Sanyo DP42849 - No Power At All
  • NihonNoir
    • Jan 2014
    • 231
    • US
    #141
    Re: Sanyo DP42849 - No Power At All
    Actually, D902 reads good without any IC 901 there.
      It should do. I think that chip was the only cause of the fault. You can try testing it now.
      • NihonNoir
        • Jan 2014
        • 231
        • US
        #143
        Okay, with the new chip in, the D902 diode reads a little lower at 488.
        491.
          Absolutely fine.
          Now for the smoke test :p.
          • NihonNoir
            • Jan 2014
            • 231
            • US
            #145
            Okay. Here I go.
            • NihonNoir
              • Jan 2014
              • 231
              • US
              #146
              Pressing power button gave me a green light that stays on for about 5 seconds, then turns off. I can do this 3 times before it locks and I no longer get any response.
              Just like this - http://www.youtube.com/watch?v=KSYCn93pz6k
                Well, you got somewhere. But you probably have additional fault, if there is damage due to surge, for example. The lit up LED going out reminds me of the flash memory problem, or Norcal's voltage check.
                • NihonNoir
                  • Jan 2014
                  • 231
                  • US
                  #148
                  Well, the new chip and diode still test good, so that's something.
                  Should I check the same chip this fellow does in his video?
                    Yes.... I would do that.
                    • NihonNoir
                      • Jan 2014
                      • 231
                      • US
                      #150
                      Actually, I haven't got the same board as he does. Not sure what to do next.
                      • NihonNoir
                        • Jan 2014
                        • 231
                        • US
                        #151
                        Also, I don't hear any click when I press power.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #152
                          does the voltage on the main capacitor change now from when is standby and powered on.
                          • NihonNoir
                            • Jan 2014
                            • 231
                            • US
                            #153
                            Well I tried measuring voltages on the pins again, and I'm not getting anything on any of them. Not sure if I'm doing it right - the tip of the lead can barely fit through that plastic connector, and it isn't going very deep.
                            Both with TV plugged in and power button pressed once.
                            • NihonNoir
                              • Jan 2014
                              • 231
                              • US
                              #154
                              When I check that large diode D951 I get 212 one way and 1042 the other.
                                You have standby LED, so for now, that part of PSU is not of concern.
                                • NihonNoir
                                  • Jan 2014
                                  • 231
                                  • US
                                  #156
                                  Well, I have green power light.
                                  What should I do next?
                                  • NihonNoir
                                    • Jan 2014
                                    • 231
                                    • US
                                    #157
                                    Tested main cap. 165 when TV is plugged in. It does not change when I press power button.
                                    Same TV, similar issue here. There's no standby light on this set apparently.
                                    • NihonNoir
                                      • Jan 2014
                                      • 231
                                      • US
                                      #158
                                      Tried to turn it on with main board disconnected. No green power light or anything.
                                      • NihonNoir
                                        • Jan 2014
                                        • 231
                                        • US
                                        #159
                                        Well, I was looking through the service manual again (for a different chassis anyway), and at the beginning of page 5 it explains how the Power Failure Circuit works. What it describes is exactly what my TV is doing: "CPU will turn the unit off in 1.5 seconds" and ". . . set will enter standby mode".
                                        It gives the same instructions that Norcal followed in his video, but since this is for a different power supply, I'm not sure it applies.
                                        I took a closer look at my board, and I do see an "800" next to the IC in question, but I can't tell if there's an "IC" in front of it since there are holes over the text.
                                        I'm having a little trouble understanding exactly how to test the pins 48 and 23, or even if those are the pins I should be testing on my particular model. Can anyone please assist me with this?
                                          Can you post a picture of this IC? Can try and highlight the pins - it is tricky though but if they are on the edge, it is easier.
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • beetle1303
                                            Carver CM-1090 - Power relay clicking on & off, then fuse blown after 20-30 seconds of power cycling.
                                            by beetle1303
                                            I gotten a Carver CM-1090 amplifier from a friend who has kept it in storage for decades. Opened it up, thick layer of dust cumulated everywhere. Vacuumed it semi-cleaned, and blown off as much as possible the remaining dust. This is a 220V version.
                                            On initial powered up with nothing connected - it works with all the lights and button indicator lit up as pressed, etc. I then powered off, connected a CD player into the CD RCA input and powered it on. It seemed to work for a short while and when I turned the volume up and down to see the the VUs works, the power started to clicked off...
                                            01-13-2025, 08:49 PM
                                            03-31-2024, 02:12 PM
