Philips 37PF7321/98 cannot turn on
  • selldoor
    Slow Learner
    • 7870
    Re: Philips 37PF7321/98 cannot turn on
    I am trying to get my head around it Its quite a complicated circuit (for me) perhaps
    need to wait for budm or bammbammfran to come back at those voltages it would be unwise to guess!
    • bammbammfran
      • Apr 2014
      • 476
      It seemed like you HAD power since your front led of the monitor were lighting
      but 63volts on your main caps says otherwise
      6307 is the main bridge rectifier and should have full power
      check the two end pins against each other for DC on the 6307 bridge rectifier
      the 1350 relay looks like power is going through it if it has power to pins 2 and 3
      1 and 4 are probably the switching pins (what plugs into the small jack that is next to it ?)
      • bammbammfran
        • Apr 2014
        • 476
        If I am looking at things correctly ??
        It looks like this power board will not show power as a stand-alone board
        looks like 6306 creates a bit of power and sends it to the main board through the 1315 fuse and the 1306 black connector and then the main board sends it back to the relay via the 1305 white connector and then the relay sends power from pin 3 to pin 2 then to the 2nd pin in on the main bridge rectifier at 6307 (since it isn't marked , lets let pin 1 of the bridge rectifier be the one that is closest to the boards edge)
        so if those two wires are connected, you should have 240ac at the bridge rectifier center pins
        • selldoor
          Slow Learner
          • 7870
          That is partly what I thought though I think the Main/standby/audio board
          may just send 5 volts back to the relay ( as it it only rated for 5v?)
          Then when the relay works it switches on the rest of the 240v circuit which charges up the main caps and fires up the Inverter?
          • john_doe
            • Apr 2013
            • 192
            • Malaysia
            The black jack 1306 has 342vDC and goes to the standby/audio board.
            • bammbammfran
              • Apr 2014
              • 476
              342 volts !!!!
              That doesn't sound right ??did you check it using just the 2 pins in that jack (pos to one and neg of tester to the other)
              what is the numbers on the small black 4 pin chip at 6306
              • john_doe
                • Apr 2013
                • 192
                • Malaysia
                #27
                Originally posted by john_doe
                For 6307,the AC and DC voltages are almost zero. Shouldn't it have 240vAC as the pin2 and pin3 of relay 1350 has 240vAC.
                I don't know whether this help or not. When I plug in all connectors to the power board, on the 6307 rectifier, pin 2 and 3 has 11vAC and pin 1 and 4 has 61vDC and decreasing slowly.
                • bammbammfran
                  • Apr 2014
                  • 476
                  I have a feeling you may not be using the tester correctly or it needs batteries
                  either way we need to start at that 1306 connectors
                  if you had 342 volts there, it would have blown that small cap clear out of the board (I doubt that is a 400v cap!) and it probably would have blown that 250v fuse
                  • john_doe
                    • Apr 2013
                    • 192
                    • Malaysia
                    #29
                    342 volts !!!!
                    With all connectors plug into the power board, the pins at 1306 has 338vDC. The DC pins at 6306 also has 338vDC. Yes, pos to one leg and neg of tester to the other leg.
                    6306
                    DF06 -> 1st line on IC
                    635A -> 2nd line on IC
                      Please tell us what point on the board you are using for the Ground ref point when you are making voltage measurement in the primary side and in the secondary side of the circuits?
                      • john_doe
                        • Apr 2013
                        • 192
                        • Malaysia
                        #31
                        I double check, it is 338vDC at 1306 connector. I hope I did not use the tester wrong and wasted your time. I attached the tester. It is a new tester. How should I test that it is working correctly?
                        • john_doe
                          • Apr 2013
                          • 192
                          • Malaysia
                          #32
                          I am very new with this stuff.
                          For DC, I use the chassis as Ground ref and touch the pin that I want to measure. For AC, I touch pos probe on one pin and neg probe to the other pin.
                          I hope I am not wasting everybody's time.
                          • bammbammfran
                            • Apr 2014
                            • 476
                            I am not familiar with that meter. Mine are not auto-ranging
                            Check your house receptacle to check ac
                            and a standard battery or car battery to check the DC
                            hey Budm, does that sound right to you that the small DF06 bridge rectifier is pumping out 340 volts dc and that the audio/standby board is changing it to 5 volts dc to turn on the power supply relay ?
                            Can't find enough in DF06 datasheet
                            600v rated, 1.1 v forward voltage max and 1.5 amp
                              "For DC, I use the chassis as Ground ref and touch the pin that I want to measure"
                              Well, when he is making that DC reading in the primary side of the circuit he should never use the chassis as the ground ref point, that is why his readings in the primary side are invalid, he need to use the negative leg of the main filter cap as the ground ref when making DC voltage reading on the primary side, the secondary side he can use the chassis ground.
                              I work on this model before so I will have to look at the SCH again to give him the test points.
                              • bammbammfran
                                • Apr 2014
                                • 476
                                OK
                                I just looked at that fuzzy picture of the audio/standby board and it looks like it has an AC section and a transformer to DC section, so 340 +- may be correct
                                SO
                                Hook the power supply to the audio/standby board with those two wires and check the two pins on the relay to see if it is getting 5 volts of DC
                                The relay should click on
                                Check with tester pin 1 to pin 3
                                If that is ok
                                check for power again on the main large caps by putting the tester pins on the two pins on one of the large capacitors
                                • john_doe
                                  • Apr 2013
                                  • 192
                                  • Malaysia
                                  #36
                                  I am getting 0v on the relay at pin 1 and 4. As soon as I plug the power supply board to 240v, there is a click sound and pin 2 and 3 has 240vAC. This relay should be normally open, right? So pin 2 and 3 should be open, right?
                                  Is this relay bad?
                                  When I touch neg probe of tester to neg leg of Big Cap and the pos probe to pin 1 of 1306, there is 0.2vDC. Same for pin 4.
                                  • john_doe
                                    • Apr 2013
                                    • 192
                                    • Malaysia
                                    #37
                                    I put the neg probe on the neg leg of one of the 2 Big Cap, the reading at 1306 is 140vDC on one pin and -80vDC on the other. Is these measurement correct?
                                    • bammbammfran
                                      • Apr 2014
                                      • 476
                                      I believe it should be open and that when 5 volts gets sent to pins 1 and 4 (one would be + and one would be -) then 2 and 3 would connect.
                                      If it for some reason connected as soon as you plug power in
                                      and you are getting 240 at the pins. then the power should be going through it and you should be getting 340 at the large bridge rectifier and at your large caps.
                                      since we are checking 240 and there is no ground on the main power side of the board to work with: Use your black probe of your tester on the main fuse, then probe pin 3 of the relay, then check to see if that same voltage is on pin 2 of the relay and on pin 2 of the large bridge rectifier
                                      then unplug the white plug by the relay and check these again (leave the black plug in)
                                      TIME FOR SOME SHUTEYE !!
                                      • john_doe
                                        • Apr 2013
                                        • 192
                                        • Malaysia
                                        #39
                                        Goodnite bammbammfran.
                                        When I touch neg probe of tester to fuse 1314 and pos probe to pin 3 of relay 1350, there is 240vAC. If I touch pos to pin 2 of relay, there is 0.8vAC.
                                        Neg probe to fuse and pos probe to pin 2 of large bridge rectifier 6307, I get 1.25vAC.
                                        With the white connector unplug, pin 2 and 3 of the relay have the same reading as above. Pin 2 at large bridge rectifier 6307 has 0.8vAC. But there is no click sound.
                                        • bammbammfran
                                          • Apr 2014
                                          • 476
                                          is it morning already !!
                                          Looks like the relay might not turning on
                                          and it is not letting the voltage go to the large bridge rectifier
                                          before , you said it had power at both pins, but you were probably probing these two pins incorrectly (possibly at the same time ?)
                                          since it does click, the voltage should be getting to it from the other board to 1 and 4 even though you did not get a reading the first time. (Did you unplug the small white plug while the power plug was in or did you unplug it then plug the power in)
                                          IF you unplugged it first: try to unplug it while the power is plugged in to see if it clicks and then plug it back in while the power plug is in to see if it clicks again.
                                          If it does not click on and off, you can try an external 5 volt source to the pins 1 and 4 of the relay(old phone adapters are around that or 4 AA batteries end for end with two wires)
                                          FYI: IF you notice on that power board on the top side there are lines with slashes across them on the top and on the bottom there are similar in the areas that are not green.
                                          these are separations between high voltage and low voltage areas.
                                          SO, that makes the relay on a low voltage side.
                                          So, if a board is loose, when you check for DC on low voltage sides, you need to use a low voltage side ground (easiest to do is usually a negative/ground pin of a capacitor)
                                          and on high voltage sides and high voltage cap.
                                          If the board is mounted on a metal frame, you can usually do low voltage using a frame as ground which is why they have the screw areas also marked off as low voltage side, BUT, in this case , I do not see grounding pads on the screws to allow this ?
                                          • JorKsX
                                            Philips 47pfl6008s wont turn on
                                            by JorKsX
                                            Hello. Got my hands on Philips 47pfl6008s/12.
                                            Problem is that it does not turn on. Last owner said the problem came slowly.
                                            One day did not respond to remote, had to unplug from AC and then back and it worked. next day had to disconnect 3-4 times before it turned on.
                                            And then it went into hours of unplugging and replugging until it turned on.
                                            When I plug AC into tv, it does not respond to "turn on" button or anything else.
                                            After 10-15minutes the TV starts blinking red LED twice.
                                            So it blinks twice, then waits 3 seconds, then again twice...
                                            02-13-2022, 03:36 PM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • ovrax
                                            Philips 55PUS6804/12 turn on & off (probably backlight issue)
                                            by ovrax
                                            First of all, please excuse me as I'm quite new to this field.
                                            I have a Philips 55PUS6804/12 TV. It turns on and off instantly (backlight flash). I personally think it's a backlight issue (faulty LEDs). Could you help me confirm my diagnosis?
                                            I've checked and the T-CON seems to be fine. I disconnected one ribbon cable at a time at the bottom, but the problem persists.
                                            The Ambilight works perfectly and stays on.
                                            No sounds.
                                            Thanks in advance.
                                            08-25-2024, 04:33 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • robante15
                                            Acer Aspire 4520 won't turn on after reboot
                                            by robante15
                                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                            If I remove the...
                                            04-06-2024, 06:50 PM
