Wiping data completely
+ More Options
Posts
  • stevo1210
    • Oct 2006
    • 4156
    A family friend of mine just upgraded his aging HP P4 desktop computer that his family uses. They only have one PC for the whole house to share and I did suggest he keep it for the kids but he only wanted one PC so he could monitor the kids.
    Anyway, he is a heavy bank user and so forth and he's got family photos, music and excel spreadsheets etc which have been transferred to the new PC.
    He is throwing the HP out at the e-waste dump so he wants to know how to delete all the data completely to never be recovered. I suggested a reformat but he said that wasn't good enough. I also suggested setting the hard drive on fire but he reckons that's a waste of resources.
    I did some research online and he is indeed right and a simple reformat to re-install Windows isn't good enough. Is there any free software out there which can re-write and erase or whatever it is to delete data?
  • stevo1210
    • Oct 2006
    • 4156
    Re: Wiping data completely
    Just found something called DBAN. Will it work on an older P4? I read that it doesnt support new HDD controllers?
    Planning to do a DBAN ---> reformat with Windows and then donate to charity instead of e-waste. (hopefully he agrees to this idea)
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Cant he use it as a slave drive -or perhaps in a usb drive case
      But yes Dban sounds just the job - you could even try a free recovery program like pandora just to see if you could recover any files after using it
      • stevo1210
        • Oct 2006
        • 4156
        I just looked into something called eraser for windows. I dunno if this works, but can I just make life easy and delete all the important files on there without re-installing windows as it is time consuming. Then defragment the hard drive so everything is moved into appropriate places, then just run wipes on the free space remaining?
        The hard drive is IDE, and the new PC uses SATA. That's the turning point.
        • Gariarto
          • Jul 2012
          • 151
          Geez, just put a 'kin hammer thru the HD top cover and be done. Or have some fun and put a round thru it !
          Then use it as a paperwieght with fond memories.
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            @Gariarto It may have escaped your notice but we are heavily into not trashing things on this site. Stevo is simply trying to save the disk so that he can donate the PC to a charitable cause. If you have nothing constructive to say - dont bother.
            • Spitz
              • Oct 2010
              • 95
              Most drive manufacturers have a program that is free to download called zero disk. It writes a code to every location and is supposed to take the drive back to factory. I have used this and have not been able to recover data after using it.
              • lcdman
                TinkerTech
                • Nov 2010
                • 232
                • U.S.A.
                Hello All,
                This is the program I use. It does what others have said they use. Just thought I'd give another FREE alternative. Also great to see you recycling rather than smash or shoot it.
                http://download.cnet.com/Active-Kill...ml?tag=mncol;1
                Take Care,
                lcdman
                • ratdude747
                  Black Sheep
                  • Nov 2008
                  • 17136
                  Hopefully it is legit e-waste and not a "chinese dumpster" bogus scheme...
                  Although I personally would, after wiping the HDD, reinstall the OS to the machine and either keep it as a spare or donate to someone ore someplace that truely could use it... I hate seeing perfectly good things going to waste (hence why I was opposed to cash 4 clunkers).
                  sigpic
                  (Insert witty quote here)
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    dban it.
                    tla's will have trouble getting it back.
                    reload the system as a spare or a donation.
                    • demented_demon
                      • Jun 2008
                      • 19
                      I would either DBAN or Parted Magic, just to give another alternative to DBAn
                      http://partedmagic.com/doku.php
                      Parted Magic has the secure erase feature that sends a command to the disk controller to securely wipe all data from the disk, seems quite effective at wiping HDD's and SDD.
                      • Gariarto
                        • Jul 2012
                        • 151
                        Alright, alright guys, just trying to be light hearted, don't get bent out of shape. Up here in the Northern Catskills our "E-Dump" is a seperate dumpster than general, glass or metal at the town transfer station. Anything going in there worth salvaging gets battered by the next piece thrown in. When you say dump out here that's just what it is.
                        • pfrcom
                          Oldbie
                          • Jun 2006
                          • 1230
                          Sure does - I've used it on i845, i865 & i875 based systems
                          better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                          • Time2Retire
                            • Aug 2012
                            • 256
                            Actually, the best way to make data on a drive inaccessible is to destroy the platters (disks) inside of it. I actually disassemble old drives and remove the platters. They seem to have an aluminum base, with a metallic coating. I put the disk in a vice and heat it with a propane torch, it melts it and makes it unreadable.
                            Wear leather gloves, as they remain hot for a while! There are also good magnets inside a drive. I have two holding down my shower curtain.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              If I want to keep the HDD working, then I just use Active@ Killdisk, like lcdman. It's free and it does the job
                              • larrymoencurly
                                • Oct 2004
                                • 960
                                I think every hard disk manufacturer's diagnostic can completely erase their own brand of drives. Also diagnostics like HDDscan, MHDD, and HDAT2 will do that.
                                • joshnz
                                  • Feb 2011
                                  • 969
                                  • New Zealand
                                  I just low level format with the hard drives manufacturer's disk utility.
                                  I also use winhex.
                                  My pc
                                  CPU : AMD PHENOM II x4 @ 3.5Ghz
                                  MB : ASUS M4A89TD PRO USB3
                                  RAM : Kingston ValueRAM 16gb DDR3
                                  PSU : Cooler Master 850W Silent Pro
                                  GPU : ATI Radeon HD 6850
                                    master hoarder
                                    • May 2008
                                    • 12170
                                    Active@Killdisk is nice, but I prefer this one:
                                    http://hddguru.com/software/HDD-LLF-...l-Format-Tool/
                                    Not sure what this new version is like, though. The old one isn't bootable and this one likely isn't either, so that may be something to consider (i.e. you'll probably need to format the drive from another computer).
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4939
                                      • New Zealand
                                      Yeah, if you want to recycle, sell the thing or even just give it away. Freecycle.org is a good site for getting rid of just about anything you don't want, if you don't want to sell them.
                                      -David VanHorn
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        Here are some options:
                                        -DBAN
                                        -SuperFdisk
                                        • max-power
                                          Dell E6540 laptop completely dead after dssasembly
                                          by max-power
                                          Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                                          that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                                          After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                                          03-24-2025, 08:49 AM
                                        • fiveseventy
                                          RX570 dies completely, then recovers.
                                          by fiveseventy
                                          Hello all,
                                          I have a Sapphire Radeon RX 570 Pulse ITX 4GB (single fan) which has started misbehaving recently.
                                          The card was bought used maybe 5 years ago and has worked without issue until recently.
                                          I have no reason to believe it has been worked on or physically damaged.
                                          For periods of time it will be 100% perfect.
                                          Perfect temperatures, no glitches or artefacts, solid FPS.
                                          I can game, run benchmarks, do whatever without any problem.
                                          I can reboot the machine as many times as I like and nothing changes
                                          however, most times...
                                          06-22-2024, 05:29 AM
                                        • pavski
                                          Completely dead MSI z490 tomahawk
                                          by pavski
                                          Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
                                          I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
                                          t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
                                          Can you please let me know if this is indeed incorrect and what else should I look at next?
                                          Thanks!
                                          06-02-2024, 02:42 PM
                                        • Andreasbest
                                          Lenovo Thinkpad T14s completely dead.
                                          by Andreasbest
                                          Hello.
                                          I received a T14s Gen1 ( NM-C891 motherboard ) that is completely dead, no indication of life at all.
                                          I tried hard reset without RTC battery and short both pins of it for 1 minute but no luck.
                                          Since it's type C connector i have no idea what to measure or where to inject voltage, so any advice are welcomed
                                          Thank you in advance!
                                          Schematic & boardview -> https://www.badcaps.net/forum/troubl...cfc-nm-c891-sc...
                                          03-19-2024, 03:18 AM
                                        • re-atari
                                          Gigabyte GA-H110-D3A schematic/boardview needed
                                          by re-atari
                                          Hello all,
                                          Does anybody have a schematic and/or boardview of the Gigabyte GA-H110-D3A mainboard available? It would really help me out big time...
                                          This board was donated to me in a known non-working state. In its previous life it was used as a mining board, so I suspected bad caps and a relatively easy fix. My intention is to use the fixed board as a testbed for a Truenas or Unraid build. The previous owner told me that the mainboard started to act 'weirdly' after replacing the originally installed Celeron for an i5-6400, varying from starting up irregularly to not at...
                                          02-24-2025, 06:45 PM
