Lenovo Thinkpad Ec Pwd Bypass
  • zomi
    • Nov 2011
    • 505
    #661
    Go to this thread https://www.badcaps.net/forum/troubl...assword-locked
    • zomi
      • Nov 2011
      • 505
      #662
      for the t495 ☝
      • KostiaM
        • Feb 2023
        • 9
        • Ukraine
        #663
        It worked with my laptop Lenovo Thinkpad E14 Gen 2 with AMD Ryzen processor
        Shorted the ground to leg 7 on IT8227e 256.
        Thanks man, very helpful!!!
        • 119149570@qq.com
          • Nov 2018
          • 3
          • chinese
          #664
          Originally posted by alexrockzill
          Hi all! First of all I'd like to express my gratitude and appreciation to Maxpower3 for the shorting method which helped me to remove SVP from my T14 Gen1 Intel based laptop. Everything went smoothly - I shorted one of the required pins to ground, disabled SVP and cleaned the security chip (a couple of times) and rebooted by ctrl alt delete. Password is gone. But i stii get the 2204 Error after rebooting from Windows. I tried reinstalling Windows, that didn't help. I used Lenovo Utility flash drive, initialised the EEPROM, rewritten all S/Ns and other ids to EEPROM. But that didn't help as well. I disconnected cmos and main batteries and tried again - same error. Does anyone know what I can do about it? I have a suspicion that it throws this error because I am disabling Security Boot in the Bios settings. I need it to be disabled for Linux installation. I attached some photos of the errors I get. Is there a way to solve this issue? Thanks in advance for your help, it is highly appreciated!
          rewrite the notebook's name,It will be OK.
          • Geromen
            • Mar 2025
            • 7
            • Dominican Republic
            #665
            ¿Puede alguien marcar los puntos a tocar en la imagen? Sería más facil de entender, ya que soy principiante.Can anyone mark the dots to touch on in the image? It would be easier to understand, as I am a beginner.
            • Geromen
              • Mar 2025
              • 7
              #666
              IT WORKED ON THINKPAD T14 I7-10610U.
              The pin order is as follows:
              1. Where number 14 is located, that is pin 14. The others in the same line are 12, 10, 8, 6, 4, and 2 (2 is also marked on the motherboard).
              2. Where number 13 is located, that is pin 13. The others in the same line are 11, 9, 7, 5, 3, and 1 (1 is also marked on the motherboard).
              Procedure:
              Use a clip to short pins 8 and 10.
              Power on the laptop, hold the short for a moment, then release and press F1.
              If the keyboard doesn’t work, use a USB keyboard.
              Once inside the BIOS, remove all passwords (leave them blank).
              Save the changes and reboot using Ctrl + Alt + Delete.
              • Geromen
                • Mar 2025
                • 7
                #667
                Watch this
                • dino44
                  • Mar 2025
                  • 4
                  • germany
                  #668
                  Hello, I have a T14 Gen1. I've been trying all day to clear the SV password using pins 4, 6, 8, and 10.
                  Currently, I only get the startup logo, and after a short while, the laptop shuts down.
                  Can anyone help me with the best way to do this and get my notebook back up and running?
                  • peste
                    • Dec 2016
                    • 12880
                    • ROMANIA
                    #669
                    post S/N, full name and model, motherboard model,TYPE,etc.
                    Don't post pictures unless asked....
                    read the forum rules..
                    https://www.badcaps.net/forum/troubl...ore-posting​
                    • dino44
                      • Mar 2025
                      • 4
                      • germany
                      #670
                      Lenovo T14 gen1
                      20S1-S1UJJ00
                      serial number: PF-2ZQCB2
                      Board: NM-C931 rev.1
                      • Zalman
                        • May 2020
                        • 32
                        • UA
                        #671
                        Lenovo T14 gen1
                        20S1-S1UJJ00
                        Gotta start shorting early on MEC1663. Listen to the coils whining noise, as soon as you hear it, short pin 8 to GND for 1-2 sec. Before you see any image. I also used external screen with internal disconnected and external keyboard. And use ALT+CTRL+DEL to restart and try over and over. You'll get it eventually.
                        Also I used a tape to cover every other pin except for #8 to save myself a headache of accidentally shorting 2 pins next to each other.
                        • LASTname
                          • Apr 2024
                          • 10
                          • PERU
                          #672
                          WHAT IS PIN 8? PLEASE...
                          • Andromedus_81
                            • Aug 2023
                            • 47
                            • United Kingdom
                            #673
                            Can someone help with how to set up and read this Lenovo model with a BIOS password using SVOD 4 please
                            Lenovo T14 Gen 1
                            Type 20S1-S6D52K
                            S/N PF-2T2WJD
                            NM-C9310 REV 1.0
                            MEC1663-BA0
                            114R7VA
                            • peste
                              peste commented
                              Editing a comment
                              post merged..next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it, then make a new thread..
                          • PMDev
                            • Oct 2023
                            • 17
                            Originally posted by volinakis
                            Maxpower3
                            I confirm your genius method is working for T14 gen 1 AMD GT4A1 NM-C801 rev.1.0 Thank you very much!
                            Which method did you use?
                            • lapfix
                              • Mar 2020
                              • 2736
                              • my workshop
                              #675
                              anyone has tried mawpower solution with E14 gen 3 AMD ryzen !!
                              • PMDev
                                • Oct 2023
                                • 17
                                Procedure:
                                Congratulations for you! Maybe you have some advice for T14 Gen 1 with AMD Ryzen pro GT4A1 NM-C801 Rev1.0?
                                • Geromen
                                  • Mar 2025
                                  • 7
                                  #677
                                  I think is the same process. Just look at the images and try.
                                  • volinakis
                                    • Jan 2021
                                    • 2741
                                    • N/A
                                    #678
                                    it doesn't work, use SVOD4 to read NPC997
                                    • volinakis
                                      • Jan 2021
                                      • 2741
                                      • N/A
                                      #679
                                      read posts, method is described by MaxPower3 in 1st post.
                                      • theBread
                                        • Apr 2022
                                        • 16
                                        Hi ^^
                                        I'm trying this bypass (after succeeding on an L580 and X390 Yoga, thanks for that ) on an E14 Gen2 (NM-D011, should be the same as the E15) by shorting ESPI_IO1 (pin 9 of the IT8227) to ground, but several issues occur along the way:
                                        • Upon boot I get
                                          Code:
                                          0183: Bad CRC of Security Settings in EFI variable.
                                        • Upon reseting the Supervisor password in the BIOS I get
                                          Code:
                                          Failed to save storage: LenovoSecurityConfig. Status: Time out.
                                        • An EATA error occurs if the reboot after the BIOS succeeds (sometimes fails as well, display stays black)
                                        • Shorting to EC pin 7 (ESPI_IO3) (while still using the same timing that works with ESPI_IO1) does not succeed at all altough described as working on another E14 Gen2 (AMD tho).
                                        Result: The bypass only works for me to get into the BIOS, not to actually fix anything.
                                        My question is: Do I have to​ reflash the BIOS or EC at this point?
                                        I remember that I had that CRC error when bypassing the Nuvoton chip of my X390 Yoga, but I sadly do not remember the fix.
                                        Also, what does the LenovoSecurityConfig mean anything?
                                        I do not own a Vertyanov programmer, only a CH341a, so programming the EC might get a bit painful and/or expensive ^^'
                                          Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                          This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 11:40 AM
