Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
  • mauda
    • Mar 2016
    • 24
    • Czech republic
    I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
    Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
    Here's what I've tried so far:
    When I received the TV, it wasn't functioning at all. Upon powering it on, the relay clicked twice, but nothing else happened. According to the service manual, there was a voltage issue behind the Wi-Fi inverter on the mainboard, indicating a faulty CPU (MT5597BMEJ). I found a similar issue described by another user on a forum (https://www.badcaps.net/forum/showthread.php?t=82203) who resolved it by replacing the mainboard.
    I ordered a used one from England, but it didn't revive the TV, nor did it successfully load the update from the USB dongle.
    All the voltages on the English mainboard were fine, so I tried swapping the memory modules (EMMC THGBMDG5D1LBAIL), but the TV's behavior remained the same as I described at the beginning (Sony logo for 3 seconds).
    I then purchased another used mainboard from an ebay auction, and it exhibited the same behavior as the one from England. I tested the contents of all three EMMC modules on both used mainboards, and they all behaved in the same manner.
    I couldn't find any relevant firmware DUMP files on Google. If anyone happens to have one, I would appreciate the opportunity to test it.
    Thank you for your attention and any assistance you can provide.
  • Bob1394
    Vizio M65-C1 | Logo appears for 10 seconds then off
    by Bob1394
    I have used the search, and am stumped.
    My Vizio M65-C1, Vizio logo appears for about 10 seconds then goes off.Power LED blinks 15 times then the TV powers down.
    I have read through many threads on the M65-C1 including the following threads. I feel like I must be looking right past the solution to my problem:
    https://www.badcaps.net/forum/showthread.php?t=81088
    https://www.badcaps.net/forum/showthread.php?t=84241 (not clear on the Eprom actions)
    Observations
    1) [Interaction] Power turned on via TV button (or remote)...
    02-08-2023, 01:03 PM
  • Ihandyrepair
    4 red flash led 65X950G boot Sony and android logo but then black
    by Ihandyrepair
    HI guys
    I got here a Sony 65X950G - I tried to find any repairs guides for this model but not many online
    here is the issue
    I have Sony and android logo. but then 4 led red flash lights front of the tv
    I have 3.3v ref. 12v reg then T con 12v when I press the power on button
    but then I get black screen and 4 red flash light at the front LED
    but I get 3 led flash on the LED driver board.
    I check that few X900F or C YouTube repairs, seems that if you have 4 led red flash it could be due of LED black light error
    so I tried...
    07-11-2024, 01:45 AM
  • TerraPhantm
    Sony A8H to A80J mainboard upgrade possible?
    by TerraPhantm
    I have a Sony 65A8H. Always bothered me that it doesn't have HDMI 2.1. I noticed the A80J board appears quite similar. And comparing some wiring diagrams in the service manuals (albeit A9G vs A90J since I couldn't find the A8/80 manuals), things appeared quite similar. And my understanding is the panels between the two TVs are more or less the same.
    So I decided I'd experiment a little bit.
    I bought an A80J board. Left the speaker connection unplugged because it doesn't fit. Changed the power connector to fit the new board. Plugged in everything else.
    When...
    08-15-2023, 08:10 AM
  • mmartell
    Sony KDL-65W850C is this a Mainboard issue ??
    by mmartell
    This sat around for quite some time after the backlights died with the six blink error code. I bought replacement strips and eventually swapped them in.
    Backlights appear to be working fine now. However the tv only powers on with the "Sony" logo for about two seconds after which it goes away and the panel with backlights stay powered for about twenty more seconds then it shuts off. Tv can only be powered again after power cycling at the outlet.
    It will not program via usb, the stick flashes but there is never any indication that it has entered programming...
    11-19-2023, 10:27 AM
  • noinimod
    Sony 55X900E no standby light, no power. Replaced mainboard already
    by noinimod
    No standby red light, nothing
    This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
    Disconnected JK3 power board from main board, checked voltages on all the pin outs
    At a few pins I can see the power supply providing 19.5V to the main board
    Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
    LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
    12-22-2021, 12:58 AM
