires and connections. Everything looks...
      02-18-2025, 05:06 AM
      Surface Mount Fuses Fundamentals Datasheet
      TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
      TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
      10-07-2024, 06:07 AM
    • mon2
      Gemsound PAX-105 Audio Amp blowing fuses
      by mon2
      Hi. New to this side of the forum.
      Have an audio amp (Gemsound PXA-105) that keeps blowing the 3A fuses upon power up. Owner stated that the amp was on when he plugged in the input (mixer board) and that started this chaos.
      Would a schematic be available? Advice on what to check? Power supply / output amp transistors? Do see the power on green led turn on for a brief moment before the fuse blows.
      Thanks.
      10-30-2024, 08:33 AM
      1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
      by sam_sam_sam
      I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
      This metal lathe has a weird motor setup it has a soft start motor with a ā€œYā€ and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
      12-29-2024, 07:18 AM
    • chth96
      Is it possible to test small ceramic disc capacitor with analogue meter?
      by chth96
      I read EBOOK of Testing Electronic Component and found that
      "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
      Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
      It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
      Is it really possible to test small ceramic disc capacitor with analogue...
      03-09-2024, 10:03 PM
