ESR meter upgrades
This is a sticky topic.
    • 31553
    Re: ESR meter upgrades
    what cpu is in it?
    • jellytot
      • Mar 2015
      • 42
      • Ireland
      #1122
      Atmega 644p
        • 31553
        good - because the replacement software wont fit a 324
        this is actually built for a 1284 but it should work i think
        it expects a 20Mhz crystal
        changed config files are included for viewing
          • 31553
          i forgot to say,
          you need to reprogram the 8 pin microcontroller that controls power, or replace it with a small circuit
          • jellytot
            • Mar 2015
            • 42
            • Ireland
            #1125
            Thank's Stj have you found this better than the original.
              • 31553
              yes,
              lots of new features.
              but the biggest thing was the circuit for power.
              the original 8pin microcontroller seemed to not go into sleep-mode sometimes and was draining the battery
              • Rado108
                • Jul 2023
                • Croatia
                #1127
                Which ESR meter would you reccomend for testing caps in vintage solid state audio gear? Do i need LCR so i can measure at different frequencys?
                  • 31553
                  vintage and solid-state arent 2 words you often hear together.
                  you mean 70's and 80's ?
                  • chth96
                    by chth96
                    03-09-2024, 10:03 PM
                    12-31-2023, 06:04 AM
                  • Ryan Wurtz
                    Lenovo Yoga C740-15IML 5V on usb meter.
                    by Ryan Wurtz
                    Hello. So I searched and didn't find any posts on this specific problem.
                    When plugged in USB power meter reads 5v
                    Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                    Original mobo had a shorted cpu it seems.
                    So I decided I need a new motherboard.
                    Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                    5v on the meter. Still won't charge. Can still charge the battery...
                    11-24-2025, 01:08 AM
                    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                    12-14-2023, 07:45 PM
                  • jorpec
                    by jorpec
                    Hi
                    Thnaks
                    01-23-2023, 10:37 AM
