Sony LED 65X9005A shuts down after few seconds - looking for help
I never remove any of the boards when doing backlights. Also. As Davi said, plugging it in will or ve useful after screen is off. Donny seems to be quite the cautious guy. I have done maybe 100 backlights and never damaged a board while it's on back, just don't move it around like it's gym weights. Looks like your gonna have fun
Happy Easter guys!
I was able to remove the frame from the back of the TV. My TV is a bit different though. I couldn't even use the suction cups. I simply took out the entire back out of the frame. Tomorrow I will get down to the LEDs. But I plugged in the TV and indeed half of the screen turned dark. So it's confirmed!
It's not all good news though. No idea when and how but I did some harm to the top of the panel.
No idea what the real world implications are going to be. I guess the i-Manual will give me an idea what I can expect from the TV from now on. I'll definitely assemble everything back and have a look.
Looks bad guys, right? I know I messed up but I still want to buy the LEDs. Should I go ahead?
What am I looking at. What are these holes on the black thing?
And where is picture of panel damage. If you effed the screen I wouldn't proceed no. I would still break it down to the LEDs and have a look and then put it all back together again as some practice. Do it as if you didn't damage the panel so you can learn.
Those holes are just placeholders for the speakers beneath. I had uploaded pics of my TV but here someone else's set where you can see what it looks like from the front. (Pic 1)
And I have circled the area with the panel issue. The glass is not broken or anything. It's somehow beneath the coating. Really not sure how it happened and what it is? (Pic 2)
Please.. 8000x6000 pics are way too much.. my pc goes nuts.. scale down them..
i can only view the reduced versions.. obviously this is a model with front covering glass with flat surface finish that inglobates speakers.. the way you put it on the sofa is wrong, must be front faced down.. so it doesnt unglue the real LCD.. actually front piece is maybe plastic and lcd is havier weight glass
Originally posted by Diah View Postthis is look like air between the LCD and the front glass. .. don't bother with it right now. complete the access to LED strips
SO GUYS.... I was finally able to remove everything. I'm a bit surprised.
1) I only see LEDs on each side of the TV. Nowhere else. Nothing in the center... Is that expected? Or do I still need to remove more?
2) ALL LEDS ARE WORKING. At first. Then they go off block by block.
So do I have a LED problem...OR NOT?
BTW: I also attached a lower resolution version (30%).
