  • chth96
    • Nov 2022
    • 118
    • indonesia
    Is it really possible to test small ceramic disc capacitor with analogue meter?
    And There is many analogue meter in aliexpress which only need two 1.5v AA size battery or It need 9-volt battery as well as two 1.5v AA size batter.
    But In order to 12v output from the probe for testing 10kohm ,should I purchase analogue meter which need two 1.5v AA size battery and 9-volt battery like below analogue meter from aliexpress shop?
    https://www.aliexpress.com/item/1005005511902269.html
    • 32066
    you can test a ceramic for shorts,
    but the small square ones are multilayer and i never seen one shorted.
    no meter has 12v output btw,
    they only use 2-3v or they would damage chips
    • chth96
      • Nov 2022
      • 118
      • indonesia
      Thank you very much for reply!
      I heard that some analogue meter make use of 9v battery as well as two 1.5 volt battery in order to measure 10k ohm range resistance.
      I read EBOOK and it says that
      "You have to select your analogue meter to x10K ohm range to test the diode.The output voltage of x10k ohms is about 12 Volt(1.5 volt+1.5 volt+9 volt=12 volt)
      the diode under test should show only one reading,If the meter showed one reading,the diode is good.If it has two readings the most probably the diode is shorted or leaky.The digital meter can't test it because the output from the meter is only about 500mv to 2 volt."
        • 32066
        well that book probably came from 1966,
        was the meter an AVO8?
        • chth96
          • Nov 2022
          • 118
          • indonesia
          It is not ancient book which have been published before my birth(I'm in late 30's​)
          This book have been published about ten years ago by famous electronics repair engineer from Malaysia.
          and the author of this book used Sunwa YX360TR analogue multimeter as an example
            • 32066
            well if the cap is in-circuit and you put 12v across it then you also put 12v across everything else.
            that probably expects 5v or 3.3v or even less.
            • PeteS in CA
              • Aug 2005
              • 3591
              • USA, Unsure of Planet
              • Reading, Education, History, Christianity
              The Fluke 87 DMM I use is powered by a 9V battery, but the voltage for testing resistance is limited to 2V or so. As for testing capacitance, what a DMM can test is best learned from the DMM's specifications. I haven't used my Fluke 87 to test capacitance. AFAIK, an ordinary DMM doesn't test ESR or impedance.
              PeteS in CA
                • 32066
                no, multimeters only do a rough capacitance test using current-over-time method to see how much it charges up.
                • vladimir1909
                  LlamaTester Alpha V0.1 Macbook Quick test
                  by vladimir1909
                  I would like to share a small MacBook diagnostic application that I've been developing. The goal of this tool is to provide technicians and repair enthusiasts with a simple way to test and gather information about a MacBook. Current features
                  • Display test
                  • Keyboard test
                  • Camera test
                  • Audio test
                  • System overview with relevant hardware information
                  • Charger and power adapter information
                  The application currently works on macOS Monterey and newer versions.
                  Please note that this is still an alpha release, so you may encounter bugs or incomplete...
                  07-09-2026, 12:07 PM
                • PatElectron
                  Denon AVR-X1400H — no audio from any source, internal test tone OK, no HDMI output, "Assigning" phase at every boot
                  by PatElectron
                  I bought this AVR-X1400H (E2, Europe) cheap as faulty, to repair. Seller said it died suddenly: no sound, no picture, headphones silent too. I have the service manual and a **working AVR-X1500H** on the bench as a reference. I've done a fairly complete diagnostic already — full details below so nobody wastes time on ground I've covered.
                  Symptoms
                  - No audio from any source: HDMI, USB, network/HEOS, analog IN1 and IN2, tuner. Nothing, on any input.
                  - The internal DSP test tone plays correctly** through the speakers, on every channel.
                  - No...
                  09-10-2026, 09:11 AM
                • ahmedtou
                  HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                  by ahmedtou
                  help me please
                  I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                  When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                  I will share all the details with you, including the disc information.
                  Code:
                  HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                  Current Profile: BD-R
                  Disc Information:
                  Status: Empty
                  State of Last Session: Empty
                  Erasable: No
                  Free Sectors: 12,219,392
                  Free Space: 25,025,314,816 bytes
                  Free Time: 2715:27:17 (MM:SS:FF)
                  Next
                  08-27-2025, 08:49 AM
                • Junior††
                  PS5 Disc Not Supported/ Disc Not Recognized Board Num: EDM-020
                  by Junior††
                  Good Afternoon fellas,
                  Issue:
                  Disc is showing as not supported when a disc is put in.
                  Here's what I've done, you can skip this if you just wanna know the question:
                  - replaced with a disc drive from a donor ps5 (honestly questionable if this is known to work)
                  - reflowed the disc drive connector
                  -reflowed the chip in question (shown on image)
                  - I will say this console was very dusty so it's conceivable that it got so hot that it made the chip joints cold and potentially other things on the board
                  Question:
                  I...
                  02-19-2025, 12:48 PM
                • flat-earther
                  LED VS incandescent light bulbs
                  by flat-earther
                  There was a period when I changed to LED lights, they use much less power than incandescents, which was appealing.
                  But then I learned about some downsides of LEDs, such as blue light, and another one that I've seen called by several names, high frequency voltage transients, dirty electricity. EMI, microsurge electrical pollution, harmonics, dirty power, high frequency noise on wiring.
                  The wiring in houses should only have 50 or 60Hz, but allegedly the high frequencies induced onto house wiring from LEDs and other devices that create the electrical pollution are in the thousands...
                  06-25-2026, 11:17 PM
