Sanyo DP42849 - No Power At All
  • lookimback
    • Aug 2013
    • 1489
    Re: Sanyo DP42849 - No Power At All
    Red on 1 then black on 1.
    IC 902 0.991 1.594
    IC 201 1.025 1.969
    IC 602 0.915. 1.066
    IC 903 1.032. 0.861
    I don't know if that helps any. I'm sure there are variances due to the differences in our meters.
    ------------signature starts here------------
    • NihonNoir
      • Jan 2014
      • 231
      • US
      #362
      Thanks for doing that. Could you elaborate on what you mean by "Red on 1 then black on 1"?
      • lookimback
        • Aug 2013
        • 1489
        First set of numbers was red probe on pin 1. Second set of numbers was reversed polarity.
        Edit: I don't think I would put too much stock into the actual numbers though. The reading, I believe, is relative to the input voltage and our meters obviously have different output voltages in diode test.
        • lookimback
          • Aug 2013
          • 1489
          If you pull them from the board you can test them. An octocoupler is just an LED and a photo sensor. When the LED receives a current it lights up. The photo sensor reacts to the light and the resistance is reduced allowing current to flow. With the octocoupler out of the board you can connect a battery to pins 1 and 2 and, with your meter on ohms you should see low resistance. Then with the battery disconnected you should see high resistance. Not sure what voltage or polarity but I have the data sheet somewhere on my computer, I'll find it and post. I think a 1.5v battery. Nothing bigger.
          Edit: That was pretty easy to find because I had uploaded it here when I was working on mine.
          You can find a lot of other data sheets for ICs on this board in this thread if you need them.
          https://www.badcaps.net/forum/showthread.php?t=33261
          • lookimback
            • Aug 2013
            • 1489
            Here's a pdf explaining how to use 2 meters to test octocouplers. Not sure if you have 2 meters but you can at least get a better understanding of how they work.
              Please note that as shown in the PDF, the Analog meter, the red probe has negative voltage output with ref to the Black probe, that is why it shows 20 Ohms as shown when Black probe is on Anode and Red probe is on Cathode, it is opposite from DMM.
              • lookimback
                • Aug 2013
                • 1489
                I hadn't even noticed the polarity was reversed. I have once again learned something new thanks to this forum.
                • lookimback
                  • Aug 2013
                  • 1489
                  I don't think the octocoupler is your problem. As Tom said a few posts back, you should see about 1v in one direction (red on pin 1) and infinity in the other. He also stated that on your meter that would be 1200-1400. That's pretty much what you got. Tom is light years ahead of me on this stuff. I'm learning as I go just like you.
                  • NihonNoir
                    • Jan 2014
                    • 231
                    • US
                    #369
                    Thanks for the info!
                    Here are the final voltages with meter on DCV20:
                    First number is cold, second is hot.
                    IC903: 1.26 -- 16.58
                    IC602: 0 -------- 0
                    IC201: 4.97 -- -- 0
                    IC902: 1.05 ----- 0.88
                    • NihonNoir
                      • Jan 2014
                      • 231
                      • US
                      #370
                      Bump.
                      • NihonNoir
                        • Jan 2014
                        • 231
                        • US
                        #371
                        Any ideas?
                          Sadly, I've run out of suggestions, sorry.
                          • NihonNoir
                            • Jan 2014
                            • 231
                            • US
                            #373
                            Is it for certain the power board?
                            • lookimback
                              • Aug 2013
                              • 1489
                              Sorry, I've been working so much lately that I haven't had time to get back to you.
                              Truthfully I can't exactly remember what the problem was and don't have time to read all the previous posts to catch up. Was this the one where it was no 5v stby?
                              I would suggest a little recap of the problem, symptoms, what you have tried already, etc.
                              • NihonNoir
                                • Jan 2014
                                • 231
                                • US
                                #375
                                First had no standby, then replaced IC901, now have standby and green light when power button is pressed, but no picture, no sound, and no relay click.
                                So is it for sure the power board?
                                • lookimback
                                  • Aug 2013
                                  • 1489
                                  Ok. So you are getting a turn on signal from the main. Have you checked the resistance on the big transformer?
                                  On the primary side check between pins 1 and 2 then between 3 and 4. Secondary side between 5 and 6 then 9 and 10. I have had bad transformers in 2 out of 3 boards I've encountered so far.
                                  • NihonNoir
                                    • Jan 2014
                                    • 231
                                    • US
                                    #377
                                    Sorry, which part is the transformer?
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      I don't want to get too involved since i don't have any LCD experience. I have flicked through the posts but at any stage since the stdby was restored has the main board been isolated and the PSU attempted to be forced on to see if it runs and all the volatages are there?
                                      I'm guessing at what you're thinking, but there must be small possibility that the power fail cct on the main board similar to the Norcal video might be at play here.
                                      Does this lock out after 3 successive attempts to cycle power and the LED go out like the video.
                                      You're very determined i give you that spending this much time on the PSU.
                                      • lookimback
                                        • Aug 2013
                                        • 1489
                                        And make sure you do this with the power off and tv unplugged.
                                        • NihonNoir
                                          • Jan 2014
                                          • 231
                                          • US
                                          #380
                                          Yes. No relay click, tho.
                                          I don't know what that picture means.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                            03-31-2024, 02:12 PM
