Lenovo Thinkpad T495 AMD bios password locked
  • lashamafia
    • Nov 2017
    • 22
    • georgia
    Hello, i need help for unlocking this Thinkpad T495 SN; PF-1YX1VY try autopatch but it's stay black screen,
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1531
    • France
    try for test
    at restart : enter Bios setup with F1 and need clear security chip
    type password blank and load by default and save
    restore original Bios after...​
    • lashamafia
      lashamafia commented
      Editing a comment
      not working,
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1531
    • France
    no boot, black screen or music ??
    • lashamafia
      Editing a comment
      fan restart every 2 seconds and keyboard light also, on my patched bios music play but stay black screen
  • volinakis
    • Jan 2021
    • 3217
    • N/A
    try this, follow instruction from autopatcher
    please support this forum
    • lashamafia
      Editing a comment
      Not worked, i try now to flash bios backup and now it's have same problem not turning on fan restart and keyboard light also restarting, checked soldering it's okay what maybe problem ?
  • volinakis
    • Jan 2021
    • 3217
    • N/A
    It means you read bios chipset with errors, that's why Maxpower3's file didn't work, he's very good in modifying bios in a proper and working way. That's why is better to read Bios guides made by masters of this forum before doing modifications of the bios, they recommend to read bios chipset 2-3 times and compare results, if they are the same it means you got a proper bios dump.
    • lashamafia
      Editing a comment
      Backup file is good i flashed it before an laptop was started, but now when i flash it it's not booting,
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1531
    • France
    startup can take a long time, sometimes several startup cycles before the light
    • volinakis
      • Jan 2021
      • 3217
      • N/A
      and if chipset is MX25L128 replace it with another one, i.e W25Q128, I had many troubles with this kind of chipset after erased 3 times.
      • lashamafia
        Editing a comment
        Replaced bios chip and now it's working, thanks for your reply,
    • volinakis
      • Jan 2021
      • 3217
      • N/A
      good news but be more explicit: is patched file working?
    • libertad_carajo
      • 5
      • Montenegro
      I have a Thinkpad T495 (AMD Ryzen).
      I tried to disable the BIOS supervisor password and Computrace, but I failed.
      Can you please help me?
      What I did so far:
      I tried the autopatcher but wasn't able to succeed (black screen, beep sounds, fan spin, but no boot).
      I flashed back the original BIOS: system works, but supervisor password is still active.
      I attached the dump of the original BIOS (verified by reading it multiple times)
      Model: 20NK (20NKS53V00)
      Serial number: PF25PGKQ
      BIOS version: R12ET62W1.32
      It would be great if anyone could help me.
      Thank you :-)
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      • Gadget & motorcycle addicted
      Thank you :-)
      Boot the machine
      Press ENTER/F1/etc. to enter BIOS settings
      Enter any character when asked for Supervisor Password
      Press enter when it shows Hardware ID
      Press space bar 2x when asked
      Turn off machine
      Restore original BIOS
      Reset BIOS settings to factory default
      Become a Badcaps supporter
      Thanks to all supporters.
      • libertad_carajo
        • 5
        • Montenegro
        Awesome, it worked like a charm! Thank you so much for your help!
        If you don't mind sharing your knowledge: How did you create this BIOS? I would like to learn.
        • Echoo
          • Apr 2018
          • 100
          • Budapest
          Hello!
          I use Autopatcher to create the open bios, the machine starts, but only beeps. screen is black. I am rewriting the original bios, it works, but it has a password. What could be the problem?
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1531
            • France
            Originally posted by Echoo
            Hello!
            https://www.badcaps.net/forum/troubl...55#post3233555
            • Echoo
              • Apr 2018
              • 100
              • Budapest
              Unfortunately, I can't do this, I don't have enough knowledge.
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1531
                • France
                try this one to test
                Originally posted by kuch3n
                Lenovo T495s 20QK
                The first try didn't worked out and the bios beeped 5x times (wrong checksum). UEFITool revealed the wrong hash:
                Code:
                FfsParser::checkProtectedRanges: Phoenix protected range [BB0000h:F30000h] hash mismatch, opened image may refuse to boot
                RelativeOffset: 00BB0000h Size: 380000h
                Hash: 894F0EC4AAE777028ADC60150B10ECE724FC165E6530129DD6B56E45623192E6
                With the help of HxD i calculated the SHA256 of above range and replaced the old hash with the new one (search the old hash and replace it with the calculated one with help of HxD). A boot with manipulated checksum and patched BIOS binary worked. Supervisor password was removed. Thank you very much!
                Donation incomming (:
                [/CODE]
                Click image for larger version  Name:	chk.jpg Views:	0 Size:	231.5 KB ID:	3234910
                Click image for larger version  Name:	cks.jpg Views:	0 Size:	320.2 KB ID:	3234909
                Click image for larger version  Name:	chk2.jpg Views:	0 Size:	349.6 KB ID:	3234911
                • Echoo
                  • Apr 2018
                  • 100
                  • Budapest
                  Thank you very mutch! Perfect! The bios open!
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1531
                    • France
                    clear password and security,load by default. restart
                    and restore original BIOS
                    otherwise password disappears forever​
                    • gsoft
                      • Jul 2023
                      • 38
                      • Italy
                      Hi I need to patch my Lenovo t495 to remove the supervisor password .
                      I cannot use the autopatcher because the t495 is not Intel but a Ryzen.
                      I make a dump of original firmware and now I ask your help to patch it.
                      Please can you help me?
                      board code: FA495 NM C131 REV. 1.0
                      • Acnologia
                        • 430
                        • Poland
                        • Life is too short.
                        It doesn't work ,what you are asking
                        You need at least the SVOD4 or the Vertyanov.
                        • gsoft
                          • Jul 2023
                          • 38
                          • Italy
                          Sorry I don't understand...
                          Is not possible to patch this bios?
                          I read other post where people figured out to patch but not with autopatcher. They ask and someone send the patched bios.... Can you help me please?
                          • lucaszmn
                            by lucaszmn
                            Problem:
                            Initial Findings:
                            • I concluded that the
                            08-12-2025, 03:01 PM
                          • to5it0
                            by to5it0
                            10-24-2025, 01:35 AM
                          • fulaphex
                            Lenovo Thinkpad X13 Gen 3 AMD locked bios
                            by fulaphex
                            hello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
                            I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....
                            07-09-2025, 07:04 PM
                          • Boardview and Schematic Bot
                            Lenovo ThinkPad T495 Notebook T Specification for Upgrade or Repair
                            This specification for the Lenovo ThinkPad T495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T495 boardview and T495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                            09-06-2024, 04:10 PM
                            09-06-2024, 03:30 PM
