Sanyo DP42849 - No Power At All
    Re: Sanyo DP42849 - No Power At All
    Check resistance across C603, near D902.
    • multimeter
      • Jan 2011
      • 739
      • united kingdom
      #82
      Originally posted by NihonNoir
      D951 is the one that gave me the low reading for such a big diode (compared to the others), and I've seen that particular diode go bad in other DP42849s, too.
      D901 - 515
      D951 - 209
      d951 maybee a shottky diode,big difference,they have readings both ways but not shorted readings,test it out of circuit,these tend to go short,
      i repaired a tv just recently with a shottky diode,weirdly it tested good in circuit,i removed it and it tested short
      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
      • NihonNoir
        • Jan 2014
        • 231
        • US
        #83
        Okay - which setting should I put my meter on to test C603? I have 200 Ohm to 20M.
        I'll see if I can get that D951 out.
        • multimeter
          • Jan 2011
          • 739
          • united kingdom
          #84
          200 ohm scale
          • NihonNoir
            • Jan 2014
            • 231
            • US
            #85
            Originally posted by multimeter
            200 ohm scale
            It's staying at "1". I tested C902 to make sure I was doing it right, and I got 15.7. Then I test other capacitors with the little "ZZZ" in the middle, and some of them I get readings, and some of them I get "1".
            Okay no - I got my polarity confused even though I tried to pay attention to the + signs. Let me do it again.
            • NihonNoir
              • Jan 2014
              • 231
              • US
              #86
              Okay I was right - I get a "1" on C603 and 15.7 on C902.
              I accidentally reversed polarity on some of the caps in the array near the PS pins and got confused.
              • multimeter
                • Jan 2011
                • 739
                • united kingdom
                #87
                does your meter reading rise then drop off on that c603? c902 sounds suspect
                • multimeter
                  • Jan 2011
                  • 739
                  • united kingdom
                  #88
                  if you have hair drier,can you just heat those caps up for a minute,and power the tv up?and also the group of caps next to the connector with standby voltages etc,power tv up as if you want to watch it
                  • NihonNoir
                    • Jan 2014
                    • 231
                    • US
                    #89
                    Nothing at all on that C603. Stays at "1". Let me triple check.
                    Okay I was right in the first place - I get readings on some of them in the array, and some of them just stay at "1". Let me redo them all and write down what I get.
                    • multimeter
                      • Jan 2011
                      • 739
                      • united kingdom
                      #90
                      check both ways,on c603 it could be open,the battery power in your meter should cause the cap to rise a little and drop back to "1",simular to a flick test with an analogue meter
                      • NihonNoir
                        • Jan 2014
                        • 231
                        • US
                        #91
                        C133 - 156.6
                        C123B - 156.6
                        C123A - 156.6/7
                        C123 - "1"
                        C122C - "1"
                        C122B - "1"
                        C122A - "1"
                        C952 - 15.7
                        C603 - "1"
                        C952 - "1"
                        C951 - "1"
                        I double checked that I put the red lead on the positive solder point.
                        • NihonNoir
                          • Jan 2014
                          • 231
                          • US
                          #92
                          "1" both ways. Reading never changes.
                          • multimeter
                            • Jan 2011
                            • 739
                            • united kingdom
                            #93
                            ok,try heating the caps up with a hair drier,on high for around a minute,then try powering up the tv
                            • NihonNoir
                              • Jan 2014
                              • 231
                              • US
                              #94
                              Gotta run my mom to her doctor, so I'll do that when I get back.
                              Reinstall board, heat caps, plug TV in and press power?
                              About how many minutes should I heat them? I don't wanna ruin anything.
                              Thank you!
                              Sorry - read your message too fast. About a minute. Got it.
                              • NihonNoir
                                • Jan 2014
                                • 231
                                • US
                                #95
                                Oh, I should resolder that diode I pulled out, right? Or can I just stick it back in the hole?
                                  You should solder it back in place.
                                  • NihonNoir
                                    • Jan 2014
                                    • 231
                                    • US
                                    #97
                                    Nothing
                                      What's the part # of IC901?
                                      • NihonNoir
                                        • Jan 2014
                                        • 231
                                        • US
                                        #99
                                        Originally posted by tom66
                                        what's the part # of ic901?
                                        a6069h sk803 23bp
                                          Measure volts DC from pin 5 to pin 3. What do you get?
                                          http://www.allegromicro.com/~/media/...Datasheet.ashx
                                          Should be around 15V to 30V.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                            03-31-2024, 02:12 PM
