Sanyo DP42849 - No Power At All
  • NihonNoir
    • Jan 2014
    • 231
    • US
    #101
    Re: Sanyo DP42849 - No Power At All
    One lead on pin 3, one lead on pin 5.
    .023 one way, and a negative reading the other. I tried with my DMM on DCV 20, and on the DCV Points 2 option. Is that right?
    Did it again.
    DCV 20 - Black lead on 3 and red on 5 = .02
      What do you mean by Points 2 option?
      Was that with TV plugged into 120V AC?
      • multimeter
        • Jan 2011
        • 739
        • united kingdom
        #103
        i cant sleep
        go back to post #44,need to check that big cap,use your new crock clips
        dc volts (highest setting 500dcv?)
        tv plugged reading?
        tv turned on reading?
        im confused with the 2 point thing too !?
        fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
        please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
        • NihonNoir
          • Jan 2014
          • 231
          • US
          #104
          Sorry, I did it wrong. I assumed pin 5 started at the top instead of the bottom.
          TV wasn't plugged in.
          0.00 on DCV 20.
          There's a 'Points 2' option right below DCV 20 on my meter.
          . . . did I ruin it?
          • multimeter
            • Jan 2011
            • 739
            • united kingdom
            #105
            0.00 on DCV 20.
            try again set it to "20" dc volts
              Never seen that before on a meter- maybe a built in pulse gen. Odd. Anyway, you can use DC20V for now. A meter shouldn't cause any damage, and they're generally pretty hardy themselves.
              • NihonNoir
                • Jan 2014
                • 231
                • US
                #107
                Okay, DCV 20 - Black to ground pin and red to pin 5 = 0.01
                  Ground pin = pin 3, right?
                  • NihonNoir
                    • Jan 2014
                    • 231
                    • US
                    #109
                    Sorry yes, pin 3.
                    I've had the TV unplugged for about 15 - 20 minutes now. Is it okay to put these alligator clips on that big cap now?
                    • multimeter
                      • Jan 2011
                      • 739
                      • united kingdom
                      #110
                      Sorry yes, pin 3.
                      post #103 ^^^
                      • NihonNoir
                        • Jan 2014
                        • 231
                        • US
                        #111
                        Well, never mind. The holes in the clips are square. My leads are round!
                          Yes.
                          If you get 160V or so across there, I suspect the STR-A6069H is bad.
                          • multimeter
                            • Jan 2011
                            • 739
                            • united kingdom
                            #113
                            i dont think the pfc circuit is working?,your not finding any voltages anywhere !!
                            • NihonNoir
                              • Jan 2014
                              • 231
                              • US
                              #114
                              PFC?
                              I can't believe my leads don't fit in these clips. Every lead tip I've ever seen has been rounded to a point, and the insertion hole for these clips is a narrow little slit. THe package doesn't say anything about being for specific DMM - just says Alligator Clip Adapter. What the hell, Radio Shack?
                              Never mind - I'm an idiot. Just had to push really hard.
                              • NihonNoir
                                • Jan 2014
                                • 231
                                • US
                                #115
                                Originally posted by multimeter
                                post #103 ^^^
                                Well, I'd planned on connecting the clips first, and then plugging the TV in and stuff. So I don't have to touch anything.
                                • multimeter
                                  • Jan 2011
                                  • 739
                                  • united kingdom
                                  #116
                                  PFC?
                                  most things backwards from that large cap,your going to have to test it!
                                  pfc ,power factor correction
                                  • NihonNoir
                                    • Jan 2014
                                    • 231
                                    • US
                                    #117
                                    Bout to test it now.
                                    • NihonNoir
                                      • Jan 2014
                                      • 231
                                      • US
                                      #118
                                      165 plugged in . . .
                                      • NihonNoir
                                        • Jan 2014
                                        • 231
                                        • US
                                        #119
                                        165/166 plugged in.
                                        No change when pressing power button.
                                        When unplugged, it slowly drains. At 24 now, and falling.
                                        • NihonNoir
                                          • Jan 2014
                                          • 231
                                          • US
                                          #120
                                          Just in case, here's what I found on Google: http://www.digikey.com/product-detai...69H-ND/3661844
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                            03-31-2024, 02:12 PM
