Sony LED 65X9005A shuts down after few seconds - looking for help
  • tec3000
    • Mar 2024
    • 119
    Yes, Diah told me the same. So I can't just remove the boards.
    And to test in diode mode I still need to detach the screen from the rest. So right now I don't know how to proceed.
    Originally posted by Diah
    Nothings Impossible, but you need to make plan first and as other said patient.
    Plan first where you can hold the LCD Panel after you take it out for long time until you finish the repair..
    second right now you can disconnect the 4 ribbon cable from T-CON to panel from T-CON side.( be careful the ribbon old the contact pins easily damaged ) then turn on.... you will see the LED BL come on. this mean after you took the panel out you can always switch the TV ON and check if yours work on BL are correct and all lit on.
    third after you take out the panel.... try to take all light filters sheets at once and keep them tight in same order and remark the top one corner to let you easy put them back at same place and order after you finishing the work.
    fourth , the solid reflector plate ( which are the bottom ) in some Sony Model they use 2 pieces clued with transparent Type. be cardull when you handle it and mark its position as it could had different surface as top and down.
    that's all..
    later 2016 Sony used double LED for edge, also after you have access to LEDs here allot of people will help you to know the kind / Type of the LEDs you have... on Aliexpress you can buy 100 pieces just for 5-6 $, so you can change all at once or if you find strips ready mounted will be better..
    • EazyBone
      • Jun 2023
      • 1321
      • United states
      #102
      I never remove any of the boards when doing backlights. Also. As Davi said, plugging it in will or ve useful after screen is off. Donny seems to be quite the cautious guy. I have done maybe 100 backlights and never damaged a board while it's on back, just don't move it around like it's gym weights. Looks like your gonna have fun
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4318
        • Italy - Milan
        #103
        Actually i was saying diode mode test on the mosfets on the Led control board..
        • Diah
          • Feb 2013
          • 6363
          don't remove the boards , just remove any plate as the one at the top and at the corners... the reset will be clips to release the bezel as i can see from the photo..
          try to draw the TV back on blank A4 paper and locate each screw you are open ,mark them on yours drawing place of it,,,,,
          Click image for larger version  Name:	1711719981237.jpg Views:	0 Size:	5.78 MB ID:	3244431
          • tec3000
            • Mar 2024
            • 119
            Diah
            thank you for marking the spots on the TV. I have uploaded yet another pic. Do I need a special tool for these? I don't see how I can remove the plate at the top. There is nothing to screw?
            • Diah
              • Feb 2013
              • 6363
              Originally posted by tec3000
              Diah
              okay, if there no screw then its just piece to add strength to chassis to being straight... however the bezel should hold on it by clips.. so leave any plate pieces mounted on chassis which there no screw
              • Diah
                • Feb 2013
                • 6363
                check yours PM
                • tec3000
                  • Mar 2024
                  • 119
                  Happy Easter guys!
                  I was able to remove the frame from the back of the TV. My TV is a bit different though. I couldn't even use the suction cups. I simply took out the entire back out of the frame. Tomorrow I will get down to the LEDs. But I plugged in the TV and indeed half of the screen turned dark. So it's confirmed!
                  It's not all good news though. No idea when and how but I did some harm to the top of the panel.
                  No idea what the real world implications are going to be. I guess the i-Manual will give me an idea what I can expect from the TV from now on. I'll definitely assemble everything back and have a look.
                  Looks bad guys, right? I know I messed up but I still want to buy the LEDs. Should I go ahead?
                  • EazyBone
                    • Jun 2023
                    • 1321
                    • United states
                    #109
                    What am I looking at. What are these holes on the black thing?
                    And where is picture of panel damage. If you effed the screen I wouldn't proceed no. I would still break it down to the LEDs and have a look and then put it all back together again as some practice. Do it as if you didn't damage the panel so you can learn.
                    • tec3000
                      • Mar 2024
                      • 119
                      Those holes are just placeholders for the speakers beneath. I had uploaded pics of my TV but here someone else's set where you can see what it looks like from the front. (Pic 1)
                      And I have circled the area with the panel issue. The glass is not broken or anything. It's somehow beneath the coating. Really not sure how it happened and what it is? (Pic 2)
                      • Diah
                        • Feb 2013
                        • 6363
                        this is look like air between the LCD and the front glass. .. don't bother with it right now. complete the access to LED strips
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4318
                          • Italy - Milan
                          #112
                          Please.. 8000x6000 pics are way too much.. my pc goes nuts.. scale down them..
                          i can only view the reduced versions.. obviously this is a model with front covering glass with flat surface finish that inglobates speakers.. the way you put it on the sofa is wrong, must be front faced down.. so it doesnt unglue the real LCD.. actually front piece is maybe plastic and lcd is havier weight glass
                          • tec3000
                            • Mar 2024
                            • 119
                            yeah, no worries. I have uploaded a smaller pic.
                            So should I move the front that's on the sofa or no need?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4318
                              • Italy - Milan
                              #114
                              so, the front side face down, better..
                              • tec3000
                                • Mar 2024
                                • 119
                                I see. You mean flat. That's how it was over the weekend and those air bubbles emerged all of a sudden. Weird right...
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4318
                                  • Italy - Milan
                                  #116
                                  was the sitting surface really flat? maybe the valley between sofa elements... hoping that remounting it is barely noticeable..
                                  • tec3000
                                    • Mar 2024
                                    • 119
                                    It wasn't on the sofa. It was on the ground. However, I put a soft gym mat under it. It didn't cover the entire panel, so I was able to move it around as needed. I'm thinking maybe it happened while I turned it every now and then... Just a theory.,
                                    • tec3000
                                      • Mar 2024
                                      • 119
                                      SO GUYS.... I was finally able to remove everything. I'm a bit surprised.
                                      1) I only see LEDs on each side of the TV. Nowhere else. Nothing in the center... Is that expected? Or do I still need to remove more?
                                      2) ALL LEDS ARE WORKING. At first. Then they go off block by block.
                                      So do I have a LED problem...OR NOT?
                                      BTW: I also attached a lower resolution version (30%).
                                      • EazyBone
                                        • Jun 2023
                                        • 1321
                                        • United states
                                        #119
                                        1) which is why it's called edge lit. Only on the sides.
                                        • tec3000
                                          • Mar 2024
                                          • 119
                                          LOL. OK, that makes sense
                                          • mauda
                                            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                            by mauda
                                            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                            05-21-2023, 11:56 PM
                                          • chaos-theory
                                            Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                            by chaos-theory
                                            I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                            Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                            03-14-2025, 05:37 PM
                                          • solveit68
                                            Lenovo L580 20LW-0010GE shuts down after a few seconds
                                            by solveit68
                                            Hello together,
                                            I am hoping for some tips here to repair a notebook.
                                            The notebook has following issue:
                                            After starting the notebook it shut down after a few seconds.
                                            Sometimes it is possible to enter the bios but then after, another few seconds it shuts down also.
                                            The time until shutdown varies slightly.
                                            What I've tried so far:
                                            - cmos cleared
                                            - removed all components that are not essential for motherboard testing including keyboard and touchpad
                                            - ram exchanged
                                            - same behaviour with power supply or battery...
                                            07-21-2023, 01:04 PM
                                          • doejohn11
                                            Lenovo Legion 5 17ach6h shuts off after 70 seconds.
                                            by doejohn11
                                            Hello guys. I have a legion 5 17ach6h with Ryzen 7 5600h and RTX3060.
                                            It was working perfectly fine but the cpu was overheating so i decided to replace thermal paste. I bought one from local hardware store and replcaed. it looked fine then the fan started to spin at the full speed after about 1 minute and then immediately shut off after 10 seconds. Then I though if i have done something wrong, so i cleaned up everything with IPA and put new thermal paste. but the issue was still there. After that, I came across this article where he had similar issue and he was able to solve it by replacing...
                                            04-19-2025, 07:38 AM
                                          • IamPritesh
                                            Sony VJF152C11N DA0HKDMB6D0 shuts down in 1 min
                                            by IamPritesh
                                            So I have this Sony VJF152C11N ( Board Number : DA0HKDMB6D0 ) which came to me with no charging issue. The Charging IC was getting hot so replaced it.
                                            ISL88732 replaced with ISL88731 and also the lower mosfet PQ59 ( NTTFS4C10NTAG ) with a similar N channel mosfet. Now the Charging is fine with 15.7 on BAT+ line but the new problem is that laptop boots till sony logo and then shuts down when battery is connected ( With or without AC adapter )
                                            What could be causing this is a non compatible IC or FET or poor soldering or some kind of shorting?
                                            07-31-2022, 05:23 AM
