Need help with Samsung LN40E550f7f
    • 12276
    • U.S.
    #61
    Re: Need help with Samsung LN40E550f7f
    Ok can you jumper blu_on a5 and and ps on together?
      • 12276
      • U.S.
      #62
      Originally posted by Kindred1
      Jumped it. No backlight.
      You jumped it plugged in tv and turned on tv right?
        • 12276
        • U.S.
        #63
        no luck?
          • 12276
          • U.S.
          #64
          Starting to suspect your power supply board.
            • 12276
            • U.S.
            #65
            Theres some power supplies on ebay for 75 bucks, seems too high for a 40 inch tv tho. explains why theres so many lol. when you can find tvs on sale for 200 or so, thats like half the price of a whole tv.
            • Kindred1
              • Feb 2018
              • 55
              Yes I did.
              • Kindred1
                • Feb 2018
                • 55
                Just to be clear, blu_on, A5 and PS_on?
                • Kindred1
                  • Feb 2018
                  • 55
                  I've found them cheaper. I just want to find out why the BLU_on is 0 volts.
                    The BLU_ON is from the main board.
                    >2.5VDC = Backlights circuit ON
                    <1VDC = Backlights circuit OFF.
                    So when you disconnect the cable from the power supply board to the main board and use the resistor between A5V and BL_ON is to simulate the ON signal.
                    Per your reported reading on the PS-ON pin and the DIM pin without the cable connected those signals are present due to pull-up resistor built into the power supply board, so that part of the power supply board is OK. If you look at the BL_ON pin right now with the resistor in place, you should then see >2.5V on that pin due to the resistor is being use to simulate the bl-on signal, it is present, right?
                    • Kindred1
                      • Feb 2018
                      • 55
                      Hi Budm. - So you're saying with the jumper in place between a5 and blu-on, ( connected to the cable that connects to the main board) Check blu_ on for >2.5volts?
                        Yes.
                          BTW, that white fuse next to the main filter caps are OK, right?
                          That fuse provides 380VDC boosted Voltage to run the Inverter circuit.
                          I hope you do not have two problems:
                          1) Main board not sending BL-ON signal.
                          2) No backlights when forced on.
                          • Kindred1
                            • Feb 2018
                            • 55
                            I must not be checking the right spot. I put the lead on blu_on pin at the power supply and get 5.17. My meters lowest setting for ohms is 200. I'm going to get my toner that has continuity tester.
                              Since you are not using the resistor on the the BL-ON pin thus it will show the same Voltage reading as A5V, the bottom line is that BL-ON pin is showing >2.5V which is more than enough to turn on the circuit.
                              • Kindred1
                                • Feb 2018
                                • 55
                                fuses are good
                                • Kindred1
                                  • Feb 2018
                                  • 55
                                  O.K. So, what's my next step?
                                    Just to be sure with the test setup as it is right now, please verify that you do have about 380VDC between the two legs of the main filter cap (you can shcek on either one of them since they are connected in parallel).
                                    • Kindred1
                                      • Feb 2018
                                      • 55
                                      Both reading 368v. With jumper still in place. Now I may have misunderstood directions early on. I reconnected power to main, but one end of jumper in the blu_ on lead in the plug. I do get proper voltage. Both ends. Sorry if I screwed up.
                                        "but one end of jumper in the blu_ on lead in the plug. I do get proper voltage. Both ends." I do not understand, so you have jumper install between BLU_ON pin and the A5V pin while the cable between the power supply and the main board is still connected?
                                        • Kindred1
                                          • Feb 2018
                                          • 55
                                          No. Forget the 'jumper'. What I meant was used a piece of wire to get get access to the pin ( in between plug housing and wire) because my meter leads are too big. The used a meter to get a reading off the wire. - When I mention misunderstanding directions, I was referring to when you first had me checking voltages off the board early in this thread.
                                          • Nicktronic
                                            Samsung Power Supply Board BN44-00874F
                                            by Nicktronic
                                            Hey everyone,
                                            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                                            Anybody...
                                            03-17-2025, 06:20 AM
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • repair-it
                                            Need advice testing a samsung power supply board with scope
                                            by repair-it
                                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                            07-12-2025, 11:00 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
