How do we know if PMC, others are corrupt? replying to post 132
ME Firmware Cleaning Guide
Modular Flash Image Tool v16.50.0.1120Attached FilesPremium supporters get full download access and other benefits.
I followed the instructions in post #1.
I also obtained the correct ME firmware version from the WinRAID forum.
Unfortunately, there are several sub-versions in the folder.
Which one is the correct 11.8.50.3460 version?
Thank you for your help.Comment
Thank you for the explanation. Unfortunately, I have another question:
11.8.50.3460_CON_LP_C_NPDM_PRD_RGN.bin => 1984KB and 11.8.50.3460_CON_LP_C_NPDM_PRD_RGN.bin => 7176KB
Why are there two files, and what is the difference between them?
Thank youComment
Thank you.
I couldn't see the forest for the trees. It's amazing what a difference one letter can make. :-)
I downloaded the latest Intel CSME System Tools v11 from the Win-Rais forum and want to use it.
I then opened the file I renamed to ME Region.bin under File => Open.
I can't find the option "Generate Intermediate Files".
Or do I just need to click the green "Build Image" button?
Do I need to select anything other than Premium U besides the LP chipset?
Can someone help me with this? Thanks.Comment
Click the gear shortcut to the left of the "green Build button" That's where you can usually find and disable the option to "Generate Intermediate Files"
Or You can go to Build > Build Settings. Either way don't forget to click OK if the option is tick/untick or simply close the window if the option is Yes/No
"Generate Intermediate Files" , if you can`t find it it`s not too important.
"Do I need to select anything other than Premium U besides the LP chipset?" , the chipset is automatically selected, don`t change it.
"Or do I just need to click the green "Build Image" button?" , If you followed all the other steps go aheadComment
Okay, thank you. I've looked several times, but unfortunately, I couldn't find the "Generate Intermediate Files" entry.
=> The file "untitled.xml" was created successfully.
In the next step, according to the instructions, "Copy or move the ME Region.bin to the decomp folder, overwriting the original," I replaced the existing ME Region.bin file with the renamed ME Region file from the repository folder "CSME 11.8 Repository r39."
Then, according to the instructions, I performed the step "Start FIT again, open the untitled.xml file, click on Build, Build Image."
=> After clicking the button, I got a build error.
But I didn't skip any steps, did I? Where am I going wrong?
Sorry for asking these beginner questions so often, but I'm trying hard to learn. :-(Comment
Thanks for the video.
I found the problem.
I had to go to:
- Flash Settings => Option "Flash Components" => Option Number of Flash Components => select "0" by double-clicking
- Integrated Sensor Hub => Option "Integrated Sensor Hub" => Option "Integrated Sensor Hub Support" => select "No" by double-clicking
After that, creating the "outimage.bin" file worked successfully.Comment
This is so frustrating.
The ME firmware cleanup was successful, and I even got "Configured" in the File System State line.
Now I've tried installing it using the FWUpdate Tool and I'm getting error 8743.
I'm seriously wondering, this can't be right. In the BIOS, I see ME Firmware 0.0.0.0. The file is now the correct one.
What's going wrong? :-(Comment
Start over, you have to:
1. Drag and drop the BIOS backup (made with SPI flash programmer) to FIT
2. Click on "Build Settings" (the button with the cogwheel, to the left of Build image)
3. You can change the output filename (optional) and change "Generate Intermediate Files" to No
4. Save the .xml file (default: untitled.xml), and close FIT
5. Go to FIT folder -> (your_BIOS_backup_folder name) -> Decomp and replace the ME Region.bin with 11.8.50.3460_COR_LP_C_NPDM_PRD_RGN.bin, renamed to "ME Region.bin"
6. Open FIT, and load the .xml (untitled.xml or the name you used), then click on Build Image button
7. If it's successful, you get an outimage.bin (or the name you chose in step 3), this file has to be flashed with an SPI flash programmer directly to the BIOS chip, it can't be flashed via software
Don't change "Flash components" or "Integrated Sensor Hub" settings, "Flash Components" has to be "1" if there's only 1 BIOS chip on the motherboard
The winraid guide mentions changing Flash Components, only in the case of creating a ME Firmware update (FWUpdate) file, not for cleaning the ME region on the BIOS chipComment
Hello,Start over, you have to:
Thanks for your feedback.
If I don't change these settings under "Flash Components" or "Integrated Sensor Hub," I get the error message shown in post 290
Update:
I just tested it again.
If I set the value under "Flash components" to "1" or "2", I get the error described in post 290.
If I set the value to "0", I can create the outimage file.
Is anyone familiar with this issue?
How can I determine if I have two BIOS chipsets installed?Comment
Sorry, I only just noticed your post. :-(
motherboard model number: HSB J MV-4 94-0 E89382
laptop model number: getac s410 g2Attached FilesPremium supporters get full download access and other benefits.
Hi, It's building fine (I've also included FIT tool and the ME region file used)Attached FilesPremium supporters get full download access and other benefits.
by weisianHi all,
I have a VSX-1021 that dropped the UE22 error on me and is no longer was working. I've then done the following:
1. Tried updating the firmware with a firmware I found online but it hangs at 20% and ultimately shows "Update Error 1". I didn't check prior to attempting the firmware upgrade but the firmware after shows "***" for the DSP numbers. This was before I looked online that pushing an update through with a bad DSP chip could corrupt the firmware.
2. Tried reflowing the original DSP chip (D810K013BZKB4000) but firmware version remains "***"...-
by BruggefanHi all
I'm having troubles with an Gigabyte MD71-HB0 rev 1.1.
I've read on different forums that many people had issues just like I had, but for some reason, mine got worse.
What happened:
- Did BMC firmware update in 2020
- Doing this, my MAC adresses were cleared from my nics
- Added MAC adresses with an eeupdate tool
Things worked fine for years, however about a year ago I performed a BMC and BIOS upgrade again.
Since then, both my 10Gbit and my 1Gbit NICs stopped working.
The amber led on the NICs is solid on, no matter...12-18-2025, 03:12 AM -
by SMDFleaIf you have to clean the ME firmware on **some microsoft surface models the touchscreen can stop working.
** Some models do not need this fix.
*You should install the latest updates from microsoft,including the driver packs before assuming there is a hardware problem.* - See Post #2
EDIT: If nothing else works try this fix - https://www.badcaps.net/forum/showpo...8&postcount=40
Always check a working dump from the same model using FIT.If the working dump default setting for "Integrated Sensor Hub Supported" is set to "NO"...-
Channel: BIOS Requests ONLY!
by jrbrassowHello all,
I am attempting to convert an 86-inch commercial display, manufactured by TPV, back into a standard, fully functional TV/monitor. The display is currently running corporate/embedded firmware that prevents standard operation.
The primary goal is to find the original or a compatible "public" (non-corporate) firmware file to flash the mainboard and restore normal HDMI input functionality. 1. Display Identification & Hardware Details- Suspected Origin: TPV / Philips Professional Q-Line or P-Line series.
- Panel HWID (from Windows): MONITOR\MGF86
by Wachenaggoi know a tool https://github.com/MuertoGB/MacEfiToolkit is capable of SN change and Clean ME but not updating EFI Version of the BIN file. is there a guide or a BIOS structure to update the firmware??...03-06-2024, 01:34 AM
- Loading...
