Lenovo Thinkpad Ec Pwd Bypass
  • ahmedmeer
    • Nov 2023
    • 11
    • dubai
    #261
    which pin is pwd plzz help
    • ahmedmeer
      • Nov 2023
      • 11
      • dubai
      #262
      GE4B0/GE5B0 NM-D011 board number
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1153
        • France
        #263
        7/8/9/10
        • ahmedmeer
          • Nov 2023
          • 11
          • dubai
          #264
          Originally posted by Maxpower3
          7/8/9/10
          which pin?
          i try 7 8 10 but not clear
          lenovo IT8227E
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1153
            • France
            #265
            Originally posted by svadikn
            How did you do it? I did not believe until the last that the bios password would disappear.😮 You are great, thank you very much. 🤗
            Can you tell me how to do it, because I have 2 such laptops with a password in bios. Is this your secret?😚
            I guess you used no password forever?
            if so you need to clean password and erase security chip then put your bios back to original
            otherwise it will never ask you for password again.
            https://www.youtube.com/watch?v=JIHT...nnel=M._.x._.P
            https://www.youtube.com/watch?v=f43J...nnel=M._.x._.P
            otherwise the other was done with the autopatcher
            my version for windows​
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1153
              • France
              #266
              which pin?
              lenovo IT8227E
              it is necessary to make a shunt for a short time on a pin of the EC. have you seen the videos to understand
              • ahmedmeer
                • Nov 2023
                • 11
                • dubai
                #267
                i know. but this model is not clear pwd
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1153
                  • France
                  #268
                  ha ok ;(
                  8227 I don't think I tested
                  A​utopatcher not work too ?
                  • svadikn
                    PC-expert
                    • Jul 2024
                    • 15
                    • Poland
                    #269
                    When I flash the xxx_PATCHED dump, the laptop does not start. I tried to return the original dump, but it didn't start either. I'm doing something wrong.🤔
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1153
                      • France
                      #270
                      bad read maybe or resisitor lost if bios chip removed
                      original3 worked ??
                      • svadikn
                        PC-expert
                        • Jul 2024
                        • 15
                        • Poland
                        #271
                        original3 worked ??
                        I immediately booted PATCHED with no password forever, but the laptop takes a long time to boot, more than 20 seconds.
                        • Maxpower3
                          Bad Veteran
                          • Feb 2018
                          • 1153
                          • France
                          #272
                          you mix the bios
                          it's not the same pc? original 2 and 4 .
                          normal late display if the file does not correspond to the original PC.
                          If no password forever starts on the other machine, clean the password and the security chip and put back your original
                          check with lenovo utility
                          dump eeprom block 6/7 if password is removed
                          Click image for larger version  Name:	363863670_256985520526544_7408429739298972171_n.jpg Views:	0 Size:	562.3 KB ID:	3313555 Click image for larger version  Name:	406670622_284067567554636_3243226384332222195_n.jpg Views:	0 Size:	1.27 MB ID:	3313557
                          if it starts with another file, it confirms the bad reading
                          • svadikn
                            PC-expert
                            • Jul 2024
                            • 15
                            • Poland
                            #273
                            you mix the bios
                            Of course I understand that. I'm doing oryginal4 right now. Downloading W25Q128BV@WSON8_20240721_123730 oryginal4_PATCHED. Now I will show the photo, because nothing works.
                            • svadikn
                              PC-expert
                              • Jul 2024
                              • 15
                              • Poland
                              #274
                              Everything worked out for me!😁 Thank you very much, you are a great professional.👍
                              • oasiscns
                                • Jul 2018
                                • 4
                                • algeria
                                #275
                                Hey dear,
                                Is it possible to bypass supervisor password for Thinkpad t14s gen 3 type 21BS (NM-E091​) ? thnx
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1153
                                  • France
                                  #276
                                  Originally posted by oasiscns
                                  Is it possible to bypass supervisor password for Thinkpad t14s gen 3 type 21BS (NM-E091)
                                  Mec1723 No solution with bypass
                                  • 3mz3t
                                    • Sep 2023
                                    • 13
                                    • Slovakia
                                    #277
                                    Did anyone have success with ThinkPad T495s / X395?
                                    It's the NM-C181 board, it uses IT8186VG-192 as an EC chip and I used LPC_AD0 on the J601 connector for the short to ground.
                                    Best I could get was bios not asking me for the password (plus complaints about invalid machine UUID), but I still wasn't able to reset the password, since the bios was still in read-only mode.
                                    Did anyone manage to get the timing right for this machine?
                                    Thanks.
                                    • arestlessknight
                                      • Jul 2024
                                      • 11
                                      Hi everyone. Searching the web for a SVP bypass has lead me to this forum where I see Maxpower3 is doing excellent work.
                                      I also have the AMD T14 (Gen 3) with the npcx997 and wanted to give the bypass a go. I'm not requesting anything just yet (I will use the info you provided to Arenz earlier in this thread), but just wanted to say hi for now. Best of luck everyone.
                                      • arestlessknight
                                        • Jul 2024
                                        • 11
                                        My first post was written while I was at work and I did not have access to the T14. The Serial No and Type No are as foillows:
                                        Serial: PF4PM76Y
                                        Type: 21CGS0VT54​
                                        Not sure when I will have time to try the bypass, hopefully soon.
                                        • altuntabak
                                          • Jan 2023
                                          • 17
                                          • türkiye
                                          #280
                                          Hello friends, first of all, maxpower, I would like to thank you for this work you have done, I have followed the information you have given (Don't save with F10, just clean Pwd with enter twice.) If I do not press f10, nothing changes when I restart, if I press f10, I constantly get an error and it does not save and changes. Nothing is happening, can you help me with this?
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
