Sanyo DP42849 - No Power At All
    Re: Sanyo DP42849 - No Power At All
    Yes, you want the TV to do that power light up briefly.
      Yeah I just realised it doesn't even bother trying to turn on unless the other boards are plugged in.
      0 on voltage test when power button is pressed.
      1 on resistance test when TV is unplugged.
        On the resistance test, I do get a reading when it's on 20M - 1.45
          BTW - I retried that hair dryer on caps thing yesterday too, since I put the new IC in, but it didn't work.
            You using 20VDC scale? 0.00V?
            No short, so it must be in ckt that feeds that part.
              Yes - for 20DCV, I got 0.00.
              But I did get something on resistance test when moving up to 20M.
                Now I need you to test the macro mode of your camera. Best pic you can get of area around J38 (bottom, green side)? Need to see small parts and traces.
                  I posted some pics in #214. They should zoom in when you click the magnifying glass. Do you need closer than that?
                    Didn't see those. I've highlighted some points to ohm out. Please test between the RED and each BLUE points in 2000 ohms. If I have the circuit right, they'll all show near zero.
                    Also, the part# of IC301 would help too
                      I pulled the board out to test.
                      Point 1 - 0.01
                      Point 2 - "1"
                      Point 3 - "1"
                      DDA002B
                      PAA0909G
                        OK, let's try again. Test as before.
                        DDA002B is available, but appears to be a proprietary Delta part (most likely specifically marked rather than dedicated design, but it makes it hard to find a datasheet for it.)
                          I found a C variant as an ON SEMI component, 19pin. Do you think this pinout helps at all?
                          http://pinout-circuits-images.dz863.com/30/DDA002C.jpg
                            http://www.dz863.com/circuits-2-8160...ation-Circuit/
                              http://www.datasheetlib.com/datashee...html#datasheet
                                Nice one... Looks like a good match
                                  you're welcome
                                    You guys are really great at this, and I appreciate all of your help. I think if I were better at this, we would be farther than we are :/
                                    I will retest in a bit, but I have a question. Someone on my local Craigslist just posted my exact same model and chassis for $35. It stays turned on, but no picture.
                                    I'm thinking of offering him $20 for it and trying the power board in mine. I've been eying boards, and my chassis is out-of-stock everywhere, and if it ain't, it's $100 plus. There's one on eBay for $60, but what a hassle if it doesn't work. At least this way, I can see it working and only be out $20 if it doesn't fix mine.
                                    What do you think?
                                    Here's a thread on the same TV, same problem.
                                      i would try to get the one of craigs list if it was me before it goes!
                                        Parts are worth more than $35, it is a good deal even @$35.
                                          No picture, there is a chance that big inverter transformer is bad, (if no backlight) but you can swap them over, it's just a lot of work.
