Lenovo Thinkpad Ec Pwd Bypass
  • Andreasbest
    • Aug 2014
    • 1151
    • Hellas ( Greece )
    #321
    I mean the model of the EC chip on the motherboard.
    You motherboard color must be blue (green is for Intel CPU) so if i'm correct the EC chip should be on the bottom side so you must diassemble it.
    • sam2929
      • Apr 2024
      • 5
      • algeria
      #322
      ​​​​​​There is 2 winbond
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1220
        • France
        #323
        Cliquez sur l'image pour la voir en taille r?elleÃÃà  Nom : 		image.pngÃÃà Affichages :	0ÃÃà Taille :		355,0 KoÃÃà ID : 			3338343
        NM-E441
        https://www.badcaps.net/forum/troubl...-0#post3273315
        Cliquez sur l'image pour la voir en taille r?elle   Nom : 		image.png  Affichages :	0  Taille :		416,2 Ko  ID : 			3338345
        • Andreasbest
          • Aug 2014
          • 1151
          • Hellas ( Greece )
          #324
          As correctly Max indicated, i's eSPI, no free solution yet.
          • ibo
            • Oct 2019
            • 93
            • Turkiye
            #325
            Is there a paid solution then?
            • Andreasbest
              • Aug 2014
              • 1151
              • Hellas ( Greece )
              #326
              Not sure.
              • kicker12
                • Jul 2022
                • 10
                • Italy
                #327
                Hey!
                #1 -> thanks a lot for the noce job all of you (and especially Maxpower3) are doing. :-)
                I happened to have a Thinkpad E590 which is BIOS locked.locked. Laptop have IT8227-256 chip...
                Question:
                1: can you please xonfirm this method works?
                2- if so, can you please confirm I need to short eithernpinn7 or 8 or 9 or 10nof that chip? From a first overlook they do not seem to be connected but, maybe, there is a via on the board. Also these pins shall go to an EC and TPM debug port but I cannot find that port...
                Any help is warmly welcome!
                Thanks!
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1220
                  • France
                  #328
                  Originally posted by kicker12
                  Hey!
                  Question:
                  Thanks!
                  Cliquez sur l'image pour la voir en taille r?elle   Nom : 		image.png  Affichages :	0  Taille :		164,5 Ko  ID : 			3340186
                  https://www.badcaps.net/forum/troubl...14#post3238014
                  link not work
                  not tested, try
                  yes 7/8/9/10 ​
                  if you have the bios provide it for test with the serial number of the laptop.
                  Not sure it works ITE
                  https://www.badcaps.net/forum/troubl...55#post3312755
                  • kicker12
                    • Jul 2022
                    • 10
                    • Italy
                    #329
                    Zuper!!!
                    Can confirm that worked: took a few attempts but it is now free as a bird!
                    Thanks MaxPower!!! :-)))
                    link not work
                    not tested, try
                    yes 7/8/9/10 ​
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1220
                      • France
                      #330
                      Zuper!!!
                      good news, thanks for feedback
                      • Noldo Fëanor
                        • Jul 2023
                        • México
                        #331
                        Hello everyone.
                        Here is the bypass solution for several Lenovo ECs.
                        This has worked on many ECs.
                        Only works if password is contained in EC
                        I succeeded on many models
                        https://www.badcaps.net/forum/troubl...86#post3217086
                        https://www.youtube.com/channel/UCeF...t_adKcguvynjeA
                        I shorten the LPC bus, with the LAD0:3 and Gnd.
                        you can use the dedicated ports where you connect directly to the track.
                        (Be careful, resistors may be missing on the path)
                        look at the diagrams
                        Hello Max, thx for your hard work. when you say "watch videos to understand" to what videos are u refering to? im new at this and i want to learn how to do this.
                        Again thanks a lot for the info u provided us.
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1220
                          • France
                          #332
                          • lint4u
                            • Nov 2013
                            • 113
                            • lint4u
                            #333
                            Hello Max
                            NM-C881 test point pls
                            X1 yoga Gen 5
                            thank you
                            • Andreasbest
                              • Aug 2014
                              • 1151
                              • Hellas ( Greece )
                              #334
                              Originally posted by lint4u
                              Hello Max
                              X1 yoga Gen 5
                              thank you
                              You must find schematics for NM-C881 first.
                              • lint4u
                                • Nov 2013
                                • 113
                                • lint4u
                                #335
                                Hello there
                                no schematic available
                                do you have it sir ?
                                • Andreasbest
                                  • Aug 2014
                                  • 1151
                                  • Hellas ( Greece )
                                  #336
                                  If i had it would already uploaded.
                                  Try google.
                                  • adamgouadma
                                    • Jul 2017
                                    • 178
                                    • setif
                                    #337
                                    Hello guys I have a LENOVO P73 There I need a way to remove the password
                                    Plate Number FP730 NM-a272
                                    rev ; 1.0
                                    TY 20QS-S02L00
                                    SN 1YZ49P​
                                    • Andreasbest
                                      • Aug 2014
                                      • 1151
                                      • Hellas ( Greece )
                                      #338
                                      rev ; 1.0
                                      TY 20QS-S02L00
                                      SN 1YZ49P​
                                      Schematics: https://www.badcaps.net/filedata/fetch?id=1973909
                                      Page 44
                                      • adamgouadma
                                        • Jul 2017
                                        • 178
                                        • setif
                                        #339
                                        I will try and let you know the results
                                        • kordex35
                                          • Apr 2015
                                          • 49
                                          • Polska
                                          #340
                                          Hello
                                          I have a question, has anyone tried the Lenovo L480 method?
                                          Please provide a diagram of the point-to-ground connection
                                          Best regards​
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
